Question about Whirlpool Refrigerators
GC3SHEXNS16 getting to cold freezer side
Freezer 70 degrees but is to cold and will not stop running
icansurf
  • 72 Answers
SOURCE: Freezer set at 0 degrees, but runs at 19 degrees. Ice Cream melting...
Low on freon/refrigerant maybe.
Posted on Mar 03, 2007
SOURCE: GE GSS22 refrig wont get cold, freezer does.
Hi, it's possible you have a defrost problem, to know if you have a defrost problem, you should unplug/disconnect refrigerator, remove your produce, leave doors open, for faster defrost, clean and leave unplug/disconnected for about hour, be cautious you will get excessive water from defrosting. let freezer defrost completely, then plug/connect refrigerator, let it work/run for an hour, if it's o/k, put back your produce, if it work good/ o/k for 3 to 4 days and start doing the same thing, you got a defrost problem, defrost problems are caused when excessive ice build up on your evaporator, two things could cause a defrost problem. (1) excessive moisture/ hot air entering refrigerator, hot days,hot foods, regular opening, to close heat source, range/ oven. in cases like that, cleaning of refrigerator will normally solve that problem. (2) faulty defrost heaters, defrost thermostat , located in back of freezer side, you will have to remove shelves and back panel, to get access to it,also check your defrost timer and speed of fan, but first disconnect refrigerator, clean and try , before changing any parts. it could just be excessive moisture. always remember to disconnect your refrigerator before attempting any repairs, let me know what happened, then i could tell you exactly what's problem. good luck
Posted on Aug 19, 2009
woodchuck789
  • 4070 Answers
SOURCE: Freezer coils frost up within minutes after being turned back on
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Aug 31, 2009
milten1
  • 1304 Answers
SOURCE: freezer is 0 degrees frige side only 40 degrees
that would be a valid check
but with this model i would look more twords you thermister in the refer, if its maintiaing a constant temp, but just outta temp, its more than likely you thermistor is going bad
Posted on Oct 14, 2009
Testimonial: "it seems that even if I set the control to the coldest is dosen't affect the temps range"
Sea Breeze
  • 4655 Answers
SOURCE: my frig is running but not cooling - frig is 50
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Posted on Jan 23, 2010
Testimonial: "Thanks for the quick help - yes frost on back wall. Once I unload and defrost should I then take out defrost thermostat? "
The freezer works fine but the refrigerator will not get cold.
On most new refrigerators there is damper that opens and allows the cold air from the freezer to circulate through the fresh food side.
I have seen this same problem caused by over stuffing either the freezer side and or the fresh foods side. On the sides of the fresh foods section there are normally vents which allow cold air from the freezer side to flow. If these are covered up, the air cannot circulate and without air circulation, the temp rise.
Both freezer side and fresh food side work because air is allowed to circulate around your product. I saw a refrigerator that the bottom half was 70 degrees and top half 38 degrees. The shelf about halfway down was completely blocking airflow. Threw out a bunch of boldly items and bags, rearranged items so air could flow and unit started working properly again.
If the damper is not opening, I have seen them freeze shut. It may have to be thawed.
There is also on some models a recirculation fan that gets turned on to circulate cold air from freezer. If this fan burns out or is blocked, it may need to be replaced.
You can go to searspartsdirect.com with your make and model number and get a complete drawing and parts breakdown for most refrigerators. And more important, you can buy them and have the part typically in two days at your door.
Hope this help!
Apr 19, 2016 | Refrigerators
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
My 2005 Admiral side by side has stopped keeping things cold everything in the freezer has thawed and the fridge part is now over 70 degrees there is power as the lights are on and it sounds like the ice...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Admiral 26 cu. ft. Side-By-Side...
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
Refrigerator runs but does not cool properly. Temp in freezer is 34 degrees, temp in refrigerator top is 70 degrees, and at bottom is 55 degrees.
heatman101
Jul 08, 2011 | GE GSS22IFR Side by Side Refrigerator
GE refrigerator is cooling to 48 degrees F, but the setting is at 37 degrees F. The temperature on my furnace is set to 70 degrees F. Is this affecting the refrigerator?
The freezer may be overcrowded with food in this case cold air from freezer is not migrating to refrigerator compartment. Inside the refrigerator, at the bottom and on top, there are opening sliding door that allows cold air from freezer to circulate in the refrigerator. Make sure that they are not obstructed. Or simply, your refrigerator condenser is dirty and may need cleaning. If neither of this is the solution, get a repairman to check or fix it for you.
Dec 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works but fridge doesn't stay cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Jul 16, 2010 | Maytag MSD2756G Side by Side Refrigerator
Keep a refrigerator/freezer in garage. The
Good day,
Yes. Domestic appliances will not work properly below approx 55 degrees.
The freezer suffers most simply because the machine runs rarely at 55 degrees and degrades as the temp goes lower.
They are designed to balance properly when in an environment where people live. Ideally 70 to 90 degrees Fahrenheit.
The machine is not broken.
Moving it inside, is the only solution.
Thank for using Fixya
Jan 02, 2010 | Frigidaire Freezers
Side by side freezer cold fridge not
the freezer may be overload or poor air circulation inside the freezer
Mar 10, 2009 | Kenmore Refrigerators
Refrigerators Logo
16 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
