Question about managemylife.com
My weedeater engine comes on but my string head doesn't turn
    New Friend:
  • 3 Answers
Try removing the head
Posted on Apr 14, 2014
Why does my new Craftsman 4 cycle Trimmer's head turn counter clockwise
Curved shaft trimmers turn clockwise.. straight shaft trimmers turn Counter Clockwise. Also the Bump head is reverse threaded because of the engine rotation.
When using this trimmer , Angle the right side of the string line down so the grass gets thrown in front of you not at your legs.
May 30, 2015 | Craftsman Garden
How do i remove the head to replace the string on a Murray M2500 trimmer?
How do i remove the hend of the weedeater it is stuck on there. I believe it is stripped
Sep 08, 2014 | Garden
My weedeater engine comes on but the string head doesn't move
the shaft is disconnected, disassemble and fix it.lol.
Apr 13, 2014 | managemylife.com
How do i reload the weedeater head?
usually, you can pull the head straight off or press it down and give it a 1/4 turn. View your manual for more information.
Aug 06, 2012 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
The spline for my Poulan TE475 WeedEater comes out during start up and wraps around the shaft. I use .080 round spline. It started recently to do this.
The string head on these units is very poorly designed. There is hardly anything in the head to retain the line. I suggest removing the stock string head and going to Home Depot and getting a replacement Universal type head or one for the Ryobi or Homelite They are basically interchangeable. Check the length available on the shaft end (threaded part) after removing the head.Use a large wrench or pliars to hold the dust cap when you unscrew the head. If you feel the driveshaft turning, don't continue turning head or you will break the flex driveshaft.
Jun 30, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
The weedeater string part below the Gaurd fell off I disconected the shaft and put the blower attachment on and it works fine. Is it the string head that's bad or the inside cable orthe coplete...
The part below the guard is designed to come off for cleaning and restringing, as long as you still have all the parts, you just need to put it back together and it will be fine.
Jun 30, 2011 | Garden
Homelite Mighty Lite 26CS Model21004D
Once you have the string wound onto the spool, place the spool onto the shaft and pull the strings out of the slots so that the string feeds through the holes without going through the slots. Good luck...Lee
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Weedeater starts fine but the string head will not spin. I removed the string head, and the shaft it connects to is not spinning either.
The shaft cable has either come loose at the head, or is broken at the engine most likely. Is this a 2 piece unit? If so, see if the cable turns with the grass trimmer section removed. If so, it is usually easiest to just replace the trimmer shaft section. One piece units require disassembly at the engine, and if you are not mechanically inclined, that can be a pain.
Apr 15, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
I need to know how to load a two string trimmer head. This is on a ryobi weedeater model 700r, 31cc, 15 inch.
most of these use 2 wires coming out of 2 holes on opposite sides roll the firstwire clockwise, then the 2nd counterclockwise so that when the spool turns the string comes out its not hard
Aug 25, 2009 | Garden
managemylife.com Logo
Top managemylife.com Computers & Internet Experts
Steve
Paul Bade
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
