Question about Generac Generator 5989 2,700 PSI 2.3 GPM Gas Pressure Washer
Oil what wt. oil do you use in a generac 2700psi washer
    New Friend:
  • 180 Answers
Contact company, they should be able to answer this. Rule of thumb 10-30 is a good all around oil.
Posted on Apr 13, 2014
I can not find how much oil to use in the Generac Pressure washer 2700.
the only thing i can suggest put your pressure washer on level surface and start fill the oil when gets to the right level the oil start coming out
Apr 19, 2013 | Generac Generator 5989 2,700 PSI 2.3 GPM...
How much oil do you put in the pump for a generac pressure washer model # 01676?
Check and see if there is a sight glass on the side of the pump. If there is, just fill it until the oil shows up about half way in the sight glass.
Sep 23, 2012 | Generac Generator 5989 2,700 PSI 2.3 GPM...
Can I Use 10w-30 or sae30 motor oil in my 2700psi 2.3 craftsman power washer?
10w30 will work fine. you also can use 15w40 depending on how hot your summers are. you can stay with 10w30 just check it depending on how long at one time you use it. if your just occasional, check twice throught the summer and add or change if needed if commercial go with 15w40 and check every day.
Jul 06, 2011 | Craftsman Garden
I bought a new craftsman pressure washer 2700psi. Put oil and gas in it. Cranked on the first try. It worked for about 15 minutes and then cut off. Now the pull start is very hard to pull and will not...
Hello
Take out the spark plug and try pulling,if it is still hard then then there is a problem with the pull start mechanism.
Check the plug for oil fouling or fresh oil.If there is excessive oil you may have bad rings.
If in doubt, craftsman will honor the 1 year warranty no questions asked,for a new unit.
Jun 25, 2011 | Craftsman 2700 Max Psi Pressure Washer 23...
What oil goes in this unit?
Hi and welcome to FixYa, I am Kelly.
This response applies only to the engine:
Use 30 WT SAE engine oil.
You can use either detergent or non-detergent oil. I recommned 3 oil changes normal oil change intervals using 30 WT SAE non-detergent oil and on the 4th oil change use a detergent 30 WT Oil.
Thanks for choosing FixYa,
Kelly
Apr 17, 2011 | Honda 2500 PSI Gas Pressure Washer
Where do you add the oil on a DeWalt 3100psi pressure washer?
From reading everything I can find, i.e User's manual & parts manual the only thing you add oil too is the engine. The pressure pump does not have a liquid sump.
You can look at parts here detail D:
http://www.ereplacementparts.com/dewalt-dpd3100-pressure-washer-parts-c-1009_7440_7445.html
So too add oil to the engine you would remove the dip stick from the crank case located on the opposite of the side of the engine as the oil sensor.
I recommend you use 30 WT SAE oil for 3 oil changes then on the 4th oil change use an HD 30 WT oil. The oil drain plug is located in the center of the side of the engine crank case base. On the 5th Oil change switch back to SAE 30 WT oil. Oil brands are not really important. They all have to meet SAE the same standards to carry the label of SAE. (Yes you can use a generic 30 WT SAE oil )
Kelly
Dec 06, 2010 | Dewalt DPD3100 Gas Pressure Washer
On a generac pressure washer that works fine.
Oil level in pump and motor OK? Spark plug not fouled? Has it sat for a while - carb dirty? Running (loaded) throttle rpm not high enough?
Mar 27, 2009 | Briggs & Stratton Power Products 1539...
Generac Generator 5989 2,700 PSI 2.3 GPM Gas Pressure Washer Logo
103 people viewed this question
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
dennys23601
Don  Farrell
Don Farrell
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
