Question about Oreck VersaVac Bagless Vacuum / Steam Mop
No suction i have cleaned ALL the filters in my versavac, and cleared the hold from the bottom and the side, there is something stuck in the middle, and i can't get to it. i've taken out all the screws and the covers still won't come off? help!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
Take apart. Run all hosing through high pressure water or air compressor.
Posted on May 06, 2014
No suction
The hose is clogged up. Try disconnecting the hose and loosen the clog. If you try to pick up pine needles, they are sticky and will clog up any vacuum sweeper.
Nov 23, 2013 | Oreck Vacuum. Versavac Bagless and Steam...
It doesn't have any suction power. What do I look at first?
first you will need to look at the filters the filter on the right hand side of the unit is washable and can be cleaned the filter under the bin should be replaced every 6 months, if this does not improve then remove the bin assy from the unit and open the flap at the bottom and with a torch look down the middle of the cyclone you may find a blockage,also under the the cleaner head itself take a look at the clear hose as this may have a split of may even have fallen off hope this helps
Nov 01, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I recently cleaned all the filters in my Bissell powerforce, now instead of suction I get all blown back instead.
take all the filters out put the dirt cup back in then try it again.3 filters 1 on the bottom of the dirt cup and one above the dirt cup and one in front at the bottom behind the little door.if thats not it at the bottom on the right side you will see a clear hose thats your intake hose,one screw holds it on,take it out and bend a coat hanger so the tip is rounded ,then work it down into the clear hose ,you should be able to push the clog out through the bottom
Apr 28, 2009 | Bissell 6594 PowerForce Bagless Upright...
No suction. filter and hose clear. motor high pitch. don't know how to remove cover to check motor.
something is clogged somewhere start from bottom and foolow suction path all the way through. wht kind of vacuum?
Apr 14, 2009 | Vacuums
No suction
Ok first thing to do is remove & clean the 2 piece premotor filter or purchase new.
Now remove soleplate from bottom of machine to do this rotate the 3 plastic screws to unlock position. Lift sole plate off now remove any blockagers or fluff that may be built up over the brush roller.
Remove hair from brush roll using scissors.
Check short clear hose for blockages & any damage rips or tares if it is damaged purchase new hose.
Now look at belts & rotate brush roller it should turn relatively easy if it is difficult to turn by hand remove the brush roller & pull off the end caps the axle will come out with one of the caps.
Check the roller bearings clean away dust build up replace end caps & axle spin roller holding on to end cap if freely to spin refit back on to machine.
If its stiff to rotate you will need new roller.
Now pull off the 2 inspection ports check them for bits of paper etc especialy the (U) shaped port at bottom rear of machine this can contain pens pencills stones all sorts of items that hinder the suction.
Now check the long flexi hose & metal wand for any obstructions.
If after all this machine is still not working correctly go to this site http://dysonmanuals.llc.nu/
On this site you will find Dyson service manuals covering poor suction, clutch,motor, etc.
Chris...
Sep 24, 2008 | Dyson DC07 All Floors Bagless Upright...
Oreck VersaVac Bagless Vacuum / Steam Mop Logo
140 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
