Question about Garmin nuvi 2555LMT
No voice command
Just got a reconditioned unit.I used the wake phrase "voice command" and nothing happened. Also no voice command App.
    Scholar:
  • 189 Answers
Try going to the settings menu and look for voice options. Usually there is a box that needs to be checked for the option to work.
Posted on Jul 12, 2014
Constant beeping in bluetooth, and will let me use voice command to call but not text.
Cathy
This headset doesn't work natively for voice dictation unless you initiate listing via your phone. There are specific headsets that do facilitate voice to text but it is specific headsets with certain phones and may require an additional app.
https://motorola-global-portal.custhelp.com/app/answers/prod_answer_detail/a_id/71063 https://motorola-global-portal.custhelp.com/app/answers/prod_answer_detail/a_id/71063
Dec 29, 2014 | Motorola Mobility Hx550 Bluetooth Headset...
How to use voice dialer (svoice) with bluetooth on galaxy s5
Corded headsets do not have Bluetooth. Do you have a Bluetooth headset (wireless) handy to test the Bluetooth function properly?
Nov 04, 2014 | Samsung Galaxy S5
Why does my Jabra freeway voice HFS100 voice command only works about 1 in 10 tries
Delete the coupling and re-couple again waiting that all the services for the AUDIO DEVICE are added.
May 20, 2014 | Jabra Freeway Hfs100 Universal Bluetooth...
How to execute voice command
right upside corner key is to be used as execute voice command....
Jan 10, 2012 | Nokia C5 Cell Phone
Good afternoon, I search a french instructions for Micro Pets tomy "Gork " Serie 2 U.S . I have forget my instructions list :/ Please help me. Thank you
If you have a brand-new MicroPet, remove the"Try Me" plastic strip before using the pet.Turn the MicroPet over and locate the plastic strip protruding from the batterycover; pull the strip straight out.
    • 2
Change the batteriesif the power is running low -- the included batteries are used for testing andmay not be fully charged. Turn the MicroPet over and use a Phillips-headscrewdriver to remove the screw at the top of the battery cover. Slide thebattery cover out and remove the old batteries. Insert two LR44 batteries,making sure to match the polarity as instructed. Replace the battery cover andtighten the screw with the screwdriver.
    • 3
Wake up your MicroPet by pressing the button onits head; it will perform an action to let you know it is awake. Say a phraseto your MicroPet, then wait for its nose or tie to light up. Now say a secondphrase and the MicroPet will follow your command. For example, say,"Robo," then wait for the pet's nose to light up, then say,"Run," and the MicroPet will run.
    • 4
MicroPets display two "moods,""happy" and "bad," depending on the commands it receives.If you repeat the same command over and over, your MicroPet will display a"bad" mood. It will then refuse to listen to your commands and willnot respond to you. Praise yourpetto cheer it up and make it happy. For example, say, "Good job," toyour MicroPet.
    • 5
Press the button on top of the pet's head while itis performing a command to reset the MicroPet.
    • 6
Hold down the button on the top of your MicroPet'shead for three seconds to make it go to sleep; it will sing a goodbye songbefore shutting down.
    • 7
Make your MicroPet sing one of three songs byclapping your hands. Clap three times for "It's a Small World," fourtimes for "Ten Little Indians" and five times for "ElectricalParade." Make sure to wait for the pet's nose to light up between eachclap. Place multiple MicroPets together and they will sing in unison.
    • 8
To program your MicroPet, turn the MicroPet off,then press the button on top of its head six times --- the pet will light up,then make three small beeping noises. Wait one second and the pet will light up--- press the pet's head button now if you want to program the "GoForward" command. To program the "Turn Right" command, wait forthe pet to light up twice, then press the head button. To program the"Turn Left" command, wait for the pet to light up three times, thenpress the head button. When you hear three beeping sounds, the MicroPet isfinished programming and will perform the commands. You can program up to fivecommands in a row. When in program mode, your pet will not respond to your voicecommands or sing songs. To go back to the normal command mode, simply turn theMicroPet off then back on.
Feb 18, 2011 | Tomy Micropets Tomy - Kuda. Magic voice...
T-Mobile Dash Voicecommand: What keyboard keys map to the "app1" through "app6" keys in the Voicecommand application?
The key to use for voice commands is the HOME BUTTON. This is the button that has the shape of a house on it, to the right of the green send key. Set the app to none or app 1, and it should work. It has only worked a few times for me though; it is kind of confusing. So, good luck. Also, there is an online voice command help. Go to voice command, click menu, click help.
Feb 10, 2011 | T-Mobile Dash Smartphone
How to activate voice command 3760t
Page 19 of your manual:
Activating Voice Command
Speak your wakeup phrase. The Voice Command menu appears.
Setting your Wakeup Phrase
The wakeup phrase is a word or phrase you can say to activate voice command. The default wakeup phrase is "Voice Command".
1. From main menu, touch Tools > Voice Command > Customize Phrase.
2. Enter a new wakeup phrase.
3. Touch "Done"
If this solves your posted problem, please come back and rate our answer. Thankyou.
Nov 05, 2010 | Garmin GPS
I have a garmin 3970t and the voice command does not work
The Garmin's not very good at recognising the default set phrase to initial voice command; i.e. "Voice Command". If you bring up the Tools menu, and touch Voice Command, it will tell you what phrase it's expecting to hear and provide a button to touch to customise it. The default, as I said, is "voice command", but for some reason, it thinks it's pronounced something like "Vwuss commont". Try it. It might work!
I changed my voice command phrase to "Voys Commarnd" (I'm English - it's how my accent would be written phonetically). It now works most of the time without a problem.
Aug 12, 2010 | Garmin GPS
How do you turn the voice command NUANCE off?
Go to MENU, SETTINGS AND TOOLS, SOUNDS SETTINGS, READOUT, then select FLIP OPEN AND TALK, turn it off.
Oct 02, 2009 | Samsung Smooth SCH-u350 Cell Phone
Voice command times out -won't work
If your phone has the voice capability's then you should be able to use it through your headset. If this was a plan you were using before a free app where it could be commanded by voice maybe it is over. However if your headset simply is not working I would try to return it the retail place of purchase if it is still under warranty, if not you can always talk to Plantronics tech at 800-544-4660.
Good luck from Headsets Direct!
Sep 16, 2009 | Plantronics Explorer 330 Headset
Garmin nuvi 2555LMT Logo
110 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
