Question about ViewSonic Optiquest Q9b 19" Flat Panel LCD Monitor
My screen is blacked out
View Sonis va902b
    Scholar:
  • 74 Answers
The first troubleshooting step for a blacked out screen is to try another screen on your computer. If the other screen works, than you have narrowed the problem to a faulty screen. If that is the case, than it's time for a new screen. If the different screen is still black, than there are several options to pursue. First of all if the screen never loads anything when you turn the computer on than this could be faulty graphics, either a bad video card, or faulty integrated graphics.
It can also be the the RAM, the memory modules that have failed. Or the hard drive just is not loading the operating system. Check and see if the fan(s) are moving, or can you here any beeps when the computer starts? It would be easier to diagnose this problem if you gave more details as to just what is happening.
Posted on Jun 18, 2009
VA902b monitor will flash on for half a second and then go black even though the light shows green. Didn't have any problems with the monitor until updates were automatically installed for windows....
The "sleep mode" is probably set too low.. or a "power saving" mode is set too cut off too quick..(sorry for the low information) .. I am at work on an Apple.. geeezzzz :(
Jun 06, 2017 | ViewSonic VA902B 19" LCD Monitor
My Viewsonic VA902b monitor screen turns black anddoesnotrespone
That is a problem of inbuilt display card it does not support to games. You have to open the system case and install AGP card in the AGP slot AGP card is available in any shop of computer your other problems will also solve
Mar 09, 2010 | ViewSonic VA902b 19" Monitor
I have a viewsonic va902b screen when I turn it on the picture flashes and wont stay on the screen, how do I fix it?
More likely to have bad caps in the power supply, that is the first place to check for bad caps with bulging top, it can also be bad inverter circuits, or bad lamps, open it up and post back what you see so we can guide you further, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 23, 2010 | ViewSonic VA902b 19" Monitor
When I turn on my ViewSonic VA902b it flashes the
The problem can be in the backlight inverter circuits, look fo bad caps with bulging tops, look to see if you do have 12vdc feeding the inverter circuits. See some examples of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 06, 2010 | ViewSonic VA902b 19" Monitor
I have a ViewSonic VA902b that will flash a good screen if I turn if off and on but otherwise just black. I traded it out with the monitor from another computer and it does the same thing on the other...
Hi.
To start test the problem on a different main outlet, if the socket or the network in the house is not well earthed you may get this problem.
The problem is given by an internal faulty component, probably a faulty capacitor.
When you unplug and plug back, the electrostatic charges in internal circuit will get drained, and this will compensate the fault.
The monitor must be tested at component level to find the fault.
Dec 09, 2009 | ViewSonic VA902b 19" Monitor
Monitor goes blank coming out of power save mode
I found this on the Internet...
"Press the "Input" button on your LCD monitor's front panel repeatedly at three- or four-second intervals until your monitor wakes up. If your monitor is set to an incorrect input mode, it won't receive a video signal. After you reset the monitor to the proper input mode, it will receive the signal and wake up automatically."
I have provided a Link with more info for you!
A
How to Get Your LCD Monitor Out of Sleep Mode
Dec 24, 2017 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
Everything is too big on the screen when I get on the internet
Try selecting a much higher resolution from the menu
1650x 1200 should be ok for a 19" or 1260x760 or something within those parameters
Please rate my help++++Thanks for using FIXYA
Oct 20, 2009 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
ViewSonic Monitor Flickers
Check your MAC's standby, power and screen saver settings
Nov 13, 2008 | ViewSonic VA902b 19" Monitor
Half screen is grabbaled
Igbalco,
Try replaced new cable or check your cable see if any pins a damaged. If it still the same...then your panel are damaged. Don't bother to replaced a panel...just buy a new one, it more cheaper. Have a nice day!
Sep 21, 2008 | ViewSonic VA902b 19" Monitor
ViewSonic Optiquest Q9b 19" Flat Panel LCD Monitor Logo
216 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
