Question about Filter Queen Majestic Canister Vacuum
Filter queen 360 wiring
Wiring diagram
5 Suggested Answers
SOURCE: Need a wiring diagram for a Filter Queen D31X
I need to make a filter
Posted on Feb 11, 2009
sawdust46694
  • 398 Answers
SOURCE: Loose wire in vacuum
http://www.filterqueen.com/contact-filterqueen-locate-distributor.html they will help you.
Posted on Aug 10, 2009
  • 430 Answers
SOURCE: I need a wiring diagram & detailed
Open the vac by removing 3 screws below the handle area and the long screw at the bottom of the cone. If the motor has been removed, you will have 2 motor leads , 2 power head socket leads, and 2 switch leads as well as the cord. Do not twist your wires first when pairing, twist with the wire nut ony and tape afterword as there is metal nearby in the housing area
1 side of the cord goes to the switch only. The opposite side of the switch will go to 1 of each of the motor and Socket. The remaining motor and socket leads pair with the remaining cord lead.
While you are in there change the round filter dic covering the front of the motor and you could change the foam/ felt wrap around the inside of the housing.
There is a insulating disc at the top of the motor to prevent shock between motor and screen. Do not remove it.
Posted on Sep 08, 2009
SOURCE: I need a wiring diagram for my filter queen
need to know how to fit spring in powerhead
Posted on Jan 24, 2010
The white wire from the plug came loose where does it go? Need to see diagram for wire.
It is the ground wire. If it broke off from the plug, replace the whole plug. There should be a place to attach the white wire to the third round prong on the new plug
Jun 02, 2015 | Filter Queen Majestic Canister Vacuum
On a filter queen 360 vaccum the electrical connection from the hose to the wand was loose and over time the electrical arcing burned up the female conector piece. Is there any way I can replace this...
I am having the same problem On a filter queen 360 vaccum the electrical connection from the hose to the wand was loose and over time the electrical arcing burned up the female conector piece. This sounds to me like a manufacturing problem. The arcing is a fire hazard. Why aren't these problems being fixed for free. When will the recall come out?
Feb 22, 2011 | Filter Queen Vacuums
Where can a person purchase parts to repair the hose of an filter queen majestic model 360.
If you live in Iowa call 888-637-4692 or 800-344-1840 for the the Service Center near you. or online at http://www.filterqueen.com/contact-filterqueen-locate-distributor.html
FQ Master
888-637-4692 in Iowa
Your Filter Queen Authorized Service Center
Mar 03, 2009 | Filter Queen Majestic Canister Vacuum
Motor
Filter ?Queen Majestic Canister Vacuum – Motor
Motor?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
If your Filter Queen Motor is out or not working, the customer can replace the motor if they are mechanically minded and mark the wires as they remove the old motor with the new motor or you can have it serviced by your local vacuum dealer in your area, you can pickup the motor @ a local vacuum cleaner dealer in you area by checking the yellow pages or to contact the Filter Queen factory listed below. It requires a new motor and a new gasket; the biggest problem would be the wiring of the new motor. The factory information is listed below:
http://www.filterqueen.com Filter Queen Canisters Vacuums
Health-Mor World Headquarters
13325 Darice Parkway, Unit A
Strongsville, Ohio 44149
1-440-846-7800 or email @ custserv@filterqueen.com
Apr 18, 2008 | Filter Queen Majestic Canister Vacuum
Filter Queen Majestic Canister Vacuum Logo
57 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
