Dose an awa msdv19-03-do 47cm LCD tv come with 12 volt outlet
sscullys
  • 984 Answers
SOURCE: HOW TO REMOVE 12 VOLT OUTLET
Are you talking about the cigar lighter in the center black panel, or the power point to the right of the radio ?
The center one, you need to pull the trim panel off. Open the ask tray, and give it a yank in both lower corners ( one at a time ) it is hard to do the first time, but there are 6 ( 8? ) spring clips holding it on.
Once you have the trim panel off, the cigar lighter is held in place by a plastic ring from the back. You need to push in the pins to get it off the back ( after unplugging the socket connector ).
To get to the power point, you need to do the same with trim panel removal, and push from the back of it. There are pins holding it into the silver dash panel.
If the fuse for the cigar lighter or power point ( 2 different fuses ) is already dead, just used needle nose pilars to pull the parts out. had the same thing with my Nuvi plug the first time. It is the fuse and nose for the fuse that is left in there.
Posted on Feb 18, 2009
  • 12 Answers
SOURCE: 12 volt power outlets not working
under the hood on the driver side
Posted on May 12, 2009
  • 713 Answers
SOURCE: Which fuse controls the 12-volt outlets. I have
check the accessory fuse, might be labeled as a cigarette lighter or accessory.
Posted on Aug 24, 2009
  • 10 Answers
SOURCE: i need to install a 12 volt power outlet on my truck
this should be a simple task for you since the cherokee already runs on a 12 volt power system. the easiest way to do it would be run a single pair wire from the battery itself to a 12 volt connector. there are harder, more detailed versions of this where you would need to dig into the fuse box, but if you are looking to power something low voltage like a gps, cell phone the first way will work.
you can buy the connector and wire with a fuse on it from any autoparts store. you will need to drill through your firewall and I would recommend a uni-bit or multi-bit to get through it. it will go right on to your drill.
Posted on Sep 25, 2009
techman007
  • 1112 Answers
SOURCE: 42" AWA LED LCD TV,
HI:
This maybe due to a faulty T-Con board, this is what I would replace first, since this is the mose inexpensive part in the set, if this does not solve you problem then it is possible that your panel is odefective and needs replacing, if so then it is cheaper to buy a new television.
Posted on Apr 27, 2011
AWA HD LED LCD TV with builtin DVD Manual
Hi Beverly House
You can use this manual for your LCD TV
http://download1.medion.com/downloads/anleitungen/bda_21097_uk.pdf
I hope my solution may help you.
Thanks for using Fixya...;-)
May 06, 2014 | Televison & Video
Where is the usb port on awa tv
Why would a USB port be on a TV?
See I don't know.
Reason?
This is the Laptop PC category of FixYa.
Suggest you re-post in Electronics > Televisions & Video
http://ernie.awa.com.au/AWA---TV-LCD/default.aspx
Regards,
joecoolvette
(Not your fault? I understand. Things happen, and your problem was posted in the wrong category)
Feb 25, 2013 | Computers & Internet
What does the 12 volt plug in look like?
12 volt plug in is a port on where your adapter of your LCD monitor inserted. its like a male (the LCD adapter) and a female (the LCD port) connector. hope this may help you
Jul 27, 2011 | Supersonic SC1568D 156 in LCD TV
42" AWA LED LCD TV,
HI:
Apr 27, 2011 | Televison & Video
Bought a new awa 32"
is it designed for your countries standards?
Mar 09, 2011 | Televison & Video
Instruction Manual For AWA 106cm HD LCD TV Model CP42PDH10S
what sound system can i put in to my 106 cm awa lcd tv
Feb 05, 2011 | Televison & Video
Do AWA 56CM lcd with DVD MSDV 2203-F3-DO play divx dvds
my one dose with no problems but tha laser has a very short life span either tthat or its prone to dust very easily all my copied movies used to work and now movies only play for 2-10 mins b4 they freeze or says bad disc i reccomend buying a stand alone dvd player for it if u going to buy this tv as the ones supplied in all lcd tv's r cheap nasty *** **** my friends got way better model and having same problems az me.......brad
Sep 22, 2010 | Televison & Video
Sanyo CLT2054 - power cord has light but when I plug it into the
OK you need a volt meter to check the voltage output of your power pack as two things cause this now enough power out the pack to run your unit or the unit has a short both problems will unlight the light so you need to know if the power supply is working right first as it should say like 120 volts AC in and 12 volts DC 1000 ma out so you will need to mesure this with a volt meter. this is a common problem loading the load of the curcuit as in your TV is mor the the power pack is giving out thus shorting out the power pack of any voltage present, as the little LED light your seeing only takes 5 volts at very ittle current to light and dose not repersent the total voltage output of the power pack itself
May 16, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
18 people viewed this question
 Grubhead
Grubhead
