Question about Hobart DGC501 Stainless Steel Gas Single Oven
Where can I buy replacement parts like latch and handles,
Where can I buy replacement part?
  • 3,904 Answers
Any appliance store that deals with Hobart can get you what you need. You should also be able to go to the Hobart site and find what you need.
Posted on Apr 13, 2014
How do i refit the main oven door lock, i need a step by step guide or something?
Oven Door Latch (part #9761013) - How To Replace ...
? 4:32
https://www.youtube.com/watch?v=rbMZ8NgiKm8
Oct 31, 2012 - Uploaded by AppliancePartsPros
Buy the new Oven Door Latch 9761013 ... How to replace yourcooker hinges. - Duration: 8:50. how-2-repair.com 84,238 views. 8:50.
How To ReInstall Your Oven Door - YouTube
? 2:12
https://www.youtube.com/watch?v=EBhJk85mc1Q
Dec 28, 2010 - Uploaded by HavillFiles
Did you remove your oven door and now you can't get it back on? The manufacturers forget to tell you about locking the latches first! ... Oven Door Hinge (part #W10347466)-How To Replace - Duration: 9:25. ... Hygena / Whirlpool / Electrolux / Phillips ovencooker door removal (others with same hinge) ...
How To Replace an Oven Door Lock Assembly ' Repair ...
www.searspartsdirect.com/repair.../how-to-replace-an-oven-door-lock-as...
Main Menu; Recently Viewed ... This step-by-step range repair guide shows how toreplace the oven door lock motor assembly for a self-cleaning oven. The door lockmotor assembly locks the latch to keep the oven door shut during the ...
Jan 08, 2016 | Ovens
How do I lock door for self cleaning
Some ovens have a latch handle between the top of the door and the actual range top that you have to push sideways to lock. May also be a lock button you have to push in while moving the latch handle.
If you don't see the latch handle, The lock system may be the hidden type that should lock automatically when set to clean. Once the oven is set properly for clean, a motor will latch the door by itself. After the oven gets close to clean temperature, the latch gets locked out and the door will not open until the clean cycle is complete and oven cools down to normal room temperature again. This is a safety feature so you can't open the door while the oven is at clean temp (about 850 degrees). Hope this explains enough. If door never auto latches, could be a problem with the latch/lock system and motor.
Mar 29, 2015 | Ovens
Whirlpool rb270pxyb
no such thing. when it is NLA it is NLA.
Apr 18, 2014 | Kenmore Ovens
I moved the latch for my jtp15 ge oven and now it won't open. What do i do to move the latch back over?
The latches on this model oven have a very high failure rate. Once the latch fails it is permanent. To open the door you have to access the control panel to reach the door look. To do this first turn the power to the oven off at the service panel by turning the breaker off.
  • Step 1 Remove the three screws from the control panel. The control panel is on the outside of the oven, above the door handle. Pull the bottom of the control panel toward you, then lift it up. This action will release the control panel cover's tabs.
  • Step 2 The mechanism that operates the door latch during the self-cleaning cycle will be behind a smooth, square plate held in place with two screws. White, black and red wires, as well as a grounding wire, will be protruding from the face of the plate. These wires will be twisted together with other control panel wiring and covered with electrical wire caps.
  • Step 3 Remove the failed part by removing the caps and untwisting the wires. Using an appropriate wrench, extract any screws holding the plate in place. The cylindrical-shaped mechanism will be attached to and behind this plate.
  • Step 4 Visit a store or contact GE at (800) 626-2224 to acquire a replacement part. To reassemble, slide the new mechanism into where the old one was and reattach the plate with the screws. Reconnect the wires by twisting them together and replacing the electrical wire caps.
  • Step 5 Replace the control panel by slipping the top of the panel into its groove and angling the panel downward, dropping the tabs back into the slots. Replace the three screws.
  • Aug 14, 2010 | GE JTP15 Electric Single Oven
    Oven door will not latch
    STEP 1:Grasp the handle on the Whirlpool oven door and open it to the first position.This will be a 4-inch opening
    STEP 2: Place your hands on either side of the oven door
    STEP 3: Pick up the door from the first position gently.Keep lifting the oven door until the door is clear of the hinge.
    Thanks
    Jun 02, 2010 | Whirlpool GMC275PD Electric Double Oven
    Jenn-air model s176w-c oven
    You have a fault in the controller module. I suspect a bad power supply capacitor is feeding dirty voltage to the control electronics.
    Unplug the range, then open the control panel (usually you get into it from the back). Remove the control module (warning: handle it only by the edges to prevent damaging the circuitry with static electricity from your fingers). You may not have to disconnect everything at this point; you just need to see the component side. Look for any electrolytic capacitors that have a domed top instead of a flat top. Normal is flat top; domed capacitors are burned out. Also, if you see a smaller electrolytic capacitor that has obviously had its can enclosure pushed off the base, that would be bad. See the photo for a comparison of bad (marked with red boxes) vs. good capacitors.
    These capacitors are relatively inexpensive to replace, usually less than $1.50 US from on-line sources. I recommend using the Panasonic FR series as the most reliable replacements. It should be much cheaper to pay a TV technician to put in the parts than to buy a replacement controller. Note: if this is what you find, and you want to take the module out for service, first go to a computer parts store and beg an anti-static bag from them. Make sure it's big enough to hold the controller including the keypad (keypad connectors can be tricky; if you don't know how the latch on the connector works you can damage the connector or keypad cable, so leave it attached and let your technician worry about it). I don't have the service info for your model, so I wouldn't know what kind of latch it uses without seeing it. Again, handling the module only by the circuit board edges or whatever mounting frame it is in, place it in the antistatic bag for transport. DO NOT USE AN ORDINARY PLASTIC BAG; these generate static charges instead of protecting from them.
    Jul 10, 2017 | Jenn-Air Ovens
    Self cleaning oven won't unlock after cycle is complete
    Unplug it for about 30 minutes, plug it back in and see if it unlocks. If not, then the latch, interlocking microswitch or control board is faulty. Also look for any bad connections (make suer the power is off before you start wiggling connections).
    May 21, 2009 | Ovens
    Replacing a door handle/ latch on a Vulcan ET4
    how do i install door handles and locks on my 1988 s10 4/4 blazer 2 door
    May 18, 2009 | Ovens
    Trying to find out how to lock the door on the whirlpool designer
    The door latch mechanism is defective. It is self-latching.
    The door latch switch must be replaced.
    Feb 21, 2009 | Whirlpool RBS275PD Electric Single Oven
    Door won't open after self cleaning.
    it is locked the leaver has become detached from the door latch and even though the leaver moves the lock part doesn't have you tried it lately push in on the door and try to move the leaver if that doesn't work get a wire coat hanger make a Small hook and from the left hand side see if you can snag the hook and pull it over ive done that before theopen end of the hook should point up start just abve the door gasket about halfway over well i cant reamber which way the latch moves but im sure you can figure it out push slighty in on the door after you hook the latch but try to open it fist some have asensor that wont let the oven door open till its cool enough to be safe let me know
    Dec 31, 2007 | Ovens
    Hobart DGC501 Stainless Steel Gas Single Oven Logo
    53 people viewed this question
    Top Hobart Ovens Experts
    Dan Webster
    Dan Webster
    joneable
    Level 1 Expert
    Gil Shultz
    Are you a Hobart Oven Expert? Answer questions, earn points and help others
