Question about Sony KDL-40NX700 40 in. LCD HDTV
40nx700 6 blink
6 blink after switch on
  • 115 Answers
Check all power out put from p.supply
Posted on Apr 13, 2014
  • Sony Master
  • 3,320 Answers
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 180 Answers
Contact sony. They should have technical support to help.
When switch on the TV then led light blinking continues only.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 23, 2016 | Televison & Video
Furnace problems
On - OK
1 Blink - Ignition failure. Check Gas flow, gas pressure, gas valve, flame sensor.
2 Blinks - Closed pressure switch. Check pressure switch (stuck in closed position).
3 Blinks - Pressure switch - failre to close. Check venter, pressure switch, vent blockage.
4 Blinks - Open limit switch. Main limit or aux limit are open. (My comment - Means overheating in chamber. Often result of blocked intake air. Bad filter. In my case, plastic wrap had been sucked into the intake. )
6 Blinks - False flame sensed. Check sticking gas valve.
Rapid continuous blinking - Incorrect twinning, incorrect primary polarity. Reverse transformer secondary leads, reverse primary wires.
Closed pressure switch can be from dirty combustion vents, bad chamber pressure - like missing screws, maladjusted gas pressure, failing pressure switch, loose hoses, moisture in the hoses or fan blades The switch need to be closed to ge the unit to work
Jan 23, 2008 | Goodman GMS90703BXA Heater
Tv switches itself off Led blinks 11 x
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Nov 26, 2015 | Televison & Video
PANASONIC Viera TH-37PX80BA with 7 blinking Red LED on switch on
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 20, 2014 | Televison & Video
Power failure
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes and details about many popular brand TVs are given.
Feb 04, 2014 | Pioneer Televison & Video
DID NOT TURN ON, HAS B+,RED INDICATOR LED BLINKING WHEN PRESSING ANY OF THE TACT SWITCH
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 09, 2014 | Philips Televison & Video
Protech 62-24084-02 troubleshooting
62-24084-02 LED CODES
POWER LED - GREEN
ON - Normal
OFF - No power to board
OK LED - GREEN
One Blink - One hour retry delay
Two Blinks - Pressure switch failure (remains open)
Three Blinks - Limit switch fault
Four Blinks - Pressure switch failure (remains closed)
Five Blinks - Twinning fault
FLAME LED - YELLOW
ON - Good flame
Rapid Blink - Flame present with gas valve de-energizing
Slow Blink - Marginal flame
Jan 01, 2014 | Protech Rheem/62-24084-82-1PK - Integrated...
My neutron R32 blinks continious yellow when switched on
blinking yellow light usally means the motors are not engaged so find the levers to reengage motors
Dec 04, 2013 | Invacare Health & Beauty
F1 code come on after 5000 rmp only n gear.i changed oil but used cheap oil.i lost speedometer at the same time.could this b the oil or do I have different problem.please help
Place the motorcycle on its side stand.
Start the engine and let it idle.
If the malfunction indicator lamp (MIL) does not light
or blink, the system has no memory of problem data.
If the malfunction indicator blinks, note how many
times the MIL blinks, and determine the. cause of the
problem (page 5-10 through 5-49).
If you wish to read the PGM-FI memory for trouble
data, perform the following:
Tum the ignition switch OFF.
Remove the seat (page 2-2).
Short the PGM-FI system service check connector terminals
using a jumper wire.
Tum the ignition switch ON and engine stop switch
RUN.
Even
if the PGMFl
has memory
data, the MIL
does not blink
when the engine
running.
If the ECM has no self diagnosis memory data, the
MILwill illuminate, when you tum the ignition switch
ON.
If the ECM has self diagnosis memory data, the MIL
will start blinking when you tum the ignition switch
ON.
Note how many times the MIL blinks, and determine
the cause of the problem (page 5-10 through
5-49).
SELF-DIAGNOSIS RESET PROCEDURE
1.Tum the engine stop switch RUN and ignition
switch OFF.
2. Short the service check connector of the PGM-FI
system using a jumper wire.
3. Tum the ignition switch ON.
4. Remove the jumper wire from the service check
connector.
5. The MIL lights about 5 seconds.
While the indicator lights, short the service check
connector again with the jumper wire.
Self diagnosis memory data is erased, if the MIL
tum off and start blinking.
.The service check connector must be jumped while
the indicator lights. If not, the MIL will not start
blinking. Note that the self diagnosis memory data cannot be
erased if you tum off the ignition switch before the
MIL starts blinking.
If the MIL blinks 20 times, the data has not been
erased, so try again.
Nov 14, 2013 | 2005 Honda CBR 600 RR
Sony KDL-40NX700 40 in. LCD HDTV Logo
60 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
