Question about Intex 1000 Gallon Per Hour FilterPump
How do i separate the impeller from the shaft on my intex 1000gph filter pump
  • 77 Answers
SOURCE: need an impeller for a model 635 intex pump.
You are correct. Intex is in the business of selling new product. If you have the pieces, they may be super glued with about a 70% sucess rate. good luck!
Posted on Aug 19, 2009
tinkerbill
  • 12 Answers
SOURCE: Need Intex Pump model #635 impeller
You know, I have made some amazing repairs on plastic items using nothing more than a soldiering iron! If you have the piece that broke off, you can carefully melt it back together. You can add more to the weld if you match the type of plastic but not too much or you imbalance it. In this case it looks like PVC. To repair it without the missing piece, form it out of epoxy putty, roughly shape it just before it sets up solid, & sand to finish.
Posted on Jan 02, 2010
  • 8404 Answers
SOURCE: how to fix a broken iimpeller
You should be able to get a replacement or repair at your local pool supply place.
Posted on Aug 04, 2010
SOURCE: i have a intex krystal
when I put the filter in the pump runs about 30 min the quits pumping water . what is the problem<br /> <!-- from fixya rte -->
Posted on Aug 16, 2010
SOURCE: what is an impeller
the impeller is the most important part of the pump when motor kicks on impeller spins pulling and pushing water through it check to see if it has something glogged in it also try backwashing filter...
Posted on Jun 01, 2012
Pump is running but not pumping
Possible broken impeller from motors shaft, common Intex problem.
So...
As a technician of more than 30 years in the Pool/Spa Industry, And with the rise of these Quasi-Pool or Spa wannabe's, popping up everywhere, I have seen SOOOO Many frustrated customers and owners of these units, with very similar problems and non working pool and spas!
Unfortunately these Intex products are Mass Produced by the Gazillions in China, and then unleashed on the general American public? Who believe that it will work and last, but come to find that they usually don't last a season! Some die sooner, and yet some do last a little longer. AND, there are no available parts to repair! They make you buy a complete replacement control unit! So if your controller panel has a bad button, no available part, whole new control system! Heater stopped working? No available element to replace, whole new controller! Pump not pumping water or leaks - yep, No impeller or shaft seal available, Whole new pump, Etc. etc.
So many customers of mine, regret their purchase.
So...To try to help, and maybe get them back into a splashing good time or... Back in Hot Water..
I tell them ... SQUEAK! And do it loudly and often!
Maybe they will listen and OIL that Sqeak?
look here...
http://www.intexcorp.com/contacts
then if if budget allows, don't buy another Intex component, if you get no help from them, get a Real Pool Pump and if possible, mate it with a Real Pool Filter, not just toys.
Something like this...
Hayward S144T1540S Pro Series Top Mount Sand Filter 14 Inch 4 way Valve...
Jun 10, 2015 | Intex Automatic Salt Water System for ...
How can I get my impeller to work when I plug it in it does nothing?
The impeller shaft could be binding. Also, the pump could be unable to spin the impeller at all, in which case you may need to replace it.
Jul 13, 2014 | Intex Krystal Clear 1600 GPH Model SF15110...
MY 1000GPH INTEX FILTER PUMP IS DISMANTLED BUT I CANNOT GET THE IMPELLER OFF THE SHAFT
there should be a backwards threaded screw take that off then hold the back of the motor shaft and unscrew the impeller regular threads
Apr 13, 2014 | Pentair 2 hp WhisperFlo InGround Pool Pump...
Intex pump flowrate drops
you may have a dirty filter. Check your filter to be sure. Remove the filter from the pool equipment and see if it runs fine for longer period of time. The filter would be the only restriction in your Intex system for water flow.
Rod
US Parts Center
Jan 17, 2013 | Intex 1000 Gallon Swimming Pool Filter...
Impeller in intex model 635 broken where can I buy replacement part?
A late answer but it might help future Intex impleller sufferers... they do not sell replacement parts and you won't find any impellers sold separately anywhere on the planet. I've had 1 Intex pool and 3 Intex filter pumps in 3 years. Last week the 3rd pump's impeller broke as well. I shan't buy their products again.
Jun 21, 2012 | Intex Krystal Clear Model 635 Pool Filter...
What is an impeller
May 30, 2012 | Intex 2100 Gph 95 Hp Sand Filter Pump With...
I have add the intex saltwater system model CS8110 to the intex AGP 15 x 48. (only 1000gph-yet the manual says 700-4000gph is sufficient) I have done all troubleshooting suggestions in the manual. With the...
Skimmer or pump baskets may be clogged. It's also possible the pool return is too high causing excess back pressure on the pump. Try raising the pump and equipment off the ground getting a bigger pump.
Oct 26, 2017 | Sport & Outdoor - Others
Is the intex 4000 pump any good.... do you lots filters...
I have the new 4000GPH pump and its awesome! The pump itself needs modifying just a bit. As for your pool, get rid of the plunger valves. They restrict the flow by about 1000GPH or more. There is a plastic grate in the inlet side of the pump. I just took a small file and sharpened the leading and trailing edges to smooth things up. The biggest thing is with the plunger valves. I modified some PVC fittings so I can use 1.5 inch ball valves. When my pump starts up, you see the water moving. I no longer have problems with **** settling to the bottom of my pool. Oh, and it will run an automatic cleaner with ease.
I dont recommend using the 400GPH pump with hoses smaller than 1.5 inches as there will be too much pressure and is likely to cause problems.
Mar 07, 2009 | Intex 4000 GPH Filter Pump
Intex 1000 Gallon Per Hour FilterPump Logo
21 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
