Question about D-Link DSB-C100 Webcam
My new cam destroyed the harddisk
My cam is USB 100K CAM-100...i just bought it and am using windows xp ...i tried to install it although i had a strong virus on my pc...but after it was installed it didn't work computer shut down n mi hard disk was completely destroyed...i bought a new hard disk..and am scared to try to install it again ..i don;t know if the problem was from it or from the virus
can you please help me
  • 556 Answers
Re: my new cam destroyed the harddisk
This is more of a corporate backup standard taht follows -- in my case used when the restoration was to occur 1/2 way around the world and I wanted to miminize problems. The question for you is can you restore the machine if the backup fails meaning you are willing to assume more risk concerning the backup.
Norton Ghost is a backup product that when I last used it allowed creation of backup CDs the first or last of which was self booting that could be used to restore your system as it was before the backup. This is an effective means of backing your entire computer up periodically to simplify recovery when you have issues like you have had. PS a backup such as this can be wortless if you do not know how to restore it and if possible have tested the restoration to a different machine (but similar) or a different drive placed in the same machine. Both of these strategies to test the backup and assure the restore may not be available to you but it is a greater risk not to have a tested restore procedure as well as testing the CD's to assure they will actually restore.
There are instances where manufacturer supplied software has had viruses. Generally as the CD's get older so do the viruses and it is more likely and up to date anti-virus program would catch them.
Downloads are also risky but one means to minimize that is to get downloads from the manufacturer's site instead of other sites.
SO if you have a tested backup and
your anti-virus is up to date and
your sources software to add to your machine is considered reliable, it would be reasonable to try again.
But this time you will be so much better off with the backup.
If you are interested you may be able to download files from the manufacturer here.
here are two links -- for DSB-C100 clear and white
they have driver links and manuals -- if you can match a manual you should be able to download your driver
DSB-C100 clear
DSB-C100 white
White does not seem to have drivers -- I would read the manual to assure they are needed.
Posted on Dec 24, 2007
0 characters
3 Points
I bought a new Microsoft life cam VX1000 web cam and wants to install but can't find the soft wear
What operating system do you used? Example windows xp? But try this link it might solved your problem:
Nov 15, 2010 | Microsoft LifeCam VX-1000 Webcam
USB d0es not recognize the web cam
just try to format your system and try to install the cd given for webcam
Jun 24, 2008 | Microsoft LifeCam VX-3000 Web Camera
I have problems with my hp web camara it freeze it a lot on messanger any help
If your web camera freezes check your Windows Device Manager and see if the hardware is recognized and installed properly. It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem. If the device is not recognized in Windows XP, it will be listed under Other Devices
In either case you can try to update the drivers. Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers. In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer. After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.
If the drivers and web cam software are correctly installed, and you still it freezes, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the web cam feature. If you have multiple devices that qualify for video, you might need to select your web cam device as the source for the web cam feature in that program. Some web cams and programs require additional software, although that should be installed with the web cam if things are right. But is does not harm to check if your Java, Flash and Quick time software are installed and up to date. But certainly check your DirectX software, since all video applications, including web cams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c – Windows Vista: DirectX 10).
Thank you !!
May 30, 2010 | HP EW192AA Webcam
Labtec webcam not working why i did every thing my computer not detecting this ****** i install all the posible drivers already i used window xp. I hate this man.
ok, uninstall all related drivers to this camera,
Now using the supplied disk install the camera software but please do not connect the camera YET, if the camera is already connected,
remove the camera and reboot,
so you installed the camera software now plug the usb camera in, it will now detect the install camera software and work.
Dec 05, 2009 | Labtec 961307-0914 Webcam
Yahoo instant messenger shuts down everytime I try to use web cam
The camera may not be compatible with Yahoo, Try a different service to use the cam on? if that to crashes then its something with the drivers.
Nov 25, 2008 | Microsoft LifeCam VX-6000 Webcam
Web cam drivers for model CS330
i want to download drivers for usb web cam oprating system is xp
May 15, 2008 | Intel Deluxe PC Camera CS330 Webcam
Philips SPC 1300NC not installing on windows xp
I don't install my webcam. Can you help me please ?
May 14, 2008 | Philips SPC 600NC Webcam
Veo stingray webcam
Normal 0 You need to go to the manufactures site and download the VISTA driver for the camera. Then follow the info below to install the program.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Oct 14, 2007 | Xirlink Promax Webcam
D-Link DSB-C100 Webcam Logo
78 people viewed this question
Top D-Link Webcams Experts
micky dee
Are you a D-Link Webcam Expert? Answer questions, earn points and help others
