Question about IDEAL Industries #61-085 Vol-Test Voltage Tester
IDEAL Industries #61-085 Vol-Test Voltage Tester does not work, what could be the problem?
This model does not have a battery, so I'm not sure as to why it would not work...
4 Suggested Answers
Healeyman
  • 1198 Answers
SOURCE: voltmeter trips GFCI
I think this is normal for a GFCI.
Posted on May 01, 2009
ToolBoxHero
  • 171 Answers
SOURCE: I cant find where the
The #61-085 does not have batteries. (It does not test for continuity) The #61-086 does have batteries.
1. Replace batteries when touching the leads together no longer lights the continuity LED or produces an audible sound. 2. Remove test leads from tester. 3. Loosen the encapsulated screw from the bottom of the case. 4. Remove battery cap. 5. Replace the batteries with (4) new 1.5V button-type batteries (IDEAL# 61-201, IEC #LR44, or NEOA# 1166A). 6. Replace battery cap and re-tighten the encapsulated screw.
Here is the link to the complete manual. http://www.idealindustries.com/media/pdfs/products/instructions/nd-3401-2_61-085-086_instructions.pdf
If you have any other questions, just ask. Don't forget to rate this answer.
Posted on Jan 11, 2011
  • 683 Answers
SOURCE: I purchased new batteries for
IDEAL 61-065 does not have continuity function and therefore does not need batteries. If you have different model (like 61-076) then check if leads are good first.
Posted on Dec 14, 2011
How do you replace the batteries
Staight from the manual:
• Remove test leads from tester.
• Loosen the encapsulated screw from the
bottom of the case.
• Remove battery cap.
• Replace the batteries with (4) new 1.5V
• Replace battery cap and re-tighten the
encapsulated screw.
Feb 10, 2011 | IDEAL Industries #61-085 Vol-Test Voltage...
Nesecito comprar un tester ideal No.61-076 presio y como lo actengo pleas
Tu puede comprar lo a Amazon.com:
http://www.amazon.com/Ideal-61-076-Vol-Con-Tester/dp/B000BVKUSA
Questa cincuenta y cinco dollars.
Buenas suerte!
Jan 19, 2011 | IDEAL Vol-Con Xl Voltage/Continuity Tester
I cant find where the batteries are located on my IDEAL voltage tester #61-085
Jan 10, 2011 | IDEAL Industries #61-085 Vol-Test Voltage...
How do u change the batteries On a vole-test xl
there is a small clip at the back push both side in at ounce and the back will come away
best of luck
merry christmas
Dec 07, 2010 | IDEAL Vol-Con Xl Voltage/Continuity Tester
DC testing
No, you can't use an Ideal 61-065 tester to test a car battery. It is only for 100 volts AC/DC to 600 volts AC/DC.
A meter like this will work:
http://www.a1components.com/itemdisplayn.aspx?item=11307
Actually, the easiest way to test a car battery without a meter is to turn on the lights. If the lights shine bright like they are supposed too for a minute or so, the battery is maintaining the correct voltage.
Feb 20, 2010 | IDEAL 61-065 Voltage Tester
Voltmeter trips GFCI
May 01, 2009 | IDEAL 61-086 Vol-Con XL Solenoid Voltage...
Usage Repair
the current reading on a tester is independent of the battery in the tester. The battery is there to provide a tiny amount of current so you can read the resistance on a circuit in ohms.
What probably happened is that the useage selector switch was in the wrong position when a measurement was made for voltage of other and being in the current position created a short and the current measurement circuit was burned out.
for more details, please follow up with questions/comments
Sincerely Loringh
Aug 27, 2008 | IDEAL Vol-Con Xl Voltage/Continuity Tester
IDEAL Industries #61-085 Vol-Test Voltage Tester Logo
75 people viewed this question
Top IDEAL Measuring Tools & Sensors Experts
Vuk B
Paul Sikkema
Paul Sikkema
Are you an IDEAL Measuring Tool and Sensor Expert? Answer questions, earn points and help others
