Question about Toshiba Televison & Video
Sound/vibration sound dialogue mars if volume above 20/21
  • 115 Answers
Replace speaker with new one
Posted on Apr 13, 2014
  • Toshiba Master
  • 3,320 Answers
What is the max volume? Give us a reference point. Is 20/21 to low?
  • John Dakin
    John Dakin Apr 14, 2014
    21 is ok but would prefer higher im a little hard of hearing
  •  Mike M
    Mike M Apr 14, 2014
    Ok just read all your posts. Too many about the same issue. It sounds like you get distortion when the volume goes over 21. Since you have consistently failed to tell us a reference point, max speaker volume is XX, I 3would recommend getting a $40-$50 2.1 speaker system and connect it to your tv audio out.
The vibrate mode on my phone will not work
Go to phone app, dial the following number-
*#0*#
You will get a screen with following options (Not All)
Click on Vibrations as shown above. If the phone vibrates, then there is some issue with Settings or Software. Restart or Reset should help you. Of it doesn't vibrates, time to visit the service center.
How to Fix Vibrate not working on my phone
Good Luck :)
Sours- How to Fix Vibrate not working on my phone
Feb 20, 2016 | Samsung Galaxy S6 Edge
How can dialogue volume be increased?
You will need access to all of the program audio files from the CD. You can either use an external audio editor to adjust individual files to balance audio levels. Or, you can use iTunes. In iTunes when you burn a playlist to disc, there is an option you can check called 'Sound Check'. It does a decent job of adjusting volume levels of individual tracks to match more closely.
May 26, 2015 | Computers & Internet
Why can`t I get my iPhone 5 C to ring. It jusy vibrates
Check above the volume key, there should be a little switch. If it's orange, flick the switch so that it isn't. Other than that, try turning your volume up.
Jul 01, 2014 | Apple iPhone 3G
No ring for in coming call or text
You might want to restore the whole iphone or ,try these suggestions first: go to settings,then sound,then check to see if ALL sounds are set to on. If yes then press your volume button up and check to see if your sound is all the way up. If yes the last thing you want to do is check to see if your vibrate switch (on the side of the phone above the volume rocker) is set to vibrate. If you see the orange on the switch it is set to vibrate and will make no noise.
Sep 28, 2012 | Apple iPhone Smartphone
My television has static and a vibration when the volume is increased to about 20 and above
don't increase abouve 20 again because it can spoil the speaker vibrating
Sep 27, 2011 | Philips Televison & Video
I have no ringing sound on phone, i have gone to settings, ringtones & sounds, the ringer is on, vibrate is on, when i get a call it vibrates but those not ring. is there a ringing volume somewhere?
Welcome to FixYa!
Volume up your phone using the Volume Key on the left side of your phone.
  • A volume bar will appear on the screen.
  • Press the Volume Key until you reach the desired volume level.
  • Tap the ICON on the right to switch between VIBRATE and RING.
  • Make sure that it is in the RING mode.
Thank you for using FixYa.
Have a great day.
Jas247
Jun 04, 2011 | HTC 7 Mozart Cell Phone
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
Low Volume despite High setting on TV
HI I am having the same problem. tv sound is fine, then fades so that 50 is the only sound volume to hear the show. It happens intermittently. Did you get your's solved? thanks
Jul 06, 2010 | JVC AV-27050 TV
Vibrating sound
its the problem of audio ic in your tv main board that has to be replaced.the number of audio ic is 668ij .this has to be replaced from the main board as this ic has turned weak and near to end of its life.replace it.
Mar 11, 2009 | Samsung Televison & Video
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
