Televison & Video Logo
g
g thompson Posted on Apr 13, 2014
My toshiba RDXV60KB dvd recorder won't turn on, doesn't appear to be getting any power, I've replaced fuse in plug but still won't work - is there an internal fuse that I can try to replace or any idea what fault could be ? Please help ! Many thanks
5 Related Answers
Anonymous
  • Posted on Nov 26, 2007
SOURCE: LG DR-4810 DVD Displays " PLEASE WAIT"
C113 10v 1000uF cap off an XFRMR in power supply board. Cooked and gone high esr. Replace with a 16v.
Anonymous
  • Posted on Dec 29, 2007
SOURCE: Will not playback get error message Please Check Disc
i have a r136 , have you got the dvd discs u need ? i had the wrong format .
eg, dvd+rw needed dvd-rw
if not and there re-recordables they dont work after a few recordings and u need a new disc.
A
Anonymous
  • Posted on Apr 02, 2008
SOURCE: Panasonic DMR-EH75V DVD Recorder
I have the same unit and luckily there is a service center here in dallas tx called bayard electronics. I just dropped mine off there. check out the website at www.bayardelectronics.com
Anonymous
  • 8 Answers
  • Posted on Jul 09, 2008
SOURCE: DVD player/ recorder problems... PLEASE HELP!!!
I have now had two Panasonic recorders 3 years apart and both have gone down with this same fault.
It's a shame as they are a fantastic recorder, I would have thought Panasonic would have put this right by now. It now 5 years on since I bought my first one and it sounds as if they still have the same fault.
Why the hell can't they just fit a standard computer dvd drive that’s cheap to replace, and not this abortion they fit.
I was looking on E-bay for Panasonic recorders that where faulty and found around twenty.
ALL WITH THE SAME FAULT
"DVD drive faulty"
I’m now looking for a new one but don’t know what to do as I have a ton of discs that need to be finalized, may just forget about them and keep clear of Panasonic in future.
Anonymous
  • 4234 Answers
  • Posted on Feb 01, 2009
SOURCE: panasonic dmr es30v
Without seeing the actual unit, I would guess that the power supply has failed. These unit have what are called "switch mode" supplies that rely on circuits that oscillate. If a capacitor goes bad, the unit won't oscillate properly, thus no power. These are difficult to track, but are not usually expensive to repair. I would suggest a trip to a service center for a detailed repair estimate. Report the results here.
Dan
sometimes electronics can be damaged by lightning storms and some may just go out depending on the age, if you cannot find a electronics repair shop you can try purchasing the same model or newer model here>>>www.discountbargainprices.com
TOSHIBA RDXV60KB RECORDER, POWER SUPPLY RELAY KEEPS CLICKING, THANKS.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
1helpful
Cannot record externally from Humax bt you View box onto Toshiba RDXV60KB ( HDD & DVD modes). As I previously could? I am getting message E26 " Cannot record from this program". But the Tos
This error e26 gets thrown up on some digital rights management programs.this really just means you are not allowed to record...ever increasingly thanks to the big corps like sony drm carrier signals are put into some broadcasts to overcome copying infringements.there still is a way to do this with the right equipment.some tv channels get revenue from their advert counts so they put these signals in to ensure that you can only watch at broadcast or catchup on certain devices.what I can't figure out is I can record anything whilst it's being aired and still transfer to older equipment but not anything with latest ios and certainly not with sony recorders.
My daughter pressed some buttons and now I can't get the guide on screen to use one time record
do a hard reset and if this does not work contact the manufacture or use the trouble shooting section of the manual
Why does my recorder turns it self off?
Look for a Reset and hold it in/on for 5 - 10 seconds. Apart from that I have no idea sorry, Greg.
1helpful
Toshiba RD-88DTKB won't switch on
Check the capacitor in the power supply board, if defective it will show a slight bulge at top, value should be around 1000uf give or take, if handy with soldering iron replace with same value and voltage rating.
3helpful
My toshiba RDXV60KB dvd recorder keeps switching off while recording
Could be a power supply issue or even a mechanical issue in the unit.
I have a toshiba rdxv60kb dvd recorder,,and can;t tune the programes into my sky box.
I have a toshiba Hdd & DVD / Video Recorder However I can not get it to work with my Sky setr up If I set thimer recording it does not work when I turn it on it will only work pn channels that are not from sky it will not instant record nor will it record programmes prerecoreded of sky HDD it will record everthing other than what I want.
My E-Mail Addres Is fj.gadkey_1@sky .com
My Home hone is uk 01527 545284
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
