Question about Toshiba 55H70 55" Rear Projection Television
Desoldering STK392-110T Can you give me instructions on desoldering STK392-110 chipswithout damaging the board ? Thanks Tony
  • 4,402 Answers
Posted on Dec 05, 2007
Can not connect board to game help
As long as you are following the instructions properly, I would say you have a defective board. This accessory is notorious for failing even brand new straight out of the box. In fact, they are so unreliable that most consignment game shops will not even consider purchasing them from you.
If you are simply finding it difficult to connect the board because you lack the proper instructions, here you go: How to sync Wii Tony Hawk Ride Skateboard (not my vid, but this is exactly what you need to do).
Apr 08, 2014 | Activision Tony Hawk Ride for Nintendo Wii
Compaq armada 110 user manual
Hi Misa,
Here's the user guide in pdf.If you're using Windows XP here's the user guide,and for Windows 7 here it is.
Hope this helps.Thanks!
Please rate this answer.
Dec 11, 2011 | Compaq Armada 110 Notebook
Bulgging capacitors on my GT5058 mother board how do I find another mother board?
Had the same problem
Bulging capacitor near the power connector.
Found the capacitor on a junk MB desoldered it and replaced on the MB.
Running fine a year later.
Give it a shot It is not that hard. Get yourself a desoldering pump and a good fine pointed iron.
It can be done...
Nov 08, 2010 | Gateway GT5058 Desktop PC
Attempting to solder vga connection on motherboard
No as long as you solder it back together right.
Feb 28, 2010 | ASUS P5LD2-VM Motherboard
How do you replace ic chips on Panasonic 52 inch hdtv projection?
Most IC's on circuit boards these days are of the surface mount variety. You will need special Desoldering Equipment to remove these chips, especially the one wth 100 or more pins, the type of equipment used in this process heats all sides of the chip at once while a small suction that grabs the chip for removal. Now the SIP chips (Single inline package). chips which usually consists of less then 20pins can be removed with a desoldering gun such as the HAko 880 desoldering gun. Or you can use a standard soldering iron and solder Wick, that can be found at Radio Shack under Soldering Braide).. These procedures are common for all IC replacement. I am asuming you are trying to remove the Convergence IC on this model, The two large Black one labeled STK-392-110, the correct and easy way to remove these is to remove the entire board from the unit and remove the two screws holdinf each one in place, Unsolder the pins of each one and remove the IC, reverse this process to reinstall them. Good soldering technique is critical here as you don't want to bridge pins together causing yourself more problems. Double check your soldering and Double check it again.
Sep 28, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Gateway notebook
Ya, I do Run A Laptop Repair Shop Here Is My Site
There are Many Tutorials online.. do a google search..
I wouldn't recommend you attempting the repair of your DC Jack Unless You've Had Alot of Soldering/Desoldering Experience... more-so Desoldering Experience
Nov 18, 2008 | Computers & Internet
If you have some basic soldering skills, this might be something you can do.
Search on google "how to solder and how to desolder" You tube seems to have very good instructional videos about it.
Good Luck.
Apr 12, 2008 | JVC AV-56WP74 56" Rear Projection...
Convergence Problem
You do have to take them off of the circuit board but.... unless you are good at soldering and desoldering I would leave this to the pro's, also on JVC's the resistors feeding the convergence IC's can be bad and will cause the new ic's you put in to immediatly fail. But if you do decide to do this repair I have a hint for you. Use STK392-150, this is the same part rated at a higher wattage so it will last longer. You can also request your servicer to upgrade them also. Hope this helps.
Mar 28, 2008 | JVC AV-56WP74 56" Rear Projection...
My tv
This set is known for some very common problems some of which is just what you described. For a small fee, I can give you some common solutions that will take care of these and other issues. The only problem is you must know how to take things apart and put them back together without doing further damage, AND you must know how to solder /desolder components.
Dec 24, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Toshiba 43H70
The Toshiba 43H70 has two RGB driver chips (p/n: STK392-110) responsible for aligning the RGB colors, one of them went bad. Instead of throwing the TV away, I decided to try and replace them, and fix the TV. I did, and it works great! I ordered two STK392-110?s online from, it cost about $18 including shipping. Each STK392-110 is about 2? in length, and 1.5? in height, and is an 18 pin device. The tools I used were all purchased at Radio Shack, and are: a soldering iron with a stand, solder, de-soldering tool, thermal grease, and a digital camera (yes, a digital camera). First, make sure the TV is unplugged! On the back of the TV, take the back wooden cover off. You?ll see a bunch of wires going everywhere, a power PCB board (probably brown), and a green PCB system board. The two STK392-110?s are on the green PCB system board attached to two big heatsinks. You will have to remove the green PCB system board to get to the two STK392-110?s and replace them, there?s no way around it. To remove the system board, you?ll have to remove the board with all the video jacks on it, and will have to disconnect all the wires going to the system board, as well as disconnect the power board from the system board. The power board and system board lie right next to each other, and are connected by two connectors. You have to be careful with those two connectors, and I used a small screwdriver, got it between the mating connector, and gently pried it open. It?s like an old mechanical switch, but instead of one contact, there are several. While taking everything apart, this is wear the digital camera comes in, take a picture of everything you disconnect and remove, and play the pictures backward so you know how and where to put everything back together. The system board is held down by several screws that will need to be removed. Once the system board is removed, you can see the two STK392-110 driver chips, however, you will have to remove several vertical boards and heatsinks to get to them freely. The STK392-110?s are attached to two heatsinks by two screws each. The heatsinks are soldered on the system board, so you?ll have to desolder them to remove them. Once you have them removed, Now that the old STK392-110?s are freely accessible, go ahead and use a pair of wire cutters, and cut them off at the leads (the 18 pins). Now desolder the 36 pins left in the board. Use the desoldering tool to get as much solder out of each hole so you can easily put the new STK392-110?s back in. (Make sure you put them in the same way as the old ones!) Put the two STK392-110?s into the holes, put the thermal grease on the metal side of the STK392-110, then attach the heatsinks to them, line up the two mounting screws that hold the STK392-110 to the heatsink, and start soldering everything back together. Make sure you use enough thermal grease between the heatsinks and the STK392-110?s, too much is better than not enough. It will look like the 18 pins are all connected together on the PCB system board, but they are not, make sure you individually solder each of them to the PCB board, and do not let solder from one pin touch solder from the pin next to it!! Use the digital pictures you took and play them backwards so you can put your TV back together correctly. Attach your TV cable to the TV, plug it in, and use the remote to turn it on (stand back just in case you crossed some wires), it should work, and the picture should be perfect.
Aug 13, 2007 | Toshiba 43H70 43" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
176 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
