Question about Maytag Neptune MAH5500B Front Load Washer
Od error code flashes when start is pressed - Maytag Neptune MAH5500B Front Load Washer
  • 32 Answers
You have a bad door latch assembly
Posted on Apr 14, 2014
Tip
OD light flashes
The flashing OD light indicates there is a problem in the transmission control system. When the Transmission Control Unit detects a malfunction it will flash the OD light and store a Diagnostic Trouble Code (DTC) in the computer. You will need to have a Ford Dealer pull the codes and determine exactly what is wrong.I wish I could be more specific, but there are about 120 different reasons for the flashing OD light.
on Feb 24, 2010 | Ford Expedition Cars & Trucks
OD light blinks when driving OD working I push the OD button and RPMs goes up press button again RPMs go down OD light still blinks
on most casrs, and For sure OLD cars. 90s
the OD warns you that the TCM is very unhappy
what is TCM tha that is the tranny brain.
(it shifts the tranny for you)
what we do is scan, it. in most cases its a jumper wire on a diagnostic connector, and it flashes out DTC error codes.
this is covered in the FSM, book. (factory service manual)
need one?
the operators guide tells this too, long lost im sure.
Jun 29, 2014 | 1994 Mercury Cougar
2002 ford explorer od light gets flashing and i loss power
The flashing light means there is a system problem with the automatic transmission. You will probably notice a lack of power when starting from a stop with this lamp flashing. The dealer or local mechanic should be able to scan for a fault code.
Apr 19, 2014 | 2002 Ford Explorer
Error p1500
The printers first error code show all lights flashing:
Flashing Ready'Data
Flashing Toner Low
Flashing Load'Remove Paper
Flashing Paper Jam
Flashing Error
Flashing Press Continue
By pressing continue twice to get to second error codes the lights show:
Flashing Ready'Data
Off Toner Low
Flashing Paper Jam
Flashing Error
Pressing continue twice more shows:
Off Ready'Data
Flashing Toner Low
Off Load'Remove Paper
Off Paper Jam
Off Error
Off Press Continue
Pressing continue twice more brings back to all lights flashing
The computers ( I have tired more than one with diff USB and A parallel cables) do not see the printer as being attached. My toner is half full. I checked the internal power board in base of printer and the fuse is good. The error should not have anything to do with being connected to a computer or not because when it was working and not connect to a computer it would not blink all the indicator lights (If I remember correctly, just the Press Continue light would be lite).
Information I have found so far:
  1. http://support.dell.com/support/edocs/systems/p1500/en/index.htm#online_documentation
o Under PDF Documents Owner's Manual(English) (.pdf) (1.33 MB) shows very little about the indicator lights.
o Under HTML Documents User's Guide shows more information about the indicator lights but mentions nothing about the secondary error codes.
  1. The Lexmark E321/E323/E220 are very close cousins to the P1500 and on Lexmark's website the manuals have more info on secondary codes but nothing that matches my error.
Information I am guessing could be the problem:
  1. The fuser has gone out (need to know how to check) Why else would they sell the fuser if it didn't go out regularly Part Number: 56P1053
  2. Clutch Assembly I'm not sure of the accuracy of the info on this page.
Mar 12, 2014 | Canon Office Equipment & Supplies
No overdrive 1992 geo tracker
first the fuses, all 6, yes 6.
4speed tranny, and is TCM (puter brain) shifted.
no flash codes from TCM?
http://www.fixkick.com/tranny/slush/OD-flashes%20now%20what.html
the TCM controls all 3 shift solenoid.
and OD, has many defeat rules in logic of TCM
one is if TCM , sees 4wd drive active it will not use OD
if the TCM sees errors, (did you dump the flash codes yet?)
it fill not use OD
if the TCM , sets limphom mode, (fail safe) it will not use 0D
or may skip second and use 0D. all this is in the FSM.
there is the tcm brain
http://www.fixkick.com/tranny/TCM/Tcm-macro1.jpg
here is a free online fsm on topic.
chapter 7? RTM
http://www.acksfaq.com/trackerfsm.htm
and 8a-39?
Mar 25, 2013 | 1992 Geo Tracker
My 1993 Od light keeps flashing fluid ok then check engine lite comes and car feels like it looses it's power feels like it's a 3 cylinder
http://www.ehow.com/how_6038371_retrieve-1990-toyota-scan-tool.html are instructions for pulling the error codes for 1990 - 1995 Toyotas.
Without the error codes to guide you, you could throw a lot of money at fixing something and still not be fixing the problem. Suggest you pull the errors codes and then you will have a place to start troubleshooting the problem.
Sep 15, 2011 | 1993 Toyota Camry V6
Flashing od
If your machine is a FAV6800AW or FAV9800AW see if this post will help you clear the OD error code on your machine.
Sep 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
OD off Light Flashing on my 1998 Ford Explorer XLT 4.0 V
The OD light is flashing to alert u to the fact that some kind of fault has occured in the transmission, the problem is in many cases a slipping condition, you need to have the trans control system tested for the trouble codes that are stored when this light flashes, this will let u know what the problem is and a direction to follow to repair it.
May 26, 2009 | 1998 Ford Explorer
Error Code "od" while trying to start machine
Could od mean overload? Reduce or actually weigh load and re-try
Apr 15, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
19 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
