Question about Frigidaire Electric Dryer
How do i replace the front felt guides - Frigidaire Electric Dryer
  • Frigidaire Master
  • 5,323 Answers
THE OLD ONES USUALLY SNAP OFF A PC AT A TIME
Posted on Dec 20, 2014
How to disassemble Frigidaire GLEQ2152ESO to replace felt guide on front of drum?
Hello dneal66 - Generally qualified technicians often perform complicated part replacement such as this due to liability and safety reasons. If I was in your position, I personally recommend contacting a professional to accurately diagnosis the precise issue before investing in parts that may or may not be the root cause. You can often locate a certified service provider through the manufacturer website.
Mar 02, 2013 | Frigidaire GLEQ2152ES Electric Dryer
Brownish streaking on clothes even after cleaning the gasket.
The dryer has felt strips on the front that the drum rubs on. When the felt wears out there is room for clothes to get between the drum and the felt which puts the burnt looking streak on them. Remove the front panel to access the front of drum and the felt guides.
Jan 13, 2011 | Washing Machines
What is the process for replacing the drum bearings for my thin twin LT5000XSN2. Need step by step. Sounds like is about to fall apart. I am very good at fixing most things.
The problem is usually not the bearings at all but the felt guides on the front of the drum. The felt wears off and then makes lots of noise. You can access this part by removing the front along with the door. Listen close with the button in and door open to see if the noise is coming from the front or rear.
Aug 19, 2010 | Whirlpool LTE6234D Top Load Stacked...
How do I replace bearing on a CTD00 Hotpoint tumble dryer
front bearing on drum felt bearing the whole front has to be removed from machine .. if felt back bearing same applies .. if the plastic drum bearing guides this can be done by removing side panel .... always disconnect from mains before attempting any repair
Jun 11, 2009 | Hotpoint NWXR473EV Dryer
Zippers get caught in seal around dryer door and twist around and break off
I had the same problem with zippers and socks. Solution was as simple as replacing the felt seal at the top of the dryer door.The drum rides on the felt seal that has plastic guides imbedded in it. It's function is to seal and more importantly act as a guide for the drum.
Check the drum at the front edge if the gap around it is not the same or if the drum is wobbley when you lift it by hand that is probably the problem.
You will need to open the dryer cabinet. Mine had 2 catch springs at the front top edges that were released by pressing with a thin flat object that will fit between the top and bottom cabinet(butter knife). Once the top can be lifted you may find a couple of screws that secure the front panel and door. Once removed the front panel can be popped off and lifted out (careful of door switch wires).At this point you csn see the felt at the top of the door . It is glued in place and is easily removed. your local appliance part supplier can supply you with a replacement that comes with the glue and installation instructions.
Put the dryer back together and no more burnt socks and ruined zippers.
Jan 22, 2009 | Frigidaire FGQ332ES Gas Dryer
GE dryer is getting louder when running
most common cause is the failure, or wear of the rollers at the rear,
the drive belt places a lot of torque on the drum, and it has rollers to support this force, in addition to nylon guides as the front has
good roller
worn roller
most dryers access from the front, the front panel and door come off,
here are generic removal instructions
with dryer unplugged examine lower front panel.
If there are two screws at lower corners
  • remove screws
  • swing front panel up from bottom
  • unhook top clips
  • undo door switch wires
  • set panel and door aside
If there are no screws
  • remove llint screeen from top
  • remove 2 screws from under lint screen
  • with putty knife or other blunt blade
    push spring clips at front top corners
  • tilt top up
  • remove 1 screw each side 1/3 way from top of dryer
  • tilt front panel down
  • undoor door switch wires
  • set front panel aside
Common to both
  • reach under drum to belt tensioner, pull tensioner to end of spring travel
  • unhook belt from motor and tensioner
  • withdraw drum forward
  • examine rollers felts nylon guides
replace rollers in pairs if worn
replace nylon glides if worn
replace felts if worn, the back one may wear before the front one, if the dryer is the open drum type,
Oct 17, 2008 | Dryers
My Maytag dryer Model DE308 is very noisy. sounds like something is catching or grinding. can I fix this?
good roller
worn roller
  • remove screws
  • unhook top clips
  • tilt top up
Common to both types
Brown streaks on clothes
mich, The brown streaks are probably caused by worn drum guides and lower basket seal. I've seen this quite often on Frigidaire dryers. Part numbers 5303937139 upper felt guide and 5303283286 lower basket seal. This can be a task for an inexperienced person but can be done. It requires removing the top panel and front panel/door assy. The old guides have to be scraped off. The upper felt guides and lower seal glue on. Catriver...post back.
Nov 19, 2006 | Frigidaire GLEQ642A Electric Dryer
Frigidaire  Electric Dryer Logo
51 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
