Question about Panasonic Digital Video Duplex, Color Mulitplexer
Color adjust on panasonic tau flat screen ct36sl13g
Help!! i bought this tv from friend it worked fine at their house when i got it home the color is mostly green i dont know what to do help!!!
  • 129 Answers
Re: color adjust on panasonic tau flat screen ct36sl13g
Good day.
Try to have the circuitry of your tv resoldered because I think there are loose connections in the unit causing a single color to be dominant.
Posted on Mar 12, 2008
Re: color adjust on panasonic tau flat screen ct36sl13g - Panasonic Digital Video Duplex, Color Mulitplexer TV Receivers &...
Tv turns on and clicks off immed
Posted on Apr 14, 2008
0 characters
3 Points
All televisions in home lost color at same time
Check your country supports which signals NTSE, PAL and try to put the same in your TV.
Aug 16, 2014 | Directv TV Receivers & DVRs
I have a panasonic flat screen, If I don't spray the fan everytime I go to turn back on the tv it overheats and doesn't turn on. What can I do to fix?
If your TV over 3 years old then you need send it to a repairer for further investigation because the part on circuit boards may have dry joins.
Aug 07, 2014 | Panasonic TV Receivers & DVRs
Added a 322 reciever to my lake house to be able to watch tv in 3rd room i had 2 standard recievers before. i installed a dish pro quad lnb & reciever had a separator w/it says dp plus 123254 tuner 2...
Is TV 2 off the 322 receiver being back fed from the receiver or do you have a direct connection to the 3rd room? If it is a direct connection, you would screw the coax from the 3rd bedroom directly to the TV 2 Home Distribution channel 21-69 out port.
If you are back feeding, you need 2 diplexers that connect 1) by the receiver and 2) between the receiver and the 3rd TV. The back feeding will use the same cable coming from the dish to the receiver.
If you have any other questions, please don't hesitate to ask.
Jun 26, 2011 | DISH Network 322 DTV Receiver
TV green screen after moving satellite receiver
a satellite receiver has its own coloring components inside it, if mixtures are not mixing properly. try that satellite receiver with differant tv. some with the tv,
Mar 27, 2009 | DISH Network 811 HD DTV Receiver
Installing a receiver
plug the receiver directly to the tv first without the panasonic. set up the receiver . then add the panasonic. the panasonic probably doesnt have a digital tuner so use composite av cables (yellow, red, white) from the reciever to the player
Dec 30, 2008 | Samsung HDTV Digital Terrestrial Receiver
Lost owners manual and need to program remote to Panasonic
Hold down Select and Mute until the tv light flashes. The enter the code and press Select.
May 12, 2008 | TV Receivers & DVRs
Panasonic model CT-36SL13G TV
Your problem is most likely the thermistor , or degausser, is going bad. It is a little black box with pins and says D1R5M on it. It can be found by following the wire from the degaussing coil around the picture tube. The location number is CF803( i think)the Panasonic partnumber is D4DF1R50001. Also, I believe your fuse is 6.3A not 3.6A.
Nov 07, 2007 | Panasonic Digital Video Duplex, Color...
Video failure...
Check the interlace/progressive switch on the back.
Sep 21, 2007 | Toshiba SD-H400
TV Receivers & DVRs Logo
430 people viewed this question
Top Panasonic TV Receivers & DVRs Experts
Are you a Panasonic TV Receiver and DVR Expert? Answer questions, earn points and help others
