Question about LG 42PX3DCV 42 in. Plasma EDTV
Picture is fine for about four minutes and then looks like a photo negative.
Turns on with good picture for about four minutes and then looks like a photo negative.turn the set off for about ten minutes and then back on it does the same thing.
2 Suggested Answers
jerryg50
  • 1689 Answers
SOURCE: lg 42le4500 tv when first turned on its okey after 2 minutes no picture black screen but sound ok, turn it off and back on againdoes the same
I would bet on some component(s) have become thermo sensitive. Most of the time capacitors can do this type of thing. Most likely the defective caps could be in the power supply.
To locate the defective caps, you would have to be able to run the supply and use the combination of a heat gun and freeze spray (liquid air spray) for cooling. At the same time you would have to monitor the output of the supply to see the components that cause the output change.
It is also possible to have thermo sensitive components on any of the other boards. This would also require proper troubleshooting.
The service rep would replace boards until he found the defective board. Then he would return the set with the new board and the bill for his work.
If your set is out of warranty, it may be better to consider a new set. Servicing these can be fairly involved and expensive.
Jerry G.
Posted on Jun 26, 2012
Sharp 52" LCD-Negative picture
hi bring the menu up if it's the same as the picture, the mainboard could be the problem, also can be a bad panel thanks
shaun
Mar 04, 2017 | Televison & Video
Rx 620 slow to print
Epson's RX620 scans and prints photos at high quality. Text, however, was slow to print and not that good.
it_portal_pic_41791_t.jpg Epson's multifunction devices fall into two categories: general-purpose models that are designed for home or small office use, and photo-oriented devices such as this, aimed more at the enthusiastic amateur snapper.
Because it's a photography-centred device, the RX620 uses dye inks. On photo paper, these produce more vibrant colours than pigment-based inks, and a true gloss finish, but on plain paper produce inferior, less vivid results.
The Stylus Photo RX620 is quite large, and looks dated - but it's not short of modern photo-printing features. Its built-in memory card reader is compatible with seven commonly used digital memory formats, including xD and SmartMedia. Photographers using film will appreciate the scanner, with its high optical resolution and transparency backlight.
On plain paper the RX620's text printing showed bandingand rough outlines on default settings. Our five-page black-and-white text document took two and a half minutes to print. Increasing quality settings made it even slower.
We tried realigning the print heads to improve print quality. The RX620's manual process involves choosing the best-aligned examples from four rows of 15 patterns. This takes good eyesight, and it can be hard to choose between similar-looking options. We needn't have bothered - text remained unchanged.
Photo printing was far better. The RX620 produced some of the best prints we've seen from a multifunction device, but only at its highest quality - and slow - setting. Our A4 test picture took 15 minutes 12 seconds to appear.
The RX620's scanner is excellent, previewing an A4 sheet in six seconds and scanning a 6x4in photo at 600 dots per inch (dpi) in just 14.5 seconds. Negative scan times were reasonable, with a single frame scanned at 2,400dpi in 1 minute 40 seconds.
The RX620 can perform many advanced functions without being attached to a computer, and its colour screen has a clear menu system. Prints can be made directly from memory cards, photo prints or even film. There are four document copying settings, but results using the default Text quality are adequate for most office purposes.
The RX620 isn't a brilliant multifunction device. It does many things well, but its printer is too slow, and simply not good enough on plain paper.
Please rate my solution after reading it. Thank you
Feb 27, 2009 | Epson RX620 All-In-One InkJet Photo...
No real color picture, looks like an undeveloped negative, ghost
The pictures are indeed negative.  When scanning negatives or transparencies make sure you have the scanner set to the appropriate setting, otherwise simply Invert the colors in Photoshop, or similar photo editing software.
Dec 03, 2008 | Cameras
Negative screen image
Look in System Preferences for Universal Access, there is a Display option which says Black on White(the normal setting) and White on Black (the setting that has been enabled).
There is a keyboard short cut to change the setting, it involves pressing four keys - Apple, Option, ^ and 8.
Nov 29, 2008 | Apple iBook G3 Mac Notebook
Picture looks like a Colored Negative
so, how can i fix this problem with my tv. the tv comes on but the colors look fuzzy..help!!
Oct 27, 2008 | Syntax Olevia 50" Rear Projection...
FE-170 Blurred photos
ccd may be going out.. try doing a reset thru the menu or else..repair
Aug 31, 2008 | Olympus FE-170 Digital Camera
Picture looks like photo negative when power is reapplied
the most probable problem is it would be one of the first generation LCD televisions.
if possible try changing the refresh rate of your tv
it may help.
Feb 02, 2008 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
My camera will not take photos
'I have opened the camera up and looks OK' How can you tell? what you have done is negated any chance of as repair or replacement. But a new camera?
May 10, 2007 | Samsung Digimax S500 Digital Camera
LG 42PX3DCV 42 in. Plasma EDTV Logo
24 people viewed this question
