Question about Promise Pegasus R6 12TB RAID System (H5187VCA
3 of 6 drives on Pegasus R6 (12TB) Array show offline
Three bottom drives on 6 array deck show offline, do not believe it is a HD or controller problem, but rather something I can do to get them back on line and not lose data.
  • 20 Answers
If this is a RAID 5 and the data is of any importance I would definitely suggest consulting an expert. RAID can be tricky. Read some precautions here :Best Way to Recover Failed RAID 5 Array Quickly and Affordably Proceed with caution, I cannot tell you how many times failed attempts have come into our office making things next to impossible to actually recover the data.
Posted on May 21, 2014
Hp 6400 array controller don't post
Hi ,,
did you tried the offline diagnostics tools (Array Diagnostic Tool) and check it .
Mar 17, 2013 | HP ProLiant ML370 G4 Server
Hi. We have a ML110 server with RAID 5 (4x250gb HD SATA) in a Adaptec 2610SA. The RAID has 2 Arrays (#00 Operating System and #01 Data). We have tried to replace a failed HD and since then the Windows...
Did you make sure that your hard drive has been made into a "dynamic volume" instead to the usual "simple volume"? It has to be "dynamic" before your can put it into a RAID configuration. You will have to use your RAID Controller to create a dynamic volume or to make the hard drive part of a dynamic volume.
Aug 04, 2010 | Adaptec 2610SA (0H2052) Serial ATA...
MY fdf12072S WAS WORKING FINE ON MY COMPAC BEFORE. bUT THE COMPUTER WAS GETTING SLOW AND SO AFTER REFORMATTING THE DESKTOP AND REINSTALLING SOME OF THE VARIOUS SOFTWARES I WAS ASET TO TRANFER THE...
did you change operating systems? windows doesnt recognize EXT2 formats there may be an issue there.
was the other drive part of a raid array before the retooling? if it was part of a raid array you may need to rebuild the array before accessing the files.
next insure there are no special drivers required to access the drives nothing wierd like scsi interface or PCI card controller?
if there is no wierd issues try useing the setup disk as a boot disk drop to DOS and access the drive that way.
Jun 10, 2010 | Fantom Drives FDU12072S 120 GB Hard Drive
Not getting a drive letter from Compaq SCSI RAID setup
Did you see any new drives in the disk managemen screen? To get to the disk management, hold window key down and hit 'R', then type diskmgmt.msc and hit enter.
If you do see the drive in the lower half of the screen, you need to initialize the drive either as dynamic disk or basic disk. Then you need to add a new partition and format it.
Good luck.
Jul 04, 2009 | Compaq (128293B21) (128293-b21) SCSI...
Windows 2000 Professional will not format SuperTrak SX6000 array.
Update the BIOS of the card and the firmware... It might be bug!!!
Feb 23, 2009 | Promise Supertrak SX6000 (p29sts600000000)...
Our 1600sc dell server is beeping continuosly.
Check the PowerEdge Raid Controller for parity problems. Sounds like the status on the physical volumes participating in a RAID array has been degraded.
Loud beeping from a drive is usually an indication that an invalid drive array member has resulted in a degraded logical volume.
If you were counting correctly, you had at least three drives - most likely participating in a RAID-5 setup. The array might have been rebuilt with one bad drive. But it sounds like you've got two corrupt physical volumes in the array. And that's not good.
Hope you've got a backup!
Jan 19, 2009 | Dell PowerEdge 1600SC Server
Fax machine is offline
what is a array sensor, i am a brother tech and never heard of an array sensor???????????????
Dec 30, 2008 | Brother IntelliFAX 5750e Laser Fax
Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
Dec 17, 2007 | Biostar P4M800-M7A Motherboard
Problem with new array.
Do you see your new disk in the "Disk Management" window? To get there go to "run", type "compmgmt.msc", then click disk management. If you do see the disks there, then you need to format the disk to a "basic" configuration. If your new disk/volume does not show up there, I would suggest a hard reset on your server whenever possible. I see this issue at times with Windows and newly added storage array logical drives.
Aug 31, 2007 | IBM Total Storage DS400 (13n1777) Fibre...
Promise Pegasus R6 12TB RAID System (H5187VCA Logo
98 people viewed this question
Top Promise Computers & Internet Experts
Gareth Cockram
Gareth Cockram
C. David Graves
Are you a Promise Computer and Internet Expert? Answer questions, earn points and help others
