Question about Bypass Essentials pkh34 Immobilizer Override Honda/
My daughter is locked in her Acura and can't unlock the doors. If she puts the key into the ignition, the alarm goes off. What should she do?
  • Acura Master
  • 3,904 Answers
Well if this is an emergency then brake the window. If there is time the I would pop the hood and disconnect the negative on the battery for about 30 seconds, reconnect and try to unlock the doors.
Posted on Apr 13, 2014
1999 acura slx alarm
CAR ALARM ISSUES
It can be any of the car doors not got properly locked or the door is locked but the switch is not sensing the door locked. Open and close each door again properly.
Or else its problem with any of switch wiring getting in contact with alarm wiring causing it to happen.
And last thing alarm connections need to be inspected. It's getting short somewhere in between.
There are few help links with solutions, to troubleshoot these types of problems. I suggest going through these links.
Click the link below: ------
Volvo car alarm keeps going off for no reason
http://technoanswers.blogspot.in/2012/07/volvo-car-alarm-keeps-going-off-for-no.html
Alarm keeps going OFF
http://technoanswers.blogspot.in/2012/07/alarm-keeps-going-off.html
2009 Toyota Camry: Hood Switch causing Alarm to go OFF?
http://whatisbyme.blogspot.in/2012/04/2009-toyota-camry-hood-switch-causing.html
Ford Pickup Alarm will not disengage?
http://technoanswers.blogspot.com/2012/01/ford-pickup-alarm-will-not-disengage.html
Mitsubishi Diamante: Factory Security Alarm will not go Off
http://www.howtorepairguide.com/2012/11/mitsubishi-diamante-factory-security.html
Toyota Avalon Factory Alarm will go off?
http://repairhelpcenter.blogspot.com/2012/01/toyota-avalon-factory-alarm-will-go-off.html
Chevrolet Tahoe Hood open warning on dash and alarm sounds?
http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
These details will help.
Thanks.
Nov 28, 2012 | 1996 Acura SLX
Tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 | Televison & Video
I went to unlock the driver side door of my 91 acura legend and i guess i set factory alarm off.i do not have original key and my car wont start.. help p[lease!!!!!
The alarm must of activated , the alarm is controlled by the locks, go to passenger door and use the key to lock and then unlock the door, this will shut down alarm, you may have to use the passenger door to shut down alarm due to a bad switch in drivers door, this will allow you to start the car, you can also not lock door and alarm may not arm. let me know if the passenger door lock works, good day.
May 24, 2012 | 1991 Acura Legend
How do I turn off the door alarm on my 2002 Chrysler PT? When I put the key in and unlock the door, the alarm goes off and doesn't stop until I turn the ignition on.
this is a standard warning to tell you the keys are in the ignition to help prevent them from being locked inside. This is a factory alarm and cannot be turned off
Jul 26, 2011 | 2002 Chrysler PT Cruiser
The alarm on my 2003 acura tl randomly goes off once it has been set. Any cure?
Have you checkd your fuses & also there is a small plastic/rubber piece somewhere on the driverside door, either on the actual door or on the car frame itself that once u close the door, that peice tells the alarm that its ok to lock and arm. (i dunno if u noticed but u can manually lock ur car w/ ur keys in the ignition, running, only if driver door is closed, from any other door usung the lock button, but not if the driver door is open) If that peice n ur door is worn, eventually it will break causing u to have to use ur key to unlock ur car. BUT, doing that will not disarm the alarm only unlock ur car & it will sound every time & not stop until u pull the fuse to the horn & lights. i had to bring mine to a dealership to get it fixd bc I couldnt figure it out. Paid $300 for a $25 piece of plastic I could have changed myself. Hope this helps..... good luck.
Aug 23, 2009 | Acura TL Cars & Trucks
2000 Toyota Sienna Minivan car alarm goes off.
1. Start with key out of the ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into ignition (Do not turn) and pull it out.
3. Perform these steps within 40 seconds.
A. Using the power door lock switch on drivers door perform 5 lock/unlock cycles starting
with lock. Use an even pace and try to go about one cycle per second.
(1 cycle = 1 lock and 1 unlock.)
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Turn the ignition to ON (Do NOT Start) then back to OFF.
E. Remove the key from the ignition.
5. Within 3 seconds the power door locks should cycle automatically indicating successful entry
into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1 second.
B. Immediately after letting go of the lock and unlock buttons,
Press the lock button by itself and hold for 2 seconds. Within 3 seconds the door locks
should cycle once indicating successful programming. If the door locks don't cycle or
cycle twice, repeat steps A and B, your remote has not been accepted.
C. Repeat steps A and B in step 6 for each new transmitter.
7. Close drivers door.
Apr 25, 2009 | Chevrolet Malibu Cars & Trucks
1999 volkswagen passat car alarm factory installed system
Do you have a key fob? Unlock the car with that and you should be OK. My sons Elantra is the same way, you can only get in with the fob. I guess the car thinks it's being stolen otherwise. If you don't have a fob, I'm no help
Mar 28, 2009 | 1999 Volkswagen Passat
2002 ford explorer-alarm goes off in the middle of the night...no one around Alarm goes of whenever it wants to. I don't lock my doors, because when I unlock them the alarm goes off and will not stop even...
At one point the door was lock from the in side and then closed and then unlocked with alarm, try un-locking it from the drivers door, then from the in side push the un-lock button and then close the drivers door. U should have no problems with it, but they do say that putting the key in the ignition and then do what you would like starting it but don't and do it 2 times and then start it will tell the alarm that it is not stolen.
Do u know that key less entry code to your drivers door?
Let me know if you would like your code that is if you don't know where to look.
Nikki2913
Feb 01, 2009 | 1996 Ford Explorer
Alarm system keeps going off on 1991 Acura Legend. Disabled horn to keep from bother neighbors all night, but lights flash and drain battery. How do I diable the alarm system. Car repair guy says he...
I had same problem, when a door lock broke, the car thinks it has been broken into once the alarm goes off. Mine started going off randomly when this lock broke. You have to reset the alarm system, with my 1990 Acura it was reset finally by putting key in door lock and turning key back and forth 3X. In my car, it was OK to do the key in door lock cycle in the passenger side door lock, but Acura dealer told me not all Acuras will reset it via passenger side key cycling, some require driver door lock key cycling only. I was lucky since my driver side door lock was currently useless, that my car allowed it to be done by key cycle on pass. door lock. But try that and if it doesn't fix it, just call acura dealerships until someone tells you the right answer. In my situation it took 3 dealerships with 3 different answers until this was the right one for my 1990 Legend.
PS I was told you can't disable alarm since it is all integrated into the battery and starting system, but read on another post that someone disableld theirs by disconnecting the horn.
Jul 19, 2008 | 1990 Acura Legend
Bypass Essentials pkh34 Immobilizer Override Honda/ Logo
43 people viewed this question
Top Acura Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Randy Ohler
 TE5LA
TE5LA
Are you an Acura Vehicle Part and Accessory Expert? Answer questions, earn points and help others
