Question about Toshiba Televison & Video
Maring sound at volume..20/21
How to balance sound on Toshiba tvs
  • Toshiba Master
  • 3,320 Answers
You may be amplifying the sound signal twice. What are you connecting the TV to?
Posted on Apr 13, 2014
Replace tv video card
FOLLOW this steps and fix it. God bless you
Perform some basic troubleshooting steps that apply to all TVs. These include checking the "Mute" button to see if it has been pressed, examining the L/R balance to ensure sound is coming from both speakers and checking the cable connections to auxiliary components such as the stereo system (which controls external speakers).
    • 2
Double-check the audio output jacks if you are using an S-video connection (a single round perforated jack) or component video connection (a trio of green, blue and red jacks). Those jacks only run the video signal to the RCA TV. In order to get an audio signal, you'll need to connect red and white RCA cables to their respective jacks on the TV.
    3 Check the back of the TV for a switch labeled "Int/Ext." It controls the sound input on some RCA TVs. If you don't have any separate speakers, the switch should be set to "Int."
      • 4
    Activate the sound set-up feature by pushing the "Menu" button and scrolling to the sound bar. (This option can usually be found only on RCA flat-screen and projection screen TVs.) The sound bar allows you to set the sound from mono to stereo, activate the surround sound features, adjust the sound for headphone use, set volume levels and activate preset sound levels for movies, sports, concerts, video games and other specific sorts of programming. If any of these settings don't match the configuration of your home theater system, it may cause problems with the sound. If you're confused about the options, select any settings that read "Normal" or "Automatic." That should set the RCA TV to factory standard audio settings.
      • 5
    Press the "Menu" button and scroll to the "Set-Up" option, then go to "Preferences." You'll see a bar on the menu marked "Maximum Volume." You can use that to limit how loud the TV can get, which can cause problems if you don't know it's been set. Move the arrow on the bar to reset the maximum volume, then hold down the "OK" button on the remote to hear what that volume sounds like. You can then listen to the TV as normal.
    Jul 20, 2013 | Sylvania Televison & Video
    I have a toshiba 26LV610U that has low volume. Most of the time I keep the volume at 40 - 50, but some DVD's are impossible to hear at max. Is there an internal volume adjustment that will amp up the...
    Tries tv menu Sound Setting adjustment.Tries all the setting to the max like treble,bass,balance and surround sound is on.This should help make the audio louder.
    Jun 10, 2011 | Toshiba MD19N1 19 in. TV/DVD Combo
    Toshiba VC-L2B Remote Control Sound volume bar is moving up and down, but there is no sound out of speaker.
    Check to make sure the wiring between the sound bar and your audio source is hooked up correctly. Check the source to see if it has it's own volume control. Many TVs require external speakers to be enabled in the "audio" section of your TV's "Settings" menu.
    May 04, 2011 | Toshiba VC-L2B Remote Control
    The volume level is low and schachy on one side of balance, most noticed in low volume, once the volume is increased greatly the balance comes back. if left in low volume the balance control on the bad...
    Hello,sounds as if its an older reciever and the control is simply dirty(dusty) . What i would recommend (if you can access it) is simply spraying contact cleaner into the control .Contact cleaner can be purchased at a radio shack or online ,just get a quick drying one and do it while its unplugged.
    Feb 14, 2011 | Audio Players & Recorders
    How to turn sound on phillips plasma 32 inch tv
    Hello
    I thinks that you want to tune your TVs sound parameters, and answers. As you know, when the TV is switched on it will display picture as well as sound, according to the volume level setting. If you want the qulality of sound much more better, by pressing Menu button and higlight the opton 'Sound'. As you select, there will be a 'tick' mark appears, indicating that sound option is selected. On to the right side, there will be Bass, Treble,and balance control displays. Use "Cursor Up" button to go box 'Bass", and increse or decrese Bass lavel as you likes. If you wants to adjust treble, use "Curser Right" button and do as previous to your taste. Come to the "Balance" option by using "Cursor Up or Dn' keys and set it to mid position. There will be indication for its mid position, and it should be in that position, so that you can hear sound from both speakers equally.
    All jumpings and adjustments can be done with 'CursorUp, CurserDn, CursorLeft, CurserRight' Ok.
    Oct 31, 2010 | Philips 32PT6441/37 32" TV
    The volume jumps up and down when i turn the volume up .also the balance tuns completely left on its own
    Years ago the volume and balance on amps were on seperate circuits. But these days they are on one. It sounds like this problem is all down to an IC in the pre-amp stage. If you trace the connection from the volume control to the PC board you will find this chip. If you come accross more than one, put the code numbers into Google and see what they do. If you see one the at deals with volume and balance, you have got the culprit!
    Sep 15, 2010 | Cambridge Audio Azur 840A Amplifier
    My a205-s6808 toshiba laptop right speaker sounds bad. its like a hushing sound everytime the bass plays. it sounded great and then one day it happened. this is my bestfriends birthday present last year...
    It may be as simple as the balance controls.
    You can get to these by selectin the volume control mixer and double checing that they are set to the middle
    NOTE these are not the main volume control ones but the smaller slder usually at the top or bottom of the mixer display depending on the sound mixer software used.
    If it is windows 7 then double click the speaker icon and select mixer
    now click on the speaker icon
    select levels
    at the right hand side are options for BALANCE and adjust as needed
    Windows XP is as follows
    ouble click on the volume control from the taskbar or sound options from control panel and the balance sliders are at the top above each volume control
    Aug 19, 2010 | Toshiba Computers & Internet
    Radio works. volume problems on drivers side front speaker
    It sounds like the problem is with the speaker, not with the radio
    Dec 04, 2009 | Cell Phones
    Acer speakers desktop
    ***For Windows XP***
    • Click on start > Control Panel > Sounds and Devices
    • The Window Below will appear :
    • Click on the Advance button and the volume options will appear
    • Adjust the balance on the master volume (Just Drag arrow to the middle)
    ***For Windows Vista***
    • Click on Start> Control Panel>Sound
    • Click / Highlight the speaker then click on Properties
    • Click on Levels tab
    • Click on Balance
    • Adjust Balance
    Nov 03, 2008 | Acer Aspire (AST180-US340B) PC Desktop
    Voice sound....when i play world of warcraft i cant voice chat with the other players in my group
    Welcome to FixYa
    Your Sound Panel must look just like the columns provided in red bellow:
    "Volume Control"
    "Balance" - Center
    "Volume" - Full
    "Mute All" - Not selected
    "Microphone"
    "Balance" - Center
    "Volume" - Full
    Thank you for using FixYa. Have a nice day.
    Jun 30, 2008 | Systemax Computers & Internet
    Televison & Video Logo
    12 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Henry  Thomas
    Henry Thomas
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
