Question about Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range
Error code 40 amana gas oven
Oven does not start. no clicks no gas. GAs works for stove top.
SOURCE: maytag oven - error message
If you are receiving the SAb code your range is in the sabbath mode. I don't know what this means but it is really easy to fix. Press and hold the clock button for 5 seconds. The code will flash, let go and it is reset.
Posted on Mar 13, 2009
buffalonyman
  • 1865 Answers
SOURCE: I have a Maytag Gemini double oven with a gas
18" is standard
Posted on Apr 16, 2009
  • 42 Answers
SOURCE: Gas stove works, but oven does not
A gas oven will have some built in safety devices. Assuming that you have an electric pilot light sparking device, anything in the pilot light circuit could cause your problem
The oven does not "want" to turn the gas on unless there is an operating pilot system.
Since you never smell gas, but gas is available, then something in the pilot light circuit sounds like the culprit.
It could be as simple as carbon build up on the igniter or an internal fusing mechanism.
If you can get into the oven to the igniter, you could try cleaning the unit with a plastic scrunge.
I'm going to guess that this is not going to respond well to 'home grown' measures and that it will require replacement of parts.
Perhaps it is time to bite the bullet and call in repair......
good luck
Posted on May 20, 2009
heatman101
  • 43501 Answers
SOURCE: Maytag oven doesn't fire, but stovetop burners work fine
This will sound crazy but I had to work through it on my own stove a few years ago. The ignitor (glow tube) was getting hot but the oven would not owrk. When investigating the problem I found that the gas valve will only open when the ignitor pulls a specific amperage or draw of current. As the ignitor ages it pu;;s a reduced draw of current. This causes you to be fooled by the glow nut no gas. Replace your ignitor and your oven will begin to work again!
You can get ignitors easily online by doing a search for "appliance parts" and then entering the model number of your stove. Look for ignitor and you will be good to go. Also check out a few different sites as the prices of the parts can vary quite a bit.
Posted on Nov 20, 2009
Testimonial: "Thank you very much for your help. I was looking for a thermocouple but that must be old school. I couldn't figure out what told gas to flow."
heatman101
  • 43501 Answers
SOURCE: maytag oven wont bake. stove and broiler work and
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Nov 21, 2010
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from forum.appliancepartspros.com
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
No flame
when this happens it is usually because of a faulty flame/gas safety valve.
Sep 08, 2008 | Amana AOGD2750 Gas Double Oven
Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
Aug 31, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana oven does not work.
the most likly problem is the bake ignitor is bad. this is a common part to fail in gas ovens. the bake ignitor part number for your model is 31940001, and price ranges from $45-$75. a bad clock can also cause this issue, but I would start with the ignitor. let me know if you have further questions. shane
Jun 29, 2009 | Amana ARGS7650SS Gas Kitchen Range
I have a an AMANA gas stove burners work but oven doesn't
First check the book to see if you have a igniter on this stove if so it takes a moment or two to get started, if not you need to light pilot
make sure gas is getting to burner when called for by the thermostat or oven control..
Jun 11, 2009 | Ovens
Amana gas range trouble with starting
not a sensor, but more likely a bad oven ignitor(glow bar) its located under the ovne floor and mounted to the side ofthe bake bar. simple emough to unscrew and unplug, replacethepart yourself
Mar 18, 2009 | Amana ARGS7650SS Gas Kitchen Range
Blue flames on top of stove now more yellow than red
Have it checked out by a QUALIFIED gas person!! Don't screw around with gas unless you want to wake up dead due to carbon monoxide poisoning or an explosion!!!! Gas is NOT a forgiving task-master.
Apr 02, 2017 | Amana AGR5715QDS Gas Kitchen Range
Oven not lighting on Amana model agds902ss
Helloemauldin Welcome to Fixya
My name is Huum,
When you turn the thermostat on your range on it sends 120 volts to the bake valve and ignitor. The bake valve and ignitor are wired in series and the ignitor draws all the current and heats up. As the ignitor heats its resistance changes and when it is cherry red the current switches to the gas valve and it opens. The amp draw on the ignitor needs to be 3.2-3.6 amps for the gas valve to open. The gas valve has gas to it at all times. The gas valve should open within 40 seconds after the ignitor starts to glow.
If the ignitor is glowing red and the gas valve doesn’t open the ignitor is usually the problem. Sometimes the ignitor will glow red but the resistance doesn’t change and the gas valve doesn’t draw the current.
This is not a do it your selfer!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 24, 2008 | Amana AGDS902SS Gas Kitchen Range
Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range Logo
52 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
