Question about Schumacher 15/10/2 Amp ShipN Shore Battery Charger
Ssc 1500a repair
Wont charge
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 24 Answers
Check the fuses
Posted on Apr 13, 2014
Testimonial: "I will take a look at that. Thank you."
Epson C86 Message says "service
This is a common error with ALL Epson printers and you can find out more about what it means, what you can do about it and even instructions for fitting a waste ink kit for your printer via here:
http://www.octoink.co.uk/waste
In terms of resetting the waste ink counter, the SSC utility should work but you may need the AdjProg (Adjustment Program) instead depending on whether the printer firmware is willing to talk to SSC or not.
Hope that helps.
Martin
Nov 24, 2010 | Epson Office Equipment & Supplies
I use a CamSpray 1500A in a student screen printing studio. Today the pressure washer is not working properly. The motor sounds good, but the pressure is barely coming out of the nozzle. Seems almost...
It can be one of two things, either the valves in the pump or the unloader on the pump is having an issue. The first thing I would check is the unloader. If you look on your machine the big black handle that you screw up and down to regulate the pressure is where your unloader is located. I don't have the model number off the pump so I can't really walk you through repairing it, if you could get the model off the pump I will be able to give you a better idea on what to look for.
If this is not your issue it is going to be the valves in the pump that need to be replaced, for this I would also need to know the model number of the pump in order to give you some direction.
Oct 30, 2010 | Cam Spray 1500A 1450 Psi Cold Water...
I have the SSC-1500A battery charger and the yellow light keeps flashing. The yellow light is the charging light.not sure why
This unit will assume a battery voltage less than 1.5 volts means the battery is sulfated. The flashing yellow light means it has gone into 'desulfate' pulse mode using pulses of high voltage to try and convert the lead sulfate back into sulfuric acid and lead plating. It will do this for about 8 hours on the charger I have. If the voltage has not raised to a level that can can accept a normal charge it will abort the pulse mode and stop trying to charge it. You will need to unplug and replug in the charger to try again. Always check the temperature of the battery while charging it and especially if the charger is in pulse mode. Stop charging if the battery is hot. *always wear safety gear*
Sep 23, 2010 | Schumacher 400w Power Inverter
Red and green light wont stop flashing on my epson c40ux and it wont print?
See status monitor? It's service required? Find SSC utility to reset waste ink counter. Try to find indoreset.blogspot.com. Or contact me for the reseter and instruction detail.
Oct 17, 2009 | Epson Stylus C40UX InkJet Printer
Problem with Sony DSR 1500A won't record error flashes "Rec Inhib
dear,
the rec inhbit cable is faulty in this case ...
u need to replace that (holder assy,MIC.)
Regards
Jun 14, 2009 | Sony DSR-1500 Mini DV VCR
Need a samsung ssc 1280 owners manual
I have PDF manuals for the Samsung SSC-1280, and SSC-14M. Feel free to e-mail me at Anoint2020@aol.com and I will send them to you. Hope this helps.
Mar 12, 2009 | Samsung SSC-960 VHS VCR
Samsung ssc-960
can someone send me an an owner manual for ssc-960 time lapse recorder. fcassis58@gmail.com
Aug 31, 2008 | Samsung SSC-960 VHS VCR
Service required. parts inside your printer are at the end of their service life. see your printers documentation for details. manual says to contact dealer. have tried using the SSC service utility...
I held down the 'stop' and 'B&W' button while pressing the 'On' button.  this cleared the error message and I was back in business again. This was for the RX620 model.
Gordon
Dec 29, 2007 | Epson Stylus Photo RX700 All-In-One InkJet...
Looking for a manual for A Samsung SSC security system
Am not familiar with an SSC-960, there are however SVR-960 (4 versions) by Samsung.
Normally Samsung follows similar installation procedures and the differences in their model are advance features and the length of recording time. If this could be of any help, this link is a users’ manual for a 1280 hrs model. It includes installation procedures.
Alternately you can try Google for “svr 960 pdf” but when I tried it most that I can get are German language versions.
Hope this be of some help/idea.  Good luck and kind regards.
Aug 25, 2007 | Samsung Weather Resistant Security Camera...
Schumacher 15/10/2 Amp ShipN Shore Battery Charger Logo
85 people viewed this question
Top Schumacher Electronics - Others Experts
Are you a Schumacher Electronics - Other Expert? Answer questions, earn points and help others
