Question about Worx (16") 3.5 HP Electric Chain Saw - WG303
Chain not engaging
When the chain is spinin on the bar but when it touches the wood the chain stops but the motor is still going is a clutch? If so how do I fix it
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 28 Answers
I have not worked on electric chainsaws but I do work on gas powered saws. The clutch shoes could be wore out if the saw sees frequent use. Could be something wrong internally as well.
Posted on Apr 13, 2014
  • Dave Vuckovich Apr 14, 2014
    I would agree with Kevin that the clutch is worn out or the shaft is twisted off
New GMC electric chainsaw runs until it try's to cut wood. Motor runs but chain dose not turn ? Turns if not on wood.!
problem in the safety clutch area
ensure that the safety bar is fully back and engaged before pressing trigger
the safety bar is that handle at you fingers when you are holding the the saw handle and by moving , flicking your fingers forward it stops the chain action
if that is fully engaged , it will require servicing by any accredited chainsaw repair shop
Apr 23, 2017 | Electric Garden
How to take chain off poluan pro saw
Before putting your hands near saw chain cutters, put leather gloves on. Cutters sitting still can still draw some blood.
Loosen the nuts holding the clutch cover, loosen the adjuster, then remove the nuts. Remove the cover. Slide the bar along the studs, free of the adjuster, toward the clutch. Revove the chain from the bar groove, then move it clear of the clutch drive. It's now off. Good time to clean bar grooves and bar-mounting area of dirt & chips.
Reverse the procedure to install a chain, making sure the cutters have their cutting edge facing forward on the top of the bar. Make sure the adjuster is engaged with the bar before tightening the nuts at all.
Holding the bar nose up, tighten the adjuster until the chain touches the bar on the lower side. Tighten nuts.
After short run to clear any debris, recheck the chain tension.
Jan 29, 2014 | Poulan Pro Chain Saw 46cc 20"
Lowering idle speed does not stop chain on ECHO SC chain saw?
I will need more information. Will the chain stop if touched to a log? Is it just creeping along compared to the speed of the motor or matching the speed of the motor? Has the saw been used enough to have saw dust build up inside the clutch and keep it engaged?
Nov 12, 2013 | Echo CS400 18" Chain Saw
Clutch will not engage chain when I pull throttle down. Also chain will not move freely with hand when motor is off. Saw was working fine, and then all of a sudden the chain stopped and acted like the...
Chain too tight? Could be the fastener was loose and it tightened while in use. Remove the cover and the chain and bar. Clean it out and see if pulley turns by hand. Check for broken springs and mounts. Did you have enough chain lube?
Jan 27, 2011 | Garden
Cannot move the chain by hand after the bar has been tightened.
First be sure the chain is on going in the right direction. When looking at the bottom of the bar the sharp tooth should be going towards the motor. When you put chain back on are the chain teeth properly engaged in the sprocket on the motor. Remove the cover again, check that teeth are in sprocket. Make sure pin from adjuster screw is engaged in the hole in the bar. Before you tighten the cover bolts, make sure chain will turn by hand. If not adjust the adjusting screw. Once adjusted, tighten cover bolts. Check again after tightening bar.
Jul 04, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
The chain on my Echo saw is moving very slowly to not at all
Your centrifugal clutch needs to be replaced or your chain guide (bar) is pinched.
Mar 14, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How do you replace the old chain with a new one?
Wearing gloves is recommended. Loosen the bar slide it againt the clutch. Place the new chain over the clutch like pictured below. Place the drive links in the groove and work tour way right until the chain is over the bar nose. Grasp the nose and pull it right, the chain should rise toward the bar bottom. If necessary guide the drive into the bar groove. Find the chain tensioner and adjust it to fit the bar. Proceed as below.
12fe20f.gif Chain adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system.
Oct 10, 2009 | Remington 16" Electric Chain Saw Assembled...
Saw will not cut , chain stops turning when chain touches wood
If your saw has a removable sprocket, Check the drive sprocket on the clutch drum. Either the the spline is worn or the drive link on the chain is not properly seated in the sprocket well.
Apr 09, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 50 Chainsaw - chain wont engage with throttle
if you lost tension on chain and now it wont turn you might want to check sprocket
Nov 06, 2008 | Garden
Worx (16") 3.5 HP Electric Chain Saw - WG303 Logo
109 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Jay Finke
Jay Finke
Are you a Worx Garden Expert? Answer questions, earn points and help others
