Question about Brother MFC 210C All-In-One InkJet Printer
No colour I'm sure the nozzels are plugged .I was away for 4 months and the ink store owner said he hear's people having the same problem with brother printers. The ink dry's up.The black work's fine.
  • 832 Answers
Run a powerpurge:
press menu then start mono (b/w) then 4 times arrow-up button.
The machine displays maintenance and all button will flash.
press 7 then 6 : claening_all . Press 3: powerp_all press start mono. machine will run a power purge.
In case your are outside the US/CAN press 0 then 9 afterwards. Machine will print test sheet. If you are from US/CAN leave the maintenance mode by pressing 9 then 9 and run the printing manually by pressing ink etc.
You may have to run the power purge 3 times.
Posted on Nov 01, 2007
I have installed a new black and colour ink cartridge but it is only printing in black and blue- why is this?
Your printer head might be blook. For the reason all the colour of ink does not come out through the printer head nozzels. In this condition you should try to come out ink through ink nozzels. procedure
1. print a nozzel cheak. and see what colour does'nt come out.
2. Now open photoshop and take a a4 page and fill it with six colour and print it 5/6 time in a photo paper. If print does not improve call me again. I will give you second tecnique.
Thank you.
Sep 15, 2010 | Epson Stylus C46 InkJet Printer
BROTHER DCP-560CN Not printing enough yellow
This can happen to cartridges with attached print heads such as HP, Lexmark or Dell. All cartridges are weighed and tested before leaving the factory so lack of ink isn't the problem. It usually has to do with the print head of the cartridge not having any ink to feed it. This happens because cartridges are kept flat or upside down for weeks or months before being used and the ink settles away from the print head. The easiest remedy is to open the box and stand the cartridge upright for a few minutes before using. Then get a damp paper towel, fold it into quarters and sit the cartridge print head down onto it. Hold the cartridge down to the damp paper towel for three minutes. This will help pull the ink out of the print heads, priming them and getting them ready to print. Finally, install the cartridge into your printer and print a few test pages.
How can I get dried ink out of my inkjet print head so I can print again? Place the clogged cartridge in about 1/4 - 1/2 inch of warm water for a few minutes. When ink starts to slowly leak out take the cartridge out of the water and dry it using a soft cloth to "Q-tip." Then place it back in your printer and run the print head cleaning utility that comes with your printer software. You may have to run this 2-4 times before printing quality is reestablished. If your print head is destroyed, as can happen, you will have to buy a cartridge and refill that cartridge before it is fully empty
Feb 19, 2010 | Brother MFC 420CN All-In-One InkJet...
Brother Mfc-845cw and Mfc-465cn both stopped printing Black about the same time. Using Non brother Ink. Tried cleaning, replacing carts, unpluging maching. how can I fix this.
the black ink that was used in the refilled cartridges was probably to thick for the nozzels on the head, you can try buying the original cartridges and then cleaning again, or check with the store you got these cartridges from as some of them offer a warranty
Nov 20, 2009 | Brother MFC-465CN InkJet Printer
Ink tank empty display will not go away
Go into Brother printer control centre and bring up brother staus. Shows all the colour levels.
Next lift printer cover up and remove carefully the cartridge that is showing empty. replace carefully making sure it is all the way in. On the printer panel push INK MANAGEMENT. scroll through until you find clean. make sure cover is back down and press clean of the particular cartrige you are having a prolem with. ei BLACK press clean black. On the Brother status monitor on your PC you should now see that the black is full
Aug 04, 2008 | Office Equipment & Supplies
I have never used my printer to print with the colored ink just mainly the black and i just purchased my printer a few months ago now when i go to print it says i am out of ink
Hi
Most inkjet printers have a priming pump underneath where print head rests.
Each time you swich on the prnter the noise you hear is the priming pump sucking the ink, in the case of brother printers it is then deposited into a large sponge at the back of printer. Also cleaning the print head too often can empty your inks very fast!
Also when you print BLACK a fine film of another colour is usually printed first! then black over prints...
It is the reason many printers will refuse to work if you do not have all inks in place.
Hope it helps
Tinteiros (Ebay)
Jun 01, 2008 | Brother Office Equipment & Supplies
No Cartridge
i am sure this is the same problem as the 440cn. each cartridge has an optical window on it where the sensor measures the ink level. what u do is put a folded piece of paper over this window and reinsert the cartridge. this makes the sensor think that cartridge is full and should reset the ink meter. the printer should work fine.
Jan 30, 2008 | Brother MFC-665CW All-In-One InkJet...
Black ink not working; but colors are
press menu then start mono (blue copy button) then fourtimes arrow up (tel index). machine will be in maintenance mode. press 7 then 6 then 4 then start mono. machine will initialize the carts and do some cleaning cycles.
If you're outside can/us: after that press zero then nine. machine prints test print. If youre inside leave maintenance mode and run a test print manually.
if you cant see any bk the ph is clogged and cant be fixed anymore (because of wrong ink: pigmented ink will clogg the filter infront of the nozzels; use ONLY dye-ink for all colors!)
leaving the maintenance mode by pressing 9 then 9.
Nov 27, 2007 | Brother MFC 210C All-In-One InkJet Printer
Printing incorrect colouring
plz check the color carts: are they inserted at the right place? If not, change them into the right place. Run the cleaning cycle 4 times to get the wrong ink out of the tube and nozzels.
If you have them at the right places print a test print by pressing ink button and selecting the test print.
Does it look good or do still have the diffrent colors?
Nov 02, 2007 | Brother MFC 210C All-In-One InkJet Printer
Printer not printing
Unfortunately, like most multi cartridge ink jet printers when one ink is empty the printer will cease printing regardless of whether you just want to print in black and white and you have plenty of black ink left. I have heard of people tricking the printer into believing the cartridge is full by placing coloured tape etc in front of the ink sensing device but I am not sure how the Brother senses the ink levels as i have some aftermarket ink cartridges for mine which seem to be completely non-opaque (unlike the originals). The need to have colour cartridges in even if you only ever print with black ink is good news for Brother as the MFC-210c uses a large amount of ink during it's routine cleaning cycles (that you cant stop) and will empty all 3 cartridges in under 6 months without ever printer a single drop of colour ink. Sorry about all the bad news, at least your not alone......
Dec 28, 2006 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
