Question about Apple iMac Computers & Internet
Fix ya com
I have iMac computer made in 2008.RAM 2GB.Recently it frequently freezes up (beach ball appears and no matter how long I wait it does not go away) Disk Utility does not indicate any problems .Considering this and the fact that I do not hear any clicks,noises etc makes the impending failure of HD unlikely.The only way to deal with the problem is to switch off the computer is using a power button.Switching to another browser does not help.It can happen regardless of what I am doing eg accessing a webpage reading email)When these problems occur there is usually approx 50% of free memory and a lot of free space on HD.I did not recently install any new software My operating system is OX 10.8.6.
  • 36 Answers
When you say you've used Disk Utility, have you done both Repair Permissions, and Repair Disk? For Repair Disk you need t boot from a different drive, the original install DVD if you have it?
Another thing to try is, remove and and then replace the RAM chips, sometimes the connections need to be re-seated.
Thanks,
John
Posted on Feb 23, 2015
StephenMunn
  • 97 Answers
SOURCE: Can't locate the dirve in Target Disk Mode
You are going to need a system install disk for this machine if you want to reinstall it. However, if you just want to run diagnostics, any system install disk for MacOSX should do the trick. You just won't be able to run the installer once you boot from the DVD. The first thing I would do is make sure the eBay seller sold this to you in this condition and without the install disc, because if not, you've got an issue with them.
If you don't have an install disc, your cheapest solution is to call Apple and order a replacement disc for your model computer. You will need your serial number, which you can find on the sticker on your computer. Good luck, and let me know if you need more guidance with this.
Posted on Jan 09, 2009
SOURCE: My imac g4 isn't reading the dvd/cd drive at all
it won't read it because the new os disk is double layered and the g4 drive you have probably won't read double layered dvds.  best solution is to buy or borrow an usb external dvd drive.  i did this last week and it worked fine.
Posted on Mar 14, 2009
darksidegds
  • 21 Answers
SOURCE: wont start up completly
there is the single user start-up, which you were thinking of. There is also a safe-boot for macs.
To start up into Safe Mode (to Safe Boot), do this:
1. Be sure the computer is shut down.
2. Press the power button.
3. Immediately after you hear the startup tone, hold the Shift key. The Shift key should be held as soon as possible after the startup tone but not before.
4. Release the Shift key when you see the gray Apple icon and the progress indicator (looks like a spinning gear).
During startup in Mac OS X 10.4 or later, you will see "Safe Boot" on the login window, which appears even if you normally log in automatically.
During startup in Mac OS X 10.2 through 10.3.9, you will see "Safe Boot" on the Mac OS X startup screen.
To leave Safe Mode in any version of Mac OS X, restart the computer normally, without holding any keys during startup.
Posted on Jul 07, 2009
  • 5 Answers
SOURCE: disk utility won't recognize that there is a
They are a few thing to try althoguht you may have already tried them;
Pram and PMU reset -
First turn off the iMac, once turned off unplug everything from the IMac and physicallly unplug it from the wall, wait about 5 mins at this point, then just plug in the very basics (keyboard + mouse) - this is the PMU or power management unit aspect of this - the next step is a PRAM or paramiter RAM reset
To do this hold down the apple + alt + p + r key on your keyboard just after you turn on the iMac, and keep these held down, you should hear it chime as normal, now if you keep holding down the keys you shoud here it chime again, keep the keys pressed down till you have heard 4 chimes in total.
After that is done let go off the keys and the iMac should restart as normal - can you eject the disk now?
Sadly System profiler is normally very effective at picking up hardware that is installed in your Mac, The fact that it is not brining up anything would suggest that the super drive may be faulty or somehow disconnected, if you try the above and it does not work then i would suggest you call a AARC or apple authorised repair center and have the S/N: Serial number of your Mac ready - you can find your local repair center on the Apple website - for example the closes repair center to me would be Jigsaw Solutions LTD (www.jigsaw24.com) who are the UK's largest retailer of Apple abode and Quark.
I hope the above is helpful and that you do not need to contact an apple authorised repaird center!
Posted on Jul 14, 2009
  • 50 Answers
SOURCE: IMac G4 completely dead!
It sounds like you may have tried this already, but I'm not sure.
Unplug the computer, disconnect the power supply form the logic board, and remove the battery completely. Let it sit this way overnight. Reassemble it and try again. It dissipates latent electricity from the board.
Posted on Jul 22, 2009
Imac freezes up
This sounds like overheating.. if the fan on your processor has failed you will get some time when you can use the pc and then it stops. Turning off for 15 minutes and then back on again gives you a little more time.
Solution.. check cooling fins are clear of dust and the fan is running freely, lack of cool airflow is the usual cause. if there is no dust and the fan is running then it is possible that the processor is suffering from failing ram.. try replacing your ram..
good luck.
Mar 30, 2017 | Cell Phones
Fix ya com
It could be "bad RAM" -- run a RAM-testing program, or remove the RAM and install different RAM.
Like trying to use chalk to write on a chalk-board that has a few "greasy" spots, and being unable to read what you wrote, having bad RAM causes the computer to "freeze" when it cannot read from the RAM.
Apr 13, 2014 | Cell Phones
Can't sign in + can't change password
to reset without any admin passwords, you'll either need a boot disk or use command line to reset the admin password
Apr 09, 2014 | Apple 13.3 MacBook Air 1.6GHz 2GB RAM...
STAC2000106 freezes
forst check the usb cable, if it is loose replace it, if not then may be a board problem
Aug 18, 2013 | Seagate FreeAgent GoFlex Desk STAC2000106...
Beach ball appears when typing emails often for short / long periods freezing screen
Try running Malwarebytes go to http://www.filehippo.com/download_malwarebytes_anti_malware/
Dec 12, 2012 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Imac i3 with 8 gb ram is still too slow
Well, there are a lot of reasons that can consequently cause the issues on your iMac. Meanwhile, there are certain ways through which you can do to fix one by one. However, if you prefer a more efficient way to resolve, try an all-in-one Mac speed up tool as it can help resolve all issues in just a few clicks.
Nov 22, 2011 | Apple 21.5" iMac Desktop
My 24" Aluminium iMac (early 2008 model) with 2.88Ghz 320g hard drive and 4g rams would freeze out of nowhere...I have ran various program tools to scan (tinkertool, DiskWarrior etc) soft and hard ware but...
Thank you for contacting Fixya Support, I am glad to assist.
In cases where you are experiencing issues with your iMac 24" and you have already tried hard drive and software repairs (including Tinkertool and Disk Warrior), one troubleshooting step I would recommend you try is unseating and re-seating your RAM card one module at a time.
Once you have tried this, then run Disk Warrior, run the Repair Disk Permissions (at least twice).
Once you have run the Disk Repair option, then perform a Disk Rebuild (it will not remove your files from your hard drive but actually rebuilds the Mac OS X directory) and reboot your iMac.
Try this procedure and see if that makes a difference in your iMac's performance.
Let me know if this helps.
Regards,
-Mactechtrainer
Sep 03, 2010 | Apple iMac 24" Desktop
Spinning wheel of death (beach ball)
Open the Activity Monitor application can see what process is taking the most CPU time.
You can also use the "top" utility by opening the Terminal program and then typing "top" and pressing return at the command prompt. To quit top just press the "q" key.
Mar 05, 2017 | Apple Computers & Internet
Imac the older one ball like base
I don't know what is wrong, but I'll bet it can be fixed by reinstalling your Operating System. You will have the option of archiving your old system, and the files won't be touched.
Sep 22, 2008 | Apple iMac G4 Desktop
Computers & Internet Logo
89 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
