Question about Watches
How to change the face of the denacci interchangeable watch
2 Suggested Answers
escapement
  • 2334 Answers
SOURCE: Change ******** Anne Klein watch
Your watch comes with interchangeable bezels, not faces. Bezel is a ring or rectangle (depends what shape your watch has) surrounding a glass.
All bezels are mostly friction fitted,so, to remove your bezel you need to use a strong knife blade and press it between the bezel and the case. The bezel should lift up.
To get the bezel back you have to press it into place.
For changing the strap you have to turn watch upside down and using the knife or lug tool try to squeeze sprigbar end out of the watch lug. Sprinbar is the piece which holds a strap attached to watch. The end of springbar you will find exactly where the strap is attached to watch. Push it inwards and it must come out. The rest is like 2x2.
Good luck.
Posted on Dec 19, 2008
Changing batteries on a Casio G-Shock Cockpit watch
yes. wrong battery possibly...
395/399 = SR927SW/SR927W
The 395 is a lower power output but same voltage (1.5v). The power spike of shorting might have caused a spike in the watch electronics.. make sure they are right polarity too. These batteries are not high current items, but maintain their voltage over the 5+ year lifespan. The S and SW are basically interchangable except for the higher amerage output.
Jan 03, 2015 | Casio G-Shock G511-1AV Wrist Watch
How do i set the two faces of a rotary relelation watch
What happens when you pull out the button when viewing the white face?
May 26, 2014 | Rotary Revelation Reversible Black/White...
How to remove back to change battery in "My Wish" Collezioni watch. No notch for knife and won't screw off.
You should be able to pry it off, just follow this simple steps:
Locate a very small tab (or recessed area) on the edge of the back cover. Pull out the stem, which releases the back on some watches.Get a small flathead screwdriver it needs to be a thin inflexible tip. Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch. These steps are listed on wikihow:
http://www.wikihow.com/Pry-off-a-Watch-Backing-Without-Proper-Tools . You also could skip step 2 if it's a cheap quartz watch.
Feb 19, 2013 | Watches
Need instruction book for older model 2826
Try Googling (invicta)(2826)(manual) without parens.
Aug 22, 2017 | Watches
How to change the watch strap, resin type
One way to change a watch strap, is if you have any old watch straps you can use them. There should always be a bump by the actual clock. You should be able to manuever the watch out of the two small holes by using your fingers. You can then interchange watch straps!
Jul 14, 2011 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
How to set Denacci Sport watch? Do not have instruction sheet.
mcdevito75 here, BEST BET, visit the website, www.watchesreplica.net This should help.
Jul 12, 2010 | Watches
How do i remove face of interchangeable watch?
This is called BEZEL you want to lift off. Take watch case opener (or just a pocket knife), insert the blade between case and bezel, then carefully pry up bit by bit, going all around the case. Make sure you are pressing blade in while prying up the bezel. This will not let knife to slip and scratch the watch. Rate me, plz.
Feb 12, 2010 | Avalon Medana Goldtone with...
Good luck.
Dec 19, 2008 | Timex 1440 Nylon watch
Watch 3 dials inside face
so its a chrono watch i belive. well sometimes diffrent models require diffrent operations to set up the display.
Perhaps the manual can be found on the internet site of the watches brand.
Mar 17, 2008 | Watches
Indiana (IU) Fossil Kaleidoscope watch
It has two batteries.  The 2nd one is not obvious.
Jun 10, 2007 | Fossil Sport Washington State University...
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
