Question about Canon PIXMA iP1300 Printer
Margin Problem Of Cannon Pixma iP1300
When I am printing with Illustrator 11, it is not printing Boderless/Full Page . It is leaving some space in every side like a Margin does . How can I print a Full page or Borderless with any margin with Illustrator .
osram
  • 20 Answers
SOURCE: left side margin is fading out right side margin is printing correctly
First try to align the printer head either with software or at the printer control panel. If that one couldn't solve the problem then you may have the encoder strip dirty at left side. It is not easy to access the encoder strip, sent it to workshop.
Posted on May 12, 2008
Scott Ellin
  • 558 Answers
SOURCE: Left side of page cut off printing from Outlook 2003
Have you try to Copy paste the content of Outlook to Word and then try to print.
As Outlook have lesser option to set for printing. And may not possess all the features to print it correctly.
Let me know if I can assist you further.
Regards
Ellin
Posted on Sep 26, 2008
latcarf
SOURCE: MP600 with Mac OS X - no borderless printing option?
I had the same question. I found the answer at Canon's site but I can't link directly to the page so here's how I found the solution...
1. Go to the Canon Support site. 2. In the "Please enter your question field" type: How do I Print edge to edge? 3. Hit the "Search" button. 4. Click the #1 (top) search result "How do I Print edge to edge?" 5. Click the #1 (top) solution: "Use Borderless Printing (Mac OS X) MP600 6. Follow the directions.
It seems the main thing you need to do is go to the "Page Setup" dialog. Then make sure you've chosen the MP600 in the "Format for:" popup menu. Finally, in the "Paper Size:" popup, select "A4" then "A4 (borderless). It's a hierarchical menu.
FWIW I still haven't gotten a "perfect" borderless print. Seems you gotta get the paper in there exactly straight...
Posted on Mar 10, 2009
yammy_alf
  • 666 Answers
SOURCE: how do I fix canon mx310 which prints with lines
please check doc. page setup, may be outline or outside margin resulting not space.
Posted on Apr 15, 2010
  • 5227 Answers
SOURCE: Cannon PIXMA iP3000 (Waste ink absorber full)
The waste ink absorber is a pair of pads at the edges of the ink carriage path near the bottom of the printer. Canon will sell you a new set to replace them if you want to d-i-y. Alternatively, you can just rinse the pads until the water runs clean once you open up the printer. Dry the pads well before reinstalling. You need to take the printer apart from the top and get under the ink carriage.
Once you reinstall the pads, you can reset the counter by:
Pixma IP3000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
I hope this helps.
(most inkjets waste ink counters are set to hit their fill point at the expected end-of-life of the printer. Additional failures may happen soon.)
Posted on May 21, 2010
Testimonial: "Your information was wonderful. Thanks I can get a few more miles out of the old printer."
My cannon pixma ip1300 printer is not printing as it does not hold the paper in long enough it just go through without stopping i think it has something to do with the round spool underneath which effects...
Hello...here i what I would do..Start from the beginning...uninstalI the printer and the print drivers.....Shut down the computer....reconnect the printer to the computer....start the pc...It should see the device and ask for software....reload the drivers from the cd...when finished...try to print a test page....make sure the printer is Powered on when booting up the pc....I hpe this was helpful......let me know wht happens....PEACE........
Mar 01, 2012 | Canon PIXMA iP1300 Printer
I am trying to print a booklet 2 pages per sheet double sided. Printing is OK but spacing is no good for the binding when the pages are cut in two. What instructions should I give the printer to allow...
Hi
By spacing, I assume you mean the margins at the centre.
The default margin settings are not the same for the right and left hand side of the page, so the printing on the reverse side is offset from the printing on the first side.
The right margin is always wider to allow for punch holes in file paper.
It is not the printer settings you need to adjust, it is the page layout of your word processing software.
Adjust the margin settings manually. In MS Office 2007:
Page Layout > Margins > Mirrored Margins.
Hope this helps.
Aug 24, 2011 | Canon PIXMA MP610 InkJet Printer
My cannon ip1300 printer does not print correctly lines & fonts are not in correct way
Try installing the latest printer driver.
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :- http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Dec 27, 2010 | Canon PIXMA iP1300 Printer
How do I fix canon mx310 which prints with lines
Apr 15, 2010 | Canon PIXMA MX310 All-In-One Printer
I lose my cd installerr cannon ip1300
you can download a driver for your printer at
http://software.canon-europe.com/products/0010383.asp
Please rate this solution. Thanks.
Sep 07, 2009 | Canon PIXMA iP1300 Printer
HP PCS 750 cuts off bottom of 8 1/2 X 11 page when printing. Auto reduces page.I need 100%.
The PSC 750 cannot print a full borderless page, it requires a bottom margin of 0.46", a top margin of 0.08" and side margins of 0.25" when printing on 8.5x11 pages.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jul 04, 2008 | Office Equipment & Supplies
Canon PIXMA iP1300 Printer Logo
old marine
old marine
