Question about LG 32LC50CB 32 LCD TV
I'm looking for a "t-conn" board. has sound but no pic.
Swapped circuit with identical one and fixed the problem. need to order...
  • 115 Answers
U can replace ur t-con card with Chinese universal panel driver card.
Posted on Apr 13, 2014
  • LG Master
  • 3,320 Answers
Try craigslist or ebay
Samsung tv t conn board
In order to assist you, please explain the issue that you are having with your set. Thank you.
Jun 06, 2016 | Samsung Televison & Video
I HAVE A 37" LG TELEVISION AND THE SCREEN AND SOUND JUST WENT OUT THE POWER BUTTON IS ON BUT NOTHING. IS THIS WORTH FIXING OR SHOULD I JUST TRASH IT...THE NUMBER ON THE BACK IS 37LC2D... CAN ANY ONE HELP...
The power LED lite indicator is solid green,but no pic.?This tv is very fixable,take it to the shop,they will order a refurbish circuit board call a T-con board from some wesites source and repalaced it for u.This should cost u half the price of a new tv.If ur power LED lite indicator is blinking and no pic.,they will replaced defective leakages capacitors in the power supply board,or replaced the power board all together.
Apr 28, 2010 | LG 42LC2D 42 in. LCD HDTV
Stuck dvd and no power
I fixed this problem in my DVP642 by replacing a capacitor on the main power board where the power chord hooks in. Take the top cover off (after unplugging player). You'll be able to locate the bad capacitor on the circuit board located on the very right. Look for location marked c316 on the circuit board. A bad capacitor will be bulged up on top. The capacitor you're looking for will be a black barrel shape with an aluminum top, this aluminum top will be bulged up or leaking on the circuit board. Replace this capacitor by desoldering the two leads into the board and replacing with an identical part you can pick up at Radio Shack for a couple dollars. My repair for this identical problem was a success. The blinking light is the tip off for this particular problem on these Phillips models.
Oct 08, 2009 | Philips DVP642 DVD Player
Instrument panel gauges all stopped working while driving.
These vans are common for having cracked circuit boards in the Instrument cluster. You need to replace the circuit board. Try smacking the end of the dash and see if the gauges start working again.
Mar 22, 2009 | 2000 Dodge Caravan
No pic..or sound
a lot of times when a set is dropped the printed circuit board gets cracked, the only way to tell is to remove the back and printed circuit board and check; if not too badly damaged can be 'hard wired' across breaks and fixed
May 08, 2008 | Toshiba 36A61 36" TV
Samsung PCL5415RB 54 Problem
Replace both convergence ICs number STK392-040 You can get replacements at the following link and they will provide free instalation instructions with pics and also give free tech support on line so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
May 06, 2008 | Samsung PCL5415RB 54" Rear Projection...
5-yr old Maxtor 160GB fw/usb down
drives dead. Head crash problem.
The read head, has clattered the disk(s)
the only other option is to swap the logic boards over ( if they,re identical ) ** circuit boards on the drives**
Mike @ Compurepair.
Feb 22, 2008 | Maxtor Hard Drive
Sony r60xbr1 tv turns on then shuts off and red stand by lite blinks 4 times
Moe,You have several Broken Conns via your Mother Board after doing about 500 in the Past 8 yrs,What you need to do is Get a Magnifying Glass and look at the Bottom of the Main Board and look for Ring Breaks around Conns *Note,Any thing on a HeatSink or Plug Conns,Will be Checked First,Use 60/40 Solder and a low heat soldering Pencil to Fix Good Luck ttech
Jul 24, 2007 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Rca 52in p52921yx2 need help
if this problem happens after such aive mins and it is consistently giving that same problem to every time the set is turned on then it is a cold solder in your circuit of the video.if it gives that problem on start up ten the video amp and related circuit should be checked.have a tech check your tv.good luck.
Apr 15, 2007 | RCA P52921 52" Rear Projection Television
LG 32LC50CB 32 LCD TV Logo
