Hi, I need to find the location of the low pressure AC port on a 1994 Lincoln Towncar...Need to recharge w/134a. Thx so much
    Sergeant:
  • 340 Answers
Follow the suction line from the compressor not hard to find.Tom
Posted on Jun 18, 2009
Location of low side a/c port 2003 lincoln ls v6
Todd, Low side A/C port, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2000 Lincoln LS AC Low pressure port Location
2005 Lincoln ls low pressure port
low side port 2003 lincoln ls v6 Google Search
Jul 28, 2016 | 2003 Lincoln LS
Location of ac low pressure port location 2004 chevorlet avalanch
Look back on the firewall for the two a/c lines. One is large and on is much smaller. The larger line is the low pressure line. Follow that line back to the compressor. The low pressure port will be on that line.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Sep 01, 2012 | 2004 Chevrolet Avalanche
How do i recharge the ac on a 2002 Lincoln Continental?
to charge car uses 134a freon, you get a can at parts store, can has a hose and gauge already on it. hose end only fits your low side suction port ,it slides on and snaps /holds in place,do as can instructions say, DONT OVER FILL 134A SYSTEM IS WORSE THEN UNDERCHARGE AND YOULL PAY ALOT MORE FOR OVERCHARGE TO GET REPAIRED THEN A JUST RECHARGE SERVICE.MOST OIL CHANGE SERVICE OFFER A/C RECHARGING,Me id go to someone that has ASE tech certified in AC
Aug 07, 2011 | 2002 Lincoln Continental
2000 Ford Escort - recharge port for AC
The low pressure service gauge port valve is located on the A/C manifold and tube. please rate, thx
Jul 07, 2009 | 1997 Ford Taurus
2004 Lincoln LS A/C Valve
In order to charge, you must locate the low pressure valve to install the refrigerant. The low pressure valve is between the compressor and the evaporator. Do not charge on the High Pressure side, The high pressure valve is between the compressor and the condenser. To locate the low pressure valve, follow the line that comes from the compressor and routes toward the firewall. The valve will be somewhere on that line. Do not overcharge. The amount of pressure that is needed on the low pressure side will depend on the ambient outside temperature.
Jun 21, 2009 | 2004 Lincoln Town Car
I am trying to locate my low pressure valve on my 2005 Lincoln LS V8 to charge my a/c with 134a
the charging port is down low near the ac compressor on the engine
May 16, 2009 | 2005 Lincoln LS
I need the location of the low pressure ac port 2001 lincoln ls v6
hi there,
commonly recharging port at low pressure is located at suction line of your ac system,on sample figure you can figure out recharging port.230e583.gif
May 07, 2009 | 2001 Lincoln LS
Looking to recharge air
AC ports caps are most offen blue in color, they have either a H (hi pressure) or L (low pressure) on the top. You want the one marked L
Apr 28, 2009 | 1999 Mitsubishi Montero Sport
1999 FORD TAURUS EVAP SERVICE PORT
The AC charge port is the on low pressure AC line (large line from compressor) near the firewall. Take care not to overcharge, there are other causes of no cooling like a stuck AC compressor cycling switch or a air temp control blend door motor malfunction, what is the issue u have? does the AC compressor run?
Mar 11, 2009 | 1997 Ford Taurus
1994 ford taurus body type 4s
go to auto zone and buy a 134 recharge kit follow the directions on the box, you will need to find to LOW side service port there are two ports with plastic caps on the ac lines you are looking for the one that is attached to a larger diameter ac line. the kit will ONLY FIT ON THIS FITTING so you dont have to worry, there is a label under the hood somewhere thats green and says how much 134a you should install be carefull wear safety googles and good luck, please rate -jeff
Jul 22, 2008 | 1994 Ford Taurus
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
