Question about Sewing Machines
Remington stitch mate
Needle replacement
    New Friend:
  • 15 Answers
Hi Bobby B,
Do you just need new sewing machine needles? There are so many types it is dizzying. Go to a place like Hancocks, Joann's or Hobby Lobby. They will be able to help you. Nearly every type of fabric has a needle that will work the best with it. Good Luck! The needle most used is a 80/12. That is the standard needle.
Posted on Apr 17, 2014
2 Suggested Answers
  • 980 Answers
SOURCE: all stitches skipping and i replaced the needle
Providing you have put the needle in the correct way round if the machine is still skipping stitches you may need to retime it, email me if you need timing instructions but remember to give me your make and model drivewithken@blueyonder.co.uk
Posted on Mar 07, 2010
Needle stays down, will not come up.
sounds like the machine froze up, machine needs to be serviced
Sep 25, 2015 | Singer 5400 Sew Mate 60-Stitch Sewing...
Sewing machine needle will not pick up bobbin
Hai, You can use (elastic) big size new quality needle. Then last 10 or 5 steps off the machine movie the handle.
Mar 23, 2014 | Singer 5400 Sew Mate 60-Stitch Sewing...
Skipping stitches
Skipped stitches
1. A bent or dull needle
2. The wrong needle for your fabric
knit fabrics require a jersey or ballpoint tip. Most wovens do well with a universal tip, and specialty fibers, like leather or metallic, usually require specific needles.
3. Incorrect machine threading
4. Unbalanced needle thread tension
Start by making relatively small changes and run a test stitch to evaluate the impact. If you need to adjust the tension dial using woven cotton fabric with good quality all-purpose thread and a new needle
5.check the needle is inserted correctly. The needle needs to be pushed as far up the needle shaft as possible. It's easy to insert the needle half way, clamp it down and think it is inserted correctly.
the flat part of the needle should be positioned towards the back. If the needle is not inserted correctly, it will not be able to pull up the bobbin thread and will cause skipped stitches.
6. If the suggestions don't help then it is time for a tune-up.
Nov 19, 2013 | Singer 7256 Fashion Mate Sewing Machine
Zigzag stitch not catching
try these suggestions and see if they help
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Oct 19, 2012 | Brother CS6000i Computerized Sewing...
I cannot form any kind of stitch with my Fashion Mate #237. What could be the problem?
Hello:
Check your needle. Make sure it is fully inserted into the needle bar clamp. Also check and clean your bobbin area and under the needle plate and around the feed dogs.
If that doesn't work for you ... get a magnifying glass and check the shuttle hook, needle plate and bobbin for burrs.
Otherwise your machine may be mis-timed and need professional cleaning and adjustments.
Jul 22, 2012 | Singer Sewing Machines
Hello, I just got a remington super deluxe zigzag 141 machine. I can't get it out of button hole mode? I also am looking for a manual. It seems to work well, just wants to sew like it is doing a button...
push down on the lever ro the right of the button hole selector until it says manual. that's for straight stitching. i have the same machine.
Oct 12, 2009 | Sewing Machines
Sewing machine not stitching at all
SIX Layers !!!!
You really need a size 16 needle that won't bend and miss the hook by the sound of it....can you sew on less challenging thicknesses OK ??
If not, the timing may need adjusting...here is a link to assist:
HERE
Jul 31, 2009 | Janome 1017 Mechanical Sewing Machine
Sewing Machines Logo
75 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
