Question about Frigidaire FGHB2844LF French Door Refrigerators
Fghn2844lh not cooling
Refrigerator stopped cooling. had a power failure indicator light and a high temp indicator light. hit reset and the power failure light went out, but the high temp (was at 54 degrees) came back on. freezer seems to be working ok, no ice build up in the freezer. 1 year ago similar issue and the repairman replaced a fan (I think it was the fan that blows from the freezer to the refrigerator section, but I was not around then, explained to me by my girlfriend). Any ideas? Thanks, Wayne
    Problem Solver:
  • 9 Answers
You said the freezer is working fine, so that would rule out compressor failure. If the fan motor is working on the system, check the vents and make sure they are not blocked. Sometimes, food will be placed in fron of the vents inside the freezer and inside the refrigerator compartment, blocking the exchange of air. If vents are not obstructed it may be the circuit board that controls or regulates the temperature for the refrigerator side. If your unit has a control setting, turn it off for a few minutes, this will allow it to re-set, then turn it back on and re-set the temperature settings if they don't go back to factory pre-set. Most units are pre-set at the factory for economy, but the consumer can set them lower or higher manually for more desired settings. If it is the control, you can usually replace it yourself with a new part and save money, or have a service tech do it. A power surge or power failure could have disrupted the system and caused the original factor settings to be lost, and they need to be reset. Hope that helps.
Posted on Apr 14, 2014
catriver
  • 878 Answers
SOURCE: Fridge & Freezer not getting cold enough
Welshons, Take a look at the picture Im posting. Did your evaporator look like it? If so your system may be restricted. This is a pretty common problem in Frigidaire top mounts. The good news is that it would be covered under warranty if it is not over 5 years old. As long as your condensor fan is running and the condensor is clean, evaporator not frosted up and evap fan running. I would think that you have a weak compressor or a restriction. Catriver...post back.
Posted on Oct 20, 2006
Krazytech
  • 725 Answers
SOURCE: Frigidaire side by side model# FRS6LR5EW6
Sounds like a defrost problem or a plugged drain... to get it to work temporary defrost the freezer. Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks.
To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain.
The defrost systems is:
HEATER-DEFROST
THERMOSTAT-DEFROST
Adaptive defrost control
Start with the adaptive defrost control board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
Frigidaire - referance model FSC23F7DSB3
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A �d� in the freezer temperature window and �F� in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. �d� and �F� will be displayed until the defrost cycle is complete. (approx. 8 minutes)
Heater / Thermostat
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Posted on Aug 10, 2008
rpbuice
  • 161 Answers
SOURCE: ice is forming around fan in back of freezer compartment
The defrost system is not doing it's job. I bet if you took the panel off below the fan you will see more ice on the cooling coils. There should be a light coat of frost on the coils but not a heavy ice build up. There is a heating element at the bottom area of these coils which should be defrosting all this ice.
1. A defrost timer turns this heating element on.
2. The heating element melts the ice.
3. A thermo disc attached to the coils will turn the heater off.
One or more of these are not doing it's job.
Posted on Dec 16, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Frigidaire Side By Side Not Cooling
That sounds like the start relay is buzzing. Unplug and lets check the compressor to see how hot and if too hot to hold your hand on the top of compressor we need to leave it unplugged until we find out if the start relay, start capacitor, overload or if the condenser fan stops after running a short while. Sea Breeze
Posted on Sep 13, 2009
BMT60
  • 126 Answers
SOURCE: Both the freezer section and refrigerator stopped
YOUR REF. MAY BE STUCK IN DEFROST. IN THE CEILING OF YOUR REF. THERE IS A CONTROL HOUSING. THERE IS AN ACCESS HOLE ABOUT 6 INCHES BACK MORE OR LESS IN THAT AREA. INSIDE THIS HOLE IS A ROUND GREY, BLACK OR RED PIECE THAT CAN BE TURNED IN ONE DIRECTION WITH A FLAT BLADE SCREW DRIVER. TURN IT. IF IT STARTS YOU WILL NEED A DEFROST TIMER. NEED MORE HELP JUST ASK.
http://www.searspartsdirect.com/partsdirect/index.action
Posted on Apr 25, 2010
Fridge & freezer lights and the water display light beep and flash 10-12 times every few hours. Simultaneously a fan motor starts and stops. Any one know what needs to be done to remedy this?
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Apr 25, 2015 | Refrigerators
How do you get the model 370lb to stopping beeping
Mar 30, 2015 | Refrigerators
My samsung frige, french doors keeo ringing
Mar 19, 2015 | Samsung Refrigerators
Open door 18 beeps lights flash red green fridge not cooling
Mar 14, 2015 | Refrigerators
Keeps beeping without stopping
Mar 09, 2015 | Smeg Refrigerators
How do I get my refrigerator to stop beeping
Sep 10, 2014 | Samsung RF4267HARS Stainless Steel French...
MY FRIGIDAIRE FRIDGE IS BEEPING AND NOT STAYING COOL
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Jul 07, 2014 | Frigidaire Refrigerators
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
FREEZER HIGH TEMPERATURE WARNING LIGHT DOESN'T GO OUT.HOW TO CANCEL OR RESET?FOR HOTPOINT FFA74.THANK YOU
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Apr 02, 2009 | Samsung Refrigerators
Frigidaire FGHB2844LF French Door Refrigerators Logo
126 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
