Question about Toro Garden
Toro diagrams48cmself drive
More deck finned plate which hangs down under the front of mower
    Guru:
  • 145 Answers
Exhaust (muffler)cover?
Posted on Apr 13, 2014
  • 72 Answers
SOURCE: Mower Deck not level
there is a geared bolt at the deck suspension un lock it and rotate it will raise and lower the deck
Posted on Aug 04, 2009
rwvanlue
  • 486 Answers
SOURCE: Stuck pull cord on Toro 6.5 self-propelled mower
1) Common problem when a mower sits for several weeks at a time between mowing;
check for extra grass debris to be glogged between the blade and the mower shell.
2) If the mower has a 'bail' or 'zone' control handle;
this releases a brake mechanism on the flywheel to allow it to rotate, and after it is running, releasing the lever will 'kill' the engine.
NOTE* when transporting a push mower in the trunk of a car, try to keep the mower as level as possible.
*extra note when mower has been transported in the back of a car;
sometimes the mower is placed in a trunk at such a severe angle that the oil from the crankcase is forced around the rings and sits on top of the piston so that when you try to pull the rope you have a 'hydra' lock. (that is when a liquid is between the piston and the spark plug) You cannot compress a liquid, so the rope appears stuck.
If this happens, remove the spark plug (make sure the loose plug wire is fastened away from any combustable that comes out of the spark plug hole *** AND THERE WILL BE A HUGE STREAM OF OIL AND GASOLINE, SO BE PREPARED TO CLEAN UP A MESS ***
pull as normal until fluid is dispelled from internal engine
clean or replace the spark plug
a few more pulls (no choke required) and you are up and going
Posted on Nov 08, 2009
  • 248 Answers
SOURCE: why is my toro lawn tractor eating mower deck
most likely possibility is a bad pulley
Posted on Oct 06, 2010
  • 6468 Answers
SOURCE: front wheels do not move on self propelled lawn mower
check the cable at the front gear box
Posted on Mar 25, 2012
  • 6468 Answers
SOURCE: how to replace drive belt on self propelled toro commercial push mower
the should be a plastic cover under the engine
Posted on Mar 29, 2012
How to mount or install mowing deck
Remove special bolts by front engine pulley then slide deck under mower. Take each lever that hangs down, they have a round part on the bottom slide into holes on deck from inside to out.Put washer over round part and then put clip into each hole. Take belt and slide over front pulley. 're install special bolts by pulley
Jul 02, 2015 | Mtd Garden
How do I remove mower deck on Toro riding mower 1986
First put the front on a jack stand on high. then lower the deck all the way down. Look at the three places on each side to remove the pins that hold the deck on Then there should be two in the front of the deck, remove them. Remove the belt from the motor pully. Lower the mower to the ground and release the peices the pins were in. Remove the clip from the tension cable and remove the cable from the deck. Raise the mover to pull out the deck. Reverse to instal
I hope I helped you
Oct 04, 2014 | Toro Garden
310-8 wheelhorse
Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual.
Jun 07, 2012 | Toro Garden
I need to replace the belt for the mower deck of riding mower. Need schematics. Model #78260 serial #4900572
Aug 27, 2011 | Toro Garden
Toro wheel horse rider recycler 8hp-25inch cut model#56132 how to remove mower deck
Apr 30, 2011 | Toro Garden
Grass cutting blowing out from in front of mower deck.
Dull or bent blades can cause this. Make sure that the grass is not built up under the mowing deck. You can purchase new blades at a Toro dealer like www.arcolawn.com.
tell them Joe from Fixya sent you!
Feb 12, 2011 | Toro LX466 22HP Lawn Tractor 13RT61RH244
Where is the model/serial numbers found on a toro self-propelled lawn mower found?
On the rear of the deck, usually under the black plastic shield. Lift the shield (like you were putting on the bag) you should find a white sticker with black lettering. The model number is 5 digits. If it is a commercial type model, sometimes they hide the sticker behind the handle name plate.
Good luck
Sep 10, 2010 | Toro Lawn Mower With Toro Power Tools
Where is the model number on the frame of a toro recycler lawn mower?
Toro model plates are white stickers with black lettering. On rear bagging models it is usually under the rear bag flap to the left of the discharge area. On side bag and commercial type units it is frequently on the underside of the plate that is just below where you hold the handle while mowing. On older recycler mowers it was on top of the left rear portion of the deck and usually fell off before the mower was very old.
Aug 25, 2010 | Toro Garden
I have a Toro LX466 riding mower. The drive belt
How to replace the drive belt on a Toro LX466 Lawn Tractor
1. Jack up the front of the mower-place a couple of blocks under the front wheels (retaining wall blocks from your flower bed work great). Block the back wheels so the mower won't roll off the front blocks.
  1. Remove the battery and battery compartment from under the seat. You can now see the cooling fan blade under the seat. The belt runs from the pulley directly under the fan to the front of the tractor.
  2. Lower the mower deck to its lowest position. Remove the deck hanger rod from the slots in the front of the mower deck.
  3. Remove the metal rod guard below the engine pulley. It's held in place on one side with a bolt, and the other side with a cotter pin.
  4. Take a large pair of channel lock pliers (about 18 in long work great) and clamp them down directly on the engine pulley, but not so tightly you distort the pulley.
  5. Remove the bolt from the pulley. It's a right-handed bolt, so turn it counter-clockwise to remove.
  6. Slide the pulley down the shaft until you can work the belt off. If the belt is too tight, then remove the spring from the idler pulley under the tractor. It's hooked on a bolt near the side of the tractor. You can remove it by grabbing the end of the spring with a pair of needle-nose vise-grips and slipping the end off the bolt. Then remove the old belt from the tractor.
  7. Take a new belt (preferably Kevlar) and start at the back of the tractor (with the pulley under the cooling fan) and thread it through to the front of the tractor. The flat side of the belt rests against the idler pulley with the flat sides.
  8. Work the belt over the engine pulley and slide it back on the shaft. Tighten the bolt on the engine pulley hand tight. Then check the belt to make sure it hasn't slipped out of the groove on the cooling fan pulley.
  9. Clamp the engine pulley with the channel lock pliers and tighten the bolt.
  10. Make sure the belt is routed correctly on the idler pulleys. If you had to remove the spring on the idler pulley, replace it. You can do this by grabbing it with the needle-nose vise-grips and placing it on the bolt-make sure it's above the washer. Then remove the vise-grips and gently pry it over with a small screwdriver until it slips into place.
  11. Replace the metal guard below the engine pulley. Hook the mower deck back onto the deck hanger. Replace the battery compartment and battery. Unblock the mower.
Jun 15, 2010 | Toro LX466 22HP Lawn Tractor 13RT61RH244
Garden Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
