Question about Garden
What weight of oil for Comet BDX 2528
What kind of oil do i use in the Comet BDX 2528
3 Suggested Answers
  • 3567 Answers
SOURCE: WHAT KIND OF OIL AND WHAT WEIGHT SHOULD I USE?
Use 10w40 motor oil in the gear box. Don't use any synthetic oils, oil marked "EC", or oil with "special" additives. Stick with the major brands; Pennzoil, Quaker State, Mobil or Shell.
A “very helpful” rating for this answer? Thanks!
Posted on Jun 22, 2009
  • 832 Answers
SOURCE: What kind of oil do I put in my Comet AXD2524G-T pump?
If the Comet Pressure Pump Oil is some kind of a
Synthetic Oil that supposed to be extra effecient than
an ordinary oil, then that will cost extra. If that is ordinary multi grade engine oil (SAE 20 - 40), then, you
can buy over the counter. Most synthetic oil have additive that give extra longer life to all moving parts.
Posted on Nov 28, 2009
What grade of oil do i use in the zwd 4040 hi pressure pump
30 weight NON DETERGENT. Autozone and other autoparts stores usually have it. It is often hard to find, so you might have to ask them where they hid it.
Dec 13, 2014 | Comet ZWD 4040 G-K Pressure Washer Pump...
Y a t'il un niveau d'huile dans la comet bxd 2525
L'utiliser cette pompe sans huile est une erreur fatale:
[PDF]COMET PLUNGER PUMP SERVICE MANUAL INDEX
www.cometpump.com/_images/support/Pump_Repair_Manual.pdfLUBRICATION: Make sure crankcase is filled with Comet Pump oil. Running this pump without oil will cause damage and void any warranties. Change the pump ..
Mar 14, 2014 | Comet BXD 2525 G Pressure Washer Pump
Who has axd 3020 oil in isle of man
30 weight non detergent works in most pressure washer pumps. available at most auto parts stores.
Jan 08, 2014 | Comet GXD2527G Pressure Washer Pump
Comet water oil
You have to take off the pump head. Here is the link to the service for comet pumps.
https://www.pwmall.com/PDF/CometServiceManual.pdf
Nov 03, 2013 | Comet GXD2527G Pressure Washer Pump
Kinetc comet 250,yr 2005, 7200 km. kindly advice after how many km. of running engine lub. oil to be changed and what all other maint. job along with it.
Every 2000 kms
1. change Engine oil 2. clean air filter 3. clean spark plug 4.check break shoes if necessary change it.
Mar 24, 2011 | Comet Motorcycles
Nov 27, 2009 | Plumbing
Jun 22, 2009 | 1999 Honda VT 750 CD Shadow A.C.E. Deluxe
Oil for Comet pump
aftermarket oil will be fine just use same grade of oil,all manufacturers want that extra kick,
May 12, 2009 | Comet GXD2527G Pressure Washer Pump
Oil Change
Drain engine oil and replace oil filter(your local automotive store will have a book telling you what oil filter you need to buy). You've probably been using a multi-grade 10-30 or 10-40 weight oil. Or a straight 30 weight oil. Regardless, replace that oil with one grade heavier, single-weight of oil. During warm months, use 40 weight; in the winter (depending on how far the mercury dips in your part of the country) use 20 or 30 weight. Slightly thicker oil won't hurt that worn engine, and if your battery is good, it'll turn over fast.
Jan 05, 2009 | 2003 Toyota Corolla
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
