Question about Alesis MasterLink ML-9600
I paly a CD on Masterlink and want to copy it on another CD recorder via digital . The other machine (HHB800) displays "UNLOCK" . So soemthing must be onlocked in the Masterlink but what, where, how?
5 Suggested Answers
SOURCE: CD RESET FAILURE
I have the same problem. I have traced it to a bad CD Player/Burner. A replacement along with a new eprom chip in order to run the new updated burner can be ordered directly from Alesis- number on their website for $70 including shipping. I was able to troubleshoot it by dropping a new Panasonic DVD/CDR burner in the unit. It powered right up but wouldn't recognize the CDR. The unit will function without the proper CDR however- just no burning. This is an easy fix if you are at all technical.
Mike C.
Dubway Studios, NYC
Posted on Nov 04, 2008
  • 37 Answers
SOURCE: No display anymore on front of Masterlink
there is a cap that is bad and it burned out a couple of surface mount components. . if you don't feel like you can repair it, send me an email.
bcssr@charter.net
thanks
dave
Posted on Jun 24, 2009
  • 37 Answers
SOURCE: I have no display on
email dave
bcssr@charter.net
dave
Posted on Jul 01, 2011
  • 125 Answers
SOURCE: I cant make recordings on my masterlink every time
Look at all the tracks in the playlist that you're trying to burn to CD - is there a track that you've perhaps forgotten about still in the playlist, one of less than 5 seconds?
When you press Create CD, you're telling the Alesis to create a CD from the WHOLE of the current playlist, not just the track you recorded most recently ...
Posted on Jan 11, 2012
When I use ML-9600 as a palyer, can not copy from it to another CD recorder via digital IN-OUTs; the other recorder says "UNLOCK" so something must be unlocked in Masterlink but what and hoe?
What are you playing back, and what can the receiving unit cope with?
If you're playing back 24/96, your receiving unit MUST be able to cope with this. If the receiving unit can only cope with 16/44 or 16/48, you're doomed to fail.
Apr 13, 2014 | Televison & Video
Can copy from analog sources, but can't copy from digital source, eventhough the signal is monitored. The display says "can't copy".
Media
The unit requires Digital Audio CD-R or CD-RW media for
recording. Computer CD-R or CD-RW discs do not work with
this unit.
Serial Copy Management System
This unit is in compliance with the Serial Copy Management
System standard. This standard has been established to
restrict digital-to-digital copying to only the first generation.
The basic rules governing this system are as follows:
Rule 1
A digital recording is possible from a digital source such as a
CD, DAT or MD onto a recordable CD-R, CD-RW, MD or DAT
through a digital input connection. However, further digital
to- digital recording is prohibited for the second and later
generations.
Rule 2
When an analog source such as an analog disc or FM
broadcast is digitally recorded by using a CD-R, CD-RW, MD
or DAT, this recorded source can be digitally recorded on
another CD-R, CD-RW, MD or DAT. However, further digital
copying is prohibited.
Download the manual "cd-rw880_ef_manual.pdf" on the page linked below:
Download free pdf for Teac CD RW880 CD Player manual
Aug 22, 2013 | Teac CD-RW880 CD Recorder
Recording levels are low
There's no record level adjustment on the Masterlink. Increase the output level of your mixer, or add a variable level preamplifier between the mixer and the Masterlink.
Or, use the level adjustment on the Masterlink once the recording has been done, and before you write it to CD, either with level control or DSP normalisation
May 23, 2013 | Alesis MasterLink ML-9600
Why i am seeing DIN UNLOCK
If you are recording from a DIGITAL input like the OPTICAL or DIGITAL COAXIAL and their is no signal, or if it is a 'non-copyable' copy of a digital copy (from a mini-disc or protected audio CD-R) you will see this. You need to record using ANALOG inputs, then you won't have this DIN UNLOCK problem using analog. Double check your digital connections and make sure your digital source is set to 'play' and see if the DIN Unlock goes off. Otherwise, use analog reocrding only.
Jan 18, 2011 | HHB BurnIt CDR830 CD Recorder
It wont let me record anymore
If you are connecting via toslink optical or coax digital chances are you are encountering SCMS (Serial Copy Management System). SCMS will prevent you from copying a previously copied DAT or CD. You will need a CSMS stripper or copy bit bypass to circumvent this. I am assuming you are not violating copyrights. Behringer Ultramatch 2000 is a good SCMS bypass machine, and they are easily found on the internet.
May 21, 2009 | Sony RCD-W1 2-Disc CD Recorder
Downloading my music and then burning to a cd
Have you read the section of manual relating to 'Importing CDs' ?
Select a playlist, press 'playlist edit' - press HD/CD - insert CD, close drawer. Once Alesis has scanned disc, press 'track move' - display should read Move CDTrk -> Trknn where 'nn' is the next available track in playlist. Press Cursor Left to place cursor under CDTrk, press Down/No, and display should read Move CD->Playlist. If you now hit Yes it will copy all CD tracks to the active playlist (it'll prompt if the playlist isn#'t empty to make sure you want to add the CD to the tracks already in the playlist).
Once they are copied to the playlist, you can move them around if required, DSP them, then burn that playlist to a blank CD
Dec 02, 2008 | Alesis MasterLink ML-9600
Masterlink
I tried the "pressing play/pause and record simultaneously" during power
up, and it worked.....dunno for how long. The unit still makes strange
noises occasionally and doesn't seem completely healthy, but it's up
and I'm copying files that I want to save. We'll see.
Jun 12, 2008 | Alesis MasterLink ML-9600
Would pay for an OS Disc, I am unable to get the download to burn properly
Is this what you want.
Masterlink OS v2.21 For Windows & Mac
MasterLink allows new software to be installed via CD-ROM. If you have a PC or a Mac with a CD-burner, you can download the file below and create an updated CD for your MasterLink.
Mar 13, 2008 | Alesis MasterLink ML-9600
Copy Files to a CD
You need to loacte the files on the unit and get them to your hard drive via the transfer function. Once on your machine use any cd (like Nero) creating program to back them up to a black cd. You have to make sure your computer has a cd burner.
Nov 01, 2007 | Olympus VN-2100PC Digital Voice Recorder
Alesis MasterLink ML-9600 Logo
18 people viewed this question
Top Alesis Televison & Video Experts
Are you an Alesis Televison and Video Expert? Answer questions, earn points and help others
