Question about Cameras
Agfa I have just found an Agfa CP66 slide projector when clearing a relative's house. It seems to be working when I tried plugging in but there is no instruction manual. How do I fit the metal sliding bit that goes behind the bulb so that I can attach the canister or container of slides?
SOURCE: Lens cover slide stuck closed
Take a butter knife and slide it where the crease is. move the close/open button till it open it could just be stuck due to moisture. Hope this helps.
Posted on Mar 09, 2008
jigsawbill
  • 398 Answers
SOURCE: Agfa Easy Pix sv digital camera
It is a digital camera, however it's like 2 megapixel, and will take decent pictures but don't expect high quality enlargements.
Posted on Aug 05, 2008
  • 3 Answers
SOURCE: Sliding Lens Door Problem -- Canon S50
I had the same problem with a S50, where the lens door would not operate properly and would not open enough to cause the camera to activate. I took it apart and found that there are two small gears that keep the door on track, one had split in half and jammed the mechanism. They were white plastic, perhaps nylon? I found another S50 on ebay with broken electronics but a working lens door and took parts from it to fix my system. Getting the tiny gear in place was tricky as there are several springs used to activate the camera on switch.
Posted on Jan 21, 2010
SOURCE: Agfa AP1100 photo printer
Agfa AP1100 Photo Printer windows 7 driver
Posted on Feb 11, 2010
  • 25 Answers
SOURCE: My Bell & Howell cube slide projector has a
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=360183793446
Bell & Howell Cube Slide Projector Gear, New Item condition: New Quantity: More than 10 available Price: US $15.00 Approximately C $15.54 Buy It NowBuy It Now
This is the gear that goes bad on Bell and Howell cube type slide projectors. If you have one of these projectors you can pretty much expect the gear in your machine to go bad. The original gears were made out of an inferior material that was too soft. New old stock gears would be made of the same material and although they have never been used they most likely will fail right away since they are made of the same inferior materal. They were made soft to reduce the mechanical noise when the gear runs. This was told to me by the person who designed them at Bell & Howell. These new replacement gears are made out of Delrin, an excellent material for gears. Delrin is sometimes used to make gears that are normally made of metal. Don’t miss your opportunity to finally fix that old projector or get a spare gear for your working machine while they are available.
Detailed installation instructions will be included with every gear.
Posted on May 08, 2010
How do I use the tools in the Agfa 1680
TRY GOING TO THERE WEBSITE, YOU COULD TRY www.youtube.com
www.ask.com
www.about.com
www.wikipedia.org
www.howto.com or www.how-to.com
down load operational manual, how to videos. you can go to any of these sites above and type the following information.
operational manual for Agfa 1680 or
instructions manual for Agfa 1680
Agfa 1680 operations manual
agfa 1680 instruction manual and guide
www.searchall.com/manuals/agfa_1680
thank you rod
Mar 03, 2015 | Agfa Cameras
Agfa sherpa 43 driver
What is the exact model number of the printer?
Thank you,
Lee
Jul 24, 2008 | Computers & Internet
I have a Agfa SnapScan 1212u, but I can't find a driver to it. I have the system Windows 7
Although Agfa no longer supports their scanners with drivers and software updates, some Vista and Windows 7 users say they are still able to install the XP software and get it to run. In another thread, broccauley said: 'I got my Agfa Snapscan 1212U scanner to work fine with Windows 7. All I did was to install the XP Agfa Scanwise 2.0.0.9 software FIRST (available from Agfa website). Then I went to Devices and Printers, right-clicked on the 1212U and chose "Troubleshoot" - Windows then found and installed the driver automatically.'
Dec 15, 2010 | Agfa SnapScan 1212u Flatbed Scanner
Are there drivers for the agfa snapscan 1212u in windows 7 platform?
As far as I can tell, the driver has not been updated for either VIsta or Windows 7. If you have Windows 7 Professional or Ultimate, you have a workaround option. Install the XP mode and then install the scanner to that virtual PC.
I hope this helps.
Jan 05, 2010 | Agfa SnapScan 1212u Flatbed Scanner
Will AGFA 780 work with windows vista?
I contacted the AGFA corporation and was informed that from windows XP and above the AGFA ePhoto 780 digital camera and software is not compatible. So my answer is NO, it will not work with windows vista. :(
Mar 18, 2009 | Agfa ePhoto 780 Digital Camera
Agfa ephoto 1280 - blank screen on "Play" OK in "Rec"
Tried replacing the memory card, and the camedra came alive again.
Feb 18, 2009 | Agfa ePhoto 1280 Digital Camera
Compatibility with new imacs
I got drivers here that work fine (sub division of Agfa).
http://static.agfa.com/digicam_scanner_drivers/scanner/snapscan_e20/index.html
May 05, 2008 | Agfa SnapScan E20 Flatbed Scanner
Cameras Logo
26 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
