Question about Honda Garden
Ignition coil not working
This is a G50 Honda engine on a mid- tine tiller. I get an extremely weak spark when shorting the ht lead to earth but not enough at all when the plug is connected. Machine has not been run for 10 years but worked fine at last use. Has the coil insulating lacquer degraded inside it thus shorting out much of the windings? If so and not repairable where can I get another and is there a part number? Machine is 35 years old +. THanks
    Loyalty:
    Visited the website for 30 consecutive days.
  • Honda Master
  • 1,430 Answers
Sounds like coil is bad get a new one go to Honda Mower Parts you can find the right coil
Posted on Dec 31, 2017
Typus
  • 69 Answers
SOURCE: Roper tiller 26 inch front tine Pulley/belt diagram
I am not sure either, but I think that it would be alot cheeper to buy a new tiller, than to use your strenght fixing a old tiller that you didn't bother to keep the instructions for (no, I am not trying to be harsh. I am trying to be nice. and I am not sure about it coming with instructions, they usually do.)
29259605.jpgSorry, that is the closest picture that I can get.
Here is a link that may help. (IDK, because it is blocked where I am at.) http://www.google.com/aclk?sa=l&ai=CqcKEPGEMSvvXJJyotgeEiOyLB_jqoUWYtdrOBMib0rsYEAMoB1DU-N7X_P____8BYMmOo4qkpMQRoAGUt9H9A8gBAaoEIU_Q6ppHU85NtRLlGbCSz8M4YQ7k6yZkGAMPo_XJ9i4rSQ&num=3&sig=AGiWqtyvlB5FasgaU109ezFuPnc-65WzHg&q=http://www.fixya.com/support/roper%3Fcmpid%3DG3372595023
Posted on May 14, 2009
SOURCE: Honda FG100 Tiller - Tines wont move
I took the transmission apart and the gears were fine. The friction pads on the centrifugal clutch don't seem to make full contact with the drum. Does anyone know what the thickness of the friction pads are suppose to be? I used some belt dressing on the pads and got some movement on the tines. With no wear on the gears, I guess I'll be replacing the clutch.
Posted on May 24, 2009
  • 48 Answers
SOURCE: Tiller tines will not turn. Engine runs fine...
Well hopefully it's not the transmission, as sometimes these tend to go. Another common but cheaper repair are the two bearings where the tines connect to the unit.
MORE THAN LIKELY.. The bearing is located above the worm gear housing, the part connected to the tines beneath the guard. This removal can be somewhat frustrating but if you remove it and remove the engine flange you'll be able to manually spin the drive shaft and see if it's the worm gear housing/lower bearings or if it's the more likely bearing on the clutch drum or the clutch itself.
Posted on Apr 16, 2010
SOURCE: mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Posted on May 27, 2010
  • 10865 Answers
SOURCE: Honda Tiller revs and works for 30 seconds and then shuts down.
Hello. you have some gunk in the carburator. Get a can of starter fluid or carburator cleaner aerosol and a helper. Remove the air filter and start it up. Spray a little starter fluid into the air cleaner to keep it running for three or four minutes and the problem should clear. If it does not clear the carburator will have to be disassembled, cleaned and rebuilt. j.
Posted on Jun 16, 2010
The starter pull rope pulls hard the engine will not crank
does pulling the start rope turn the engine over . make sure the tine drive is disconnected
if yes , the motor is not seized but the tines could be
if the motor will not fire ( check spark plug for spark it could be the coil or a short to ground in the ignition on/off switch wire
Feb 22, 2016 | Garden
What do u do when spark is weak on Yamaha blaster
Check battery voltage, remove spark plug suppressor cap from HT lead and see if spark is good by holding lead in a gloved hand and placing the lead end near the engine. If spark good get a new suppressor cap. Check the plug shows a good spark in the new cap by holding the screw thread to the engine. Poor spark change spark plug. If you get a poor spark from the HT lead then get the ignition coil checked.
Oct 06, 2014 | Yamaha Motorcycles
1992 dodge d150 won't start getting fuel and spark
So many problems it could be. Bad plug leads, leads on wrong plugs, starter dragging tension down so plugs have weak spark, ignition timing is out? Low fuel pressure, weak compression due to worn bores or piston rings. Damp tension leads, coil, condenser or ballast pack weak. Distributor or rotor arm shorting to earth. You don't say it this happened overnight or vehicle hasn't started in quite a while. Did you do a repair or service the engine?
Jan 20, 2014 | Air Lift 1992 Dodge D150 Air Suspension...
Ignition mystery! 1994 GMC Suburban 2500 5.7 mtr. No spark to spark plugs. Have spark from coil to distributor. Have changed coil wire, cap, rotor, ignition module, and coil. have 12.5 volts going to...
I guess you could have the ignition analyzed on an oscilloscope. Maybe a tech could see something then.
I always heard the only gap was the spark plug gap-the rotor has no gap-are you sure you got the correct rotor? And does it touch the top distributor cap coil wire tower?
Let us know. It is a mystery worthy of a solution.
Sep 21, 2013 | Chevrolet Suburban 2500 Cars & Trucks
Car wont start but kicks over
Since you do have A fully charged battery and also you do receive fuel smell after crank start and the car wont start,either you do have an Ignition fault means not giving the spark,advice remove the spark plugs and check whether are wet with fuel,see whether are black,if so change them and before start check by leaving an HT lead off a spark and use one of the old ones connected to the HT lead and earthed to the engine,ask somebody to start the engine checking for any spark comes out. If yes then put the HT lead back to the new spark on the engine and try. If ther is not any spark,then you have to go backwards from the HT leads to distributor,Rotor Arm,Electronic igniter,Coil if is fitted,Fuse and relay. Good Luck.
May 28, 2013 | 1995 Jeep Grand Cherokee
My cr 80 is not geting spark what could be wrong
spark plug
ht cap
ht lead
coil
could be wires from ignition box
is the engine earthed to the battery
Feb 13, 2013 | 2005 Honda CR 85 R
Engine missing/ backfiring, no pulling power
Hi I am vortash sounds to me like an ignition lead short check that the leads on the pot are not sparking to earth effectively cutting off the spark to one cylinder ( electricity takes the shortest point to earth so wont reach the plug if sparking to the cylinder ) I think youll find if it was the Kick stand sensor it wouldnt even fire up .. ? check all your HT circuit for damp or damaged leads .. hope this is of help regrads Vortash
Jul 21, 2009 | 2003 Honda VTR 1000 F Firestorm
No power to the spark plugs
Check first the wire connections to your ignition unit. Are they properly plugged? If all wires are good, try to measure the voltage from one of the wires to the ignition unit while the ignition key is in "on" position. If there's no voltage, have someone check your ECM. If there's a good voltage reading, try replacing your ignition unit with a good one.
Jul 10, 2009 | 1994 Suzuki Sidekick
1999 yz 125 weak spark won't start
Not much info Smitty but if that weak spark is constant (ie:pulsing ) i would guess that the trigger coil is ok.I'd make a check on your ignition coil earths then do a couple of continuity tests on your coil primary and secondary , orange terminal to ground,orange terminal to ht lead ,if they check out ok according to service manual specs then i'd run continuity test on the source coil.....Hope this is helpful in someway ...Smittycat.......from Flabbycat
Apr 19, 2009 | 2003 Yamaha YZ 125
Garden Logo
57 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
