Question about Cub Cadet Garden
Cub cadet with 24 hp kohler v twin that acts like it is flooding out after 20-30 min of mowing.stop mower and it picks back up,may mow 2 feet and start doing it again,seems to do it mainly when turning or on a side slope.clean gas,no ethanol EVER!Please help. Daniel.
  • 3,904 Answers
It sounds to me that you have something in your gas tank that is intermittently plugging your gas feed hole. Inspect in your tank for something floating around in there and pull it out.
Posted on Apr 13, 2014
Testimonial: "took fuel line loose from tank and put in 5 gal. can of gas.same thing.I found that if I shake mower back and forth while running full throttle it cuts out every time.Incorrect fuel level in carb bowl?It has no float in carb. How do I set fuel level?"
  • Jerry Kramer
    Jerry Kramer Apr 20, 2014
    I apologize for such a late response to this. Fixya was not working correctly and I was unable. The next thing I would look for is a pin hole size air leak or even a bad vacuum hose. You will have to flex the lines while it is running to spot it or use a soapy solution and watch for bubbles.
alicantecoli
  • 22326 Answers
SOURCE: 2007 Cub Cadet LT1050 ~ 180
Sorry but for some reason the clutch is worn out ,maybe grass too long who knows but you will need to replace the the shoes on the centrifugal clutch ,when its cold they grip but once they warm up they slip just like a car clutch
Posted on Sep 03, 2010
ftw1952
  • 10319 Answers
SOURCE: Mower will start up cold, i will mow for a half
The valves DO NEED adjusting every 250 to 300 hours of service. That is why it dies out beleive me. It is not that hard to do if you have a service manual to help you along to perform this task
Posted on Jul 09, 2011
richroth
  • 9472 Answers
SOURCE: cub cadet 2166 with kohler
Either you have to much oil in the crankcase or you have a cracked or worn piston ring. When you mow on a incline, more oil come in contact with the upper crankcase and piston assembly. If the oil level is correct, you will need to replace the piston rings.
Richard Roth
The FixYa Team
Posted on Aug 07, 2011
  • 6468 Answers
SOURCE: my cub cadet 1042 stalls when mowing up steep incline, what's the problem?
check the float level in the carb
Posted on Apr 06, 2012
  • 6468 Answers
SOURCE: cub cadet super lt1050 after about 2 to 4 hours of mowing the battery loses its charge and the mower shuts off
check the alt output then look at the 2 wire plug near the dip stick tube
Posted on Apr 11, 2012
I need a picture showing the placement of the 2 springs on the mowing deck of a 2011 Cub Cadet Ltx 1040.
Cub Cadet LTX 1040 and LTX1045 Riding Mowers - YouTube
? 2:24
www.youtube.com/watch?v=XLT1v7h4at4
Jun 10, 2013 - Uploaded by CubCadetCA Cub Cadet LTX 1040 and LTX1045 Riding Mowers. CubCadetCA ... How to Change the Deck Belt on a Cub Cadet Riding LawnMower: Using ...
Jul 25, 2015 | Cub Cadet Garden
Why would my belt on my cub cadet 1046 mower keep popping off?
Did you put all the belt keepers back on? I find a lot of DIYers usually leave one off thinking it is not important.
Jun 30, 2015 | Cub Cadet Garden
I start mowing then a few minutes it will stop mowing. cub cadet zero turn tractor 1050 model 17af9bkbp010
I don't know if the Cadet is powered by a Kohler engine or Yamaha.
You may have a bad spark plug, plugged filter or bad gas.
May 08, 2015 | Garden
1050 Cub Cadet
Fit new spark plugs and new fuel filter.
Jan 09, 2018 | Garden
Cub Cadet LT1042 PTO keeps shutting off after mowing several feet, will turn right back on but keeps shutting off
I have a Cub Cadet 1605 and it does the same exact thing. Try the PTO switch on the dash. I replaced mine and it works fine. Hope this helps.
Oct 12, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
Pto shuts off durning mowing
hook up a test light so you can see if it looses power when it shuts off
May 14, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet won't stay running. I can mow for a will and it just sputters, and or dies. I let it cool off for about 10 minutes.It starts right up after it cools. It also starts to smoke when it gets...
Similar issue - buddies CubCadet with Kohler Courage 22 would not stay running. Turned out the coils got rusty where it interacts with flywheel. cleaned the contacts (be careful to shim for proper spacing) and ran like a top.
May 29, 2010 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Garden Logo
155 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
