Question about Dishwashers
Ge dishwasher will not drain fully anymore i have cleaned all traps and motor/pump could it be something in the pump? what else could it be?
    Brigadier General:
  • 8,619 Answers
Hi
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 18, 2009
4000 series
There is some blockage in the pump unit and will need to be opened.
Usually the impeller is stuck or there is a blockage.
Will look something like the part on this link.
Drain Motor Assembly
Aug 02, 2014 | Bosch Dishwashers
Dishwater not fully exspeeling from dishwaser
If nothing obvious like blocked / obstructed outlet pipe
You need to check if the outlet pump motor in line with the outlet hose is spinning when in the outlet mode. First check if it is spinning by looking at it and see if the small fan is spinning FREELY. If it is turnning this means that it has power and the internal "impeler" that pushes the water out has become loose. Remove the pump (easy job) and repair. If it does not spin you need to determine if the 2 push on terminals have power on. If there is voltage and the motor does nut spin this indicates that the pump motor is open circuit and must be replaced.
Mar 26, 2010 | GE Nautilus 24" Built-in Dishwasher
Canot get the diswasher to drain. Tried CLR-no
Hi, please check to make sure which style d/w you have as outlined above. The direct drive dishwashers have a drain solenoid attached to the motor and pump or a separate drain valve that must be checked with a ohm or volt meter. The drain solenoid and valve energize and opens the drain port to allow the water to pump out. For a "no drain" problem, always start with the common stuff first...a kinked or clogged drain hose. The drain hose must be checked and cleaned out and if you have to, remove the drain hose(s) to fully check and clean them. Don't forget the drain system sometimes consists of a self cleaning body that also can get clogged and stop the dishwasher from draining. If your drain hose needed to be lengthened a hose connector was probably used, these hose connectors are slightly smaller than the drain hose and food bits often get clogged there, also the tail pipe piece that connects the drain hose from your d/w to the house drain is also another popular place to get a clog. On the forward/reversing style of dishwashers that won't drain, make sure the motor is reversing to drain the water out. If the motor does not reverse to drain, the motor, wires ( especially where the doors bends to open and close ) and timer will have to be checked. If the motor is reversing and running, the pump impellor inside the motor and pump assembly may be damaged and is incapable of pushing the water out to drain. If the drain solenoid or drain valve checks ok on the direct drive motor and pump, the impellor inside may also be damaged as mentioned above.
Always check the drain spout under the sink for a d/w that will not drain, also if the Air gas is leaking this is a clogged air gap or drain and normally not a d/w problem.
Feb 22, 2010 | GE Nautilus 24" Built-in Dishwasher
GE MODEL GSD900D ISN'T PUMPING OUT THE WATER. IS THERE A RESET BUTTON?
There is no reset button. The most common problems are drain hose blocked (new or plugged disposal?), or the pump/motor assembly has been leaking. Is the motor turning? GE motors will turn from the time you turn it on until dry cycle. Remove the lower panels and observe the drain solonoid on the left of the motor. The silver plunger should go down when in drain cycle. Look for any corrosion meaning you have had a leak. If so, it is probably time for a new dishwasher. The newer dishwashers are much quieter, clean better, and use less energy. The best price on a new pump assembly is around $120 plus shipping.
Hope this helps,
Ken
Oct 16, 2009 | GE Dishwashers
Dishwasher doesn't drain
The drain motor might be worn so it still pumps out fairly well but will let wtare back in once it stops pumping. It may also have something stuck in it so it ot is worth removing and cleaning through with a good degreasing cleaner.
Sep 10, 2009 | Hotpoint 24 in. HDA3400G Built-in...
I can't find the filter on GE Triton dishwasher to clean it. Also, where do I add the dishwasher salt?
If possible, can you provide the specific model of your dishwasher? ( That would help) also: see attached link to a site that shows pictures of generic GE dishwasher pumps.. at least one view shows a screen on the inlet of the pump however many dishwashers have a screen that traps food particles from draining into the pump and I would look at the loweset point inside the d/w itself for a drain opening. Some mfrs put a screen filter there..Could be more specific if you could provide model numbers though.. Hope this helps..
Aug 24, 2008 | Dishwashers
Dishwashing machine not fully draining (2 inches of water remain). I have an open problem concerning this problem. I have a new pump. dishwashing machine not fully draining (2 inches of water remain) For...
Following a cycle, a small pool of clean water inside the tub is typical. Excessive water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up. If dirty water spews from the air gap, the drain line is kinked or clogged. Note: If you've recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made (see your disposer instructions).
Apr 19, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Will not drain
.first thing to do is to see if the drain motor is running or not....if it is running but not draining the water the hoses and drain pump motor should be checked for any restrictions right from the drain pump assembly/motor all the way to the sink/house drain.
If the drain motor assembly is not running, is it receiving power, is it jammed up with something ( glass, pits are common ).
Jan 09, 2008 | GE 25 in. Nautilus GSC3400J Free-standing...
Ge dishwasher is 12 yrs old. water doesnt drain, checked trap, its clear..
check the pump and motor to see if it is working the motor might run but the pump could be to weak to move the water, and the opposite the motor could be to weak. if you hear the motor run then its a fairly simple test put a small rag in front of the intake to the pump and carefully move it close to see if the pump tries to pull it in dont let it suck it in that will cause lots of problems.
Dec 09, 2007 | GE 24 in. GSD3620Z Built-in Dishwasher
Dishwasher not draining fully
Remove and replace the motor / pump assy. Call technician. Big Job
Dec 02, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
152 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
