Question about Dacor Ovens
Error message u22 over temp
Is this a problem that can be fixed temporarily till I bring a service man tomorrow. I'm having guests and I need to cook at this moment.. Help!
I was getting a small "0" error message on the display of my Miele dg 155 steam oven. Tried Descaling but the process didn't complete, stopped at 10 minutes (33 minutes total) and started...
GO TO SERVICE MODE. TURN OVEN OFF OPEN DOOR MOVE KNOWB COUNTER CLOCK WISE TO DEFROST PUSH TEMP BUTTON 3 TIMES PUSH + BUTTON TILL YOU REACH 67 CLOSE DOOR AND WAIT FIVE MINUTES VOILA......
Feb 26, 2011 | Miele DG155-1 Steam Oven Single
When using the oven I get an error message of F3E2. I was told to turn the power off at the breaker box by a Wirlpool associate and that should fix the problem, which it did but now its not heating to the...
A reset switch is what he is talking about. Turn power off at breaker for one minute if this does not rectify problem have a service tech come out. A local appliance guy is usually the cheapest and best route to take as the brand name guys are usually few and far between.
Oct 11, 2010 | Ovens
Samsung oven bf641fst displays -SE- How do you fix
According to the crappy manual:
-SE-
An error of the oven may cause low performance and problems in safety. Stop using oven immediately and call service man.
Means very little I know.
Jan 14, 2010 | Ovens
Frigidaire oven F-10 error
HI. this is a oven temp sensor failure notice. you will need to check the wires leading from the temp sensor to the control. if the wires are in good condition and , the sensor harness is not welded, replace the temp sensor asap.
May 24, 2009 | Frigidaire FGB24S5A Gas Single Oven
I have a Kenmore Elite slide in electric range and the oven will not preheat to temperature (even after 40 min.) The repair man says I need a new control panel that will cost me almost 500 bucks...Any...
Hi. the electronic oven control board actually costs 198.00 but, the labor charges will inflate the cost because of the need to disassemble and add new wire harnesses. On most models, this relay is separate from the actual control board and it is usually linked via, wires. I would check around to see if you could get a second and maybe a third opinion. In my experience, you should just be able to replace the temp sensor or relay and that should fix the issue. Normally, if the control board is experiencing any issues, you will see a error code of some sort. I would defiantly get a second or third opinion before allowing the service tech to do the repair. that repair cost seems to be highly inflated in my view.
Please rate and god bless:)
Apr 03, 2009 | Ovens
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
I have a self-cleaning oven and set it to clean for 1 1/2 hours. The light turned off at the end of the time but the "sound" made during cleaning didn't stop. When I followed the procedures of turning the...
how long did you wait to open after cleaning, it won't let you open till it is cooled down to a safe temp. if its been several hours then the high limit t stat may have opened and you need service. prideapplianceser@sti.net
Jan 01, 2009 | Ovens
WILL NOT CONTROL TEMPERATURE
there is some adjustment in the switch to control it but according to ur problem the switch is weak though if u adjust the switch it will work properly only for few days or few months instead u can change a new switch to fix the problem permanently
Jun 21, 2008 | Frigidaire FGB24S5A Gas Single Oven
KitchenAid Architect Series KEMC308KSS
what if we have a voltage problem in the house, then it would be a lot cheaper to have a ceritifed electrician look at this beacuse there has to be a connection that the service man is overlooking than to purchace a new double oven at a tune of 1500.00
clll me 276-523-4434 David
Apr 12, 2008 | KitchenAid Architect Series KEMC308KSS...
GE JTP56 Double Oven
Hello there,
This may be related to the F7 problem even if you are not getting an error message. Go to my web site at the following link:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
Please let me know if this works for you. I have sent my fix to over 1300 folks.
Good Luck,
Powerman
Oct 20, 2007 | GE Profile JTP56 Electric Double Oven
Ovens Logo
32 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
