Question about Kitchen Appliances - Others
When running hot water through taps the boiler ignites but cuts out repeatedly, the water never getting hot. occasionally it displays the code F14
When running hot water through the taps the boiler continuously ignites, cuts out, ignites, etc. the water is becomes warm for a minute or so at a time and then back to freezing cold. twice the boiler has displayed the code F14
  • 171 Answers
SOURCE: Plumbing - no cold water from cold water tap
Hi blondi_1452,
I'm Harvey the Master Plumber.
Your question is: Why would the cold line water be luke warm?
In 30 years I've seen this maybe 10 times. It is relatively rare. But each time it was a cross connection between the hot and cold water lines. It could be this fixture is close to the hot water heater or the cross cnnection is in a faucet or it is in the way the water lines are piped. Anyway I would have to closely inspect the system while running the water in the fixtures in different combinations. Once the cross is located the easiest fix at this point is installing a check valve at the right point. You might consider utilizing thr Repair Directory to find a repairman. Make sure he has solved this type of problem before.
Feel free to contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 14, 2008
  • 104 Answers
SOURCE: Combi Boiler - Running warm & then cold!? HELP!
mixing valve must be replaced
Posted on Nov 02, 2008
SOURCE: Vaillant boiler - heating OK, but no hot water.
Most likey problem is the diverter valve, not energising fully. This in turn will not move the little plastic lever arm that actuates the microswitch on the side, sending the signal to ignite.
You can buy a diaghram kit from most local plumb centres, you need to replace the diaghram and seals, don't forget the silicon grease to ensure the plunger doesnt stick. Kits less than a tenner.
You should have noticed before it stopped working completely the water had reduced in temperature before the weeks it failed.
To make sure it is a diverter valve fault, depress the microswitch if you can, when the hot water is flowing and hey presto the demand for hot water light should shine.
Posted on Apr 26, 2009
SOURCE: Baxi solo 3 70pf boiler problem
This happened to me and it was a rubber pipe inside had perished so it was detecting a loss of pressure. You can see it if you take the main cover off and also the front clipped on cover. Its at the top on the right. You need to replace it with heatproof pipe. Good luck!
Posted on Jan 05, 2010
SOURCE: My vokera linea ag plus domestic hot water cycles
I have the same problems, did you manage to get it fixed and what was wrong?
Posted on Mar 08, 2010
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
When i turn on the tap the water is cold for 2 minuets then comes hot
Is this a new problem? Is it just running the cold out of the pipes before the hot water shows up? Is it a on demand or tankless system?
Oct 12, 2014 | Water Heaters
Sime super 80.. Heating and hot water at the same time?
going off on a safety possible high temp unit needs service such a nozzle filter if oil or thermocouple if gas
Jun 16, 2017 | Water Heaters
Vaillant ecoMAX 828/2boiler goes on & off when running hot water!
water must be set at 3lts a min ,check diaphragm valve move when hot tap is on, check microswitch ,best of luck
Aug 09, 2009 | Water Heaters
Vaillant combi boiler problem
when the tap is turned on and the water light on the boiler doesn't this means the diverter valve is not operating it could be down to low water pressure in the house this can be checked at the cold tap in the kitchen. if there is plenty of pressure then it could be the diagphram in the diverter valve is worn or split. the diagphram is only a few pounds but it depends on the engineer you get as to how much money he wants to fit it.
the egg timer symbol (or two pyramids together) is an ignition indicator turn off and on again to see if it will fire with the tap running. reset the boiler with the lower right hand control knob.
Dec 31, 2008 | Heating & Cooling
Hi,i have a vaillant turbomax combi boiler,the radiator side is working well but when running hot tap the boiler kicks in for about 5 seconds ,hot water starts to flow then boiler cuts out,water runs cold...
Which turbomax, as there a two different models. The more modern one, with the brass CPL diverter valve, located at the front left of the boiler, was very prone sticking & jamming, this would restrict flow through the hot water circuit in the boiler, and cause cycling. Vaillant actually modified the diverter. You can identify, if it is the old type, as there is a very small hole in the middle of the diverter on the old ones, probable no more than 1mm-2mm wide. The modfied one, is much bigger approx 5mm wide. If old type, replace as this usally sorts the problem
Nov 23, 2008 | Heating & Cooling
Ideal c24
Hi Jurgie,
I'm Harvey, the Master Plumber,
Happy to render my assistance.
This is your problem!
When you are switching on the boiler it ignites for 8 to 10 seconds, then it cuts off and the lock out lamp comes on. Pressing the reset button or turning on the hot water tap has the same effect.
I need to get the make and model of your specific boiler to give you an accurate answer!
Waiting for your response.
Harvey, your Master Plumber.
Sep 07, 2008 | Bosch 1600P-NG Natural Gas AquaStar...
Kitchen Appliances - Others Logo
343 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
