Question about Dell Latitude D820 Notebook
Bad ram or stuck keyboard how do you check - Dell Latitude D820 Notebook
    Problem Solver:
  • 23 Answers
What exactly is happening?
Posted on Apr 13, 2014
Had keyboard replaced,now powers up and screen blanks off
If the power button is located on the keyboard, then make sure the power button is not stuck. Cause when stuck, it switches off automatically after 4 seconds.
Or check if the RAM memory is properly inserted.
Sep 18, 2013 | Toshiba Satellite 1715XCDS Notebook
3 beeps power on
1 long, 1 short beep : System board problem
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
1 long, 3 short beeps: Enhanced Graphics Adapter (EGA)
3 long beeps : keyboard card
Keyboard is not connected properly Verify that the keyboard is connected properly to the computer by turning off your computer and then disconnecting and reconnecting the keyboard to the computer. Stuck key Ensure that there are no stuck keys on the keyboard. If all keys appear to be ok and you have a standard desktop computer with keyboard, turn the keyboard over and gently hit the back of the keyboard to loosen any dirt or hair that may be stuck in the keyboard. Bad keyboard Try another keyboard on the computer to verify that the keyboard has not gone bad. Bad PS/2 or AT port If all of the above solutions are not able to resolve your issue it is likely that the port on the back of the computer may be bad and the motherboard or I/O board may need to be replaced. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Make sure that your RAM modules and Cmos battery are securely seated on some motherboards Cmos batteries are soldered in Test all power and data leads that attach from motherboard to your hard drive IDE SATA make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40 pin ide it will be the first to fail Check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it Restart your computer the found new hardware wizard should activate a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function.
Feb 22, 2013 | HP Hewlett Packard Compaq D51S Intel...
3 short 1 long 2 short led error blink code on emachine intel board d101ggc
Verify that the keyboard is connected properly to the computer by turning off your computer and then disconnecting and reconnecting the keyboard to the computer. Stuck key Ensure that there are no stuck keys on the keyboard. If all keys appear to be ok and you have a standard desktop computer with keyboard, turn the keyboard over and gently hit the back of the keyboard to loosen any dirt or hair that may be stuck in the keyboard. Bad keyboard Try another keyboard on the computer to verify that the keyboard has not gone bad. Bad PS/2 or AT port If all of the above solutions are not able to resolve your issue it is likely that the port on the back of the computer may be bad and the motherboard or I/O board may need to be replaced. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules make sure that your RAM modules and Cmos battery are securely seated on some motherboards Cmos batteries are soldered in Test all power and data leads that attach from motherboard to your hard drive IDE SATA make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40 pin ide it will be the first to fail Check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it Restart your computer the found new hardware wizard should activate a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function.
Feb 17, 2013 | E-Machines eMachines Desktop PC
Emachies w3609 3 beep codes
Verify that the keyboard is connected properly to the computer by turning off your computer and then disconnecting and reconnecting the keyboard to the computer. Stuck key Ensure that there are no stuck keys on the keyboard. If all keys appear to be ok and you have a standard desktop computer with keyboard, turn the keyboard over and gently hit the back of the keyboard to loosen any dirt or hair that may be stuck in the keyboard. Bad keyboard Try another keyboard on the computer to verify that the keyboard has not gone bad. Bad PS/2 or AT port If all of the above solutions are not able to resolve your issue it is likely that the port on the back of the computer may be bad and the motherboard or I/O board may need to be replaced. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules make sure that your RAM modules and Cmos battery are securely seated on some motherboards Cmos batteries are soldered in Test all power and data leads that attach from motherboard to your hard drive IDE SATA make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40 pin ide it will be the first to fail check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it restart your computer the found new hardware wizard should activate a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function. Hope this helps.
Jan 04, 2013 | E-Machines W Computers & Internet
5250 beeps 3 times
Stuck key
Bad keyboard
Bad PS/2 or AT port
hope this helps
Oct 10, 2012 | eMachines Computers & Internet
Asrock 3 Beep Code k7vm2 Problems & Solutions
check the leads that attach motherboard to hard drive make sure they have secure dust free connections
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
verify that the keyboard is connected properly to the computer by turning off your computer and then disconnecting and reconnecting the keyboard to the computer
Bad keyboard
Bad PS/2 or AT port
hope this helps
Jun 20, 2012 | Asrock Computers & Internet
My son's acer 5738 laptop has a rapid beeping noise when turned on and the keyboard is locked? Can you recommend something? thx
Rapid beeping sometimes indicates a stuck key on the keyboard. check all the keys to see if something is jammed, or if a certain key is not as responsive as the others.
I the keys are not stuck or jammed, and if you are brave enough, remove the bottom pannel and see if you are able to remove the ram. Turn the system on without any ram installed and see if the rapid beeping still occurs.
If the rapid beeping stops with the ram removed, you may need to purchase a replacement.
Jan 17, 2010 | Computers & Internet
My laptop constantly beeps and will not recognise the keyboard
One of two things... bad or missing memory will cause beeping, but I assume if you know the keyboard is not responding then the PC has booted up. The other thing to check is a stuck key. Look and see if there is one key that appears to be depressed. If that does not reveal the bad key try rubbing your hand across the keyboard, pressing down on the keys as you move your hand across. As a last resort you might try tapping every key several times to release the stuck key.
Happy
Nov 08, 2009 | Toshiba Satellite A105 Notebook
I have one intel 845gvsr board for repair. The board is dead. When RAM is removed it gives memory error beeb i.e. 3 long beeps, but RAM is ok & cpu is also ok. When is installed the board does nothing. No...
Hi there
Three Long Beeps = Keyboard/Keyboard card error
An error with the keyboard can be caused by any of the below possibilities.
  1. Keyboard is not connected properly.
  2. Stuck key
  3. Bad keyboard
  4. Bad PS/2 or AT port
Solution:Keyboard is not connected properly
Stuck key
Ensure that there are no stuck keys on the keyboard. If all keys appear to be ok and you have a standard desktop computer with keyboard, attempt to turn keyboard over and gently hit the back of the keyboard to loosen any dirt or hair that may be stuck in the keyboard.
Bad keyboard
Bad PS/2 or AT port
Good luck and kind regards
Jan 05, 2009 | AOpen XC Cube MZ915M (95MZ1592Z1) Barebone
Continuous beeping sound
you can see out put in screen if no you must chek ram's
else you should remove your keyboard and mouse in test ather
Dec 16, 2007 | Packard Bell iMedia SL 9553 (P660401806)...
Dell Latitude D820 Notebook Logo
15 people viewed this question
Alun Cox
