Question about Canon IR2870 COPIER FOR 220 VOLTS ONLY
ERROR CODE IN IR 7095 EOOO2- 0001
IAM FACING THE PROBLEM IN IR 7095 MACHINE ERROR CODE FOR LASER DRIVE PROBLEM HOW I SOLVE THE PROBLEM KINDLY ADVICE
    Master:
  • Canon Master
  • 434 Answers
This error refer there is a problem in the fixing unit, check thermistor and clear that error from service mode
Posted on Jun 23, 2014
SOURCE: Error code E20 in Canon NP 6241 copier
Check this code - does it read E020 ? if so this is usually a result of toner starvation possibly caused by a faulty toner sensor in dev or hopper unit.I have also found the toner hopper supply motor can fail with the same result. In either case it is an engineers job to rectify. Good luck !
Posted on May 19, 2009
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Posted on Jan 11, 2010
SOURCE: error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Posted on Feb 11, 2010
canontech
  • 1219 Answers
SOURCE: Canon IR 3100cn Copier Error Code E00002-12
E002 Insufficient temperature rise of the fixing unit
0002 The non-contact thermistor fails to
reach 70 deg C within 180 sec after
reaching 50 deg C.
Check on connection of the thermistor, Replace the
fixing unit
To recover from the error: In service mode ( * 2 8 * )
COPIER>FUNCTION>CLEAR >ERR
0003 The non-contact thermistor fails to
reach 100 deg C within 180 sec after
reaching 70 deg C.
0004 The non-contact thermistor fails to
reach 120 deg C within 180 sec after
reaching 100 deg C.
0005 The non-contact thermistor fails to
reach 140 deg C within 180 sec after
reaching 120 deg C.
0006 The non-contact thermistor fails to
reach 160 deg C within 180 sec after
reaching 140 deg C.
0007 The non-contact thermistor fails to
reach 180 deg C within 180 sec after
reaching 160 deg C.
0008 The non-contact thermistor fails to
reach standby temperature (normally
190 deg C) within 180 sec after reaching
180 deg C.
0101 The non-contact thermistor fails to
reach 120 deg C within 300 sec after
power-on.
0102 The non-contact thermistor fails to
190 deg C) within 300 sec after reaching
120 deg C.
Posted on Jun 16, 2010
SOURCE: I HAVE A CANON IR
my xerox problem E000064-0000
Posted on Mar 15, 2011
C3852 error code
Fusing code I. the fusing unit is not warming up to the proper temp. Open the front to the right below where the cleaning clothes are kept there is a cover at about 45 degrees have to get on the ground and look at it there is hole small screwdriver to push the small switch to reset the machine for tha code it will not reset by powering off than on or closing the door.
Aug 10, 2014 | Konica Minolta bizhub C450P Laser Printer
E000014-0000 error problem how to fix in canon ir 6000
please switch off ur machine .....and sale to some fool then ur problem will be solve.........this is my free advice..........
Nov 29, 2013 | Canon imageRUNNER 3300 All-In-One Laser...
Canon IR 7095, error code E000005-010
Hello to all
I have a client server ir Pass has forgotten his password and I reset.
how reinitialiser server S2 canon ir Pass?
Thank you for the help.
Dec 27, 2012 | Canon Imagepass S2 Fiery For Ir...
My ir canon photocopier shows E 100 error. Please help
if you are changing the machine room from cold to warm, it can causes the error code E100, it's a condensation of the laser sensor. to solve this problem you need change the laser sensor PCB or the laser unit. or try to warm up the pcb sensor with a hot air. look at the picture to identify the laser sensor:
Dec 17, 2010 | Canon iR 2016i Black and White Copier
Error code e100 on canon laser fax L100
E100 means that you have laser trouble, probably laser pcb is bad. Replace it.
But also check the laser shutter.
Jan 30, 2009 | Canon FAX-L1000 Plain Paper Laser
Canon IR2870 COPIER FOR 220 VOLTS ONLY Logo
95 people viewed this question
old marine
old marine
