Question about Hiro H50015 Network Adapter
Hiro h50015 nic on windows 7 says network cable unplugged when cable is clearly plugged in
Hiro h50015 gigabit nic installed in compaq sr2180nx with new fresh windows 7 installation. no internet connection. says cable unplugged. cable is plugged in.. tried different cables. downloaded drivers from realtek site and hiro site. installed drivers, uninstalled drivers numerous times. uninstalled microsoft client for networks and all the protocols and services and reinstalled them. at my wits end...
    Master:
  • 409 Answers
You would want to try it in another pc before trying multiple drivers or the protocols...
you wouldn't get a 'cable disconnected' error if they were an issue.
the card could just be bad.
Posted on Apr 14, 2014
    Problem Solver:
  • 30 Answers
To connect to the internet, you must have a device like a modem or a router. Is your PC connected to this device? Do you have other PCs or networked devices on your LAN? Can you reach them with ping?
To make it easier to help, you should give information how your network looks! e.g.
internet ---- cisco800 router --- d-Link switch ---- myPC
or something like that. Otherwise it is fooling around in the dark.
2 Suggested Answers
SOURCE: Issue with HIRO H50069 running on XP 32-bit.
For that you need to reset your router to factory defaults.
Then reconfigure fix this problem.
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Set WAN settings as your internet service provider settings.
Enable DHCP .
Click on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Also change channel type in wireless option 4,6 and 11 channel are best.
Try 1 by 1 then save settings and restart router.
Let me know if you need further assistance.
Thanks.
Posted on Nov 06, 2009
Marvell yukon ethernet shows with yellow exclamation mark and will not allow me to connect to internet
The driver should be on the motherboard disc or the one supplied by your ISP internet service supplier
make very sure all leads are plugged into their specific connection plugs you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
Feb 08, 2012 | Marvell Yukon 88E8001/8003/8010 PCI...
Compaq Presario 2050NX onboard pnp nic (LAN) device not found - reinstalled onboard LAN device driver, still can't see it
For Windows XP CLICK HERE
In Windows 7 the driver installs automatically
I would suggest uninstalling all drivers for the network adapter then reboot and allow the system to find the NIC again. If this is Windows XP uninstall all drivers for the NIC, reboot, and install the above driver.
If it is Windows 7 uninstall the drive, reboot and allow device manager to locate the driver itself.
Nov 14, 2011 | Compaq Computers & Internet
I'm not able to connect with my ASUS M50vm to ethernet. how i can check if the hardware is working?
May 16, 2011 | ASUS Intel 440BX Chipset P2B-VM...
Nic card not working? How to troubleshoot? Is there a plug and play nic card that can be installed onto this desktop PC?
Hello Sqis,
You can purchase any nic card which is compatible with WinXP or 7.
Insert the card in PC Slot of the motherboard.
Install the driver for the card and it will work.
May 05, 2011 | HP Compaq Presario SR1650NX...
Update Drivers pour REALTEK8139/810X Family fast Ethernet NIC sur "XP"
Apr 30, 2011 | Televison & Video
I need NIC drivers for a compaq computer
Realtek LAN DriverThis is the Type which is installed on your PC
Realtek RTL8169/8110 Family PCI Gigabit Ethernet NIC
Realtek RTL8168/8111 Family PCI-E Gigabit Ethernet NIC
Realtek RTL8101 Family PCI-E Fast Ethernet NIC
For Vista 32-bit
Click Here to Download the driver
For Vista 64-bit
Click Here These links are From Official Compaq site.Unfortunately there are is no download option for XP and Windows 7 on Compaq site.
so use the below link directly from Realtek
Click Here Try this first if this driver don't work use this it should get installed- Realtek Official site Choose Windows and Download the appropriate one according to your operating system. Here you have for all versions of windows.
Feb 04, 2011 | HP Compaq Presario SR5350F Desktop PC...
1. We make image of WS HP XW4600 with RHEL 5.1 - using clonezilla 2. Then we put this image on PC HP Compaq 6000 Pro Microtower 3. Everything is OK excluding network adapter - it doesn't work. 4. By...
You might plug in a USB wireless adapter or NIC. That might get you to the internet where you can download the needed drivers for the internal NIC. Or you can look in Device Manager, see what NIC is listed that needs drivers, download that driver set to another computer, then transfer the drivers to the Compaq. In Device Manager, add the drivers for the NIC, directing the search to the USB device where the drivers are located.
Oct 15, 2017 | Red Hat Enterprise Linux ES 3 Standard...
I cannot install ethernet driver of hp compaq d530. Where can i find it?
Hello: I hope the following information is helpful.
If you are trying to install the driver for the Broadcom ethernet NIC that was pre-installed (NOT an ethernet card that you purchased and installed yourself), there is a softpack (updated driver installation) download available from HP/Compaq. It will install the driver automatically for you, just download it from the link below and run the ".exe" file.
IMPORTANT: Check to be sure that your current Operating System, and model of the network device you are trying to install, are BOTH listed below BEFORE you download!
This is a software / driver update for the HP Compaq d530 ultra-slim desktop: All Models
Supported network devices:
BCM5906M Broadcom 10/100/1000 5782 based NIC Broadcom 570x 10/100 Integrated controller Broadcom NetXtreme Gigabit Ethernet 5782 Broadcom NetXtreme Gigabit Ethernet PCI-Express NetXtreme(tm) 10/100/1000 Gb NIC
Supported Operating Systems: Microsoft Windows 2000 Microsoft Windows 98 Microsoft Windows NT 4.0 Microsoft Windows Vista Business 32 Edition Microsoft Windows Vista Business 64 Edition Microsoft Windows Vista Enterprise 32 Edition Microsoft Windows Vista Enterprise 64 Edition Microsoft Windows Vista Home Basic 32 Edition Microsoft Windows Vista Home Basic 64 Edition Microsoft Windows Vista Home Premium 32 Edition Microsoft Windows Vista Home Premium 64 Edition Microsoft Windows Vista Starter 32 Edition Microsoft Windows Vista Ultimate 32 Edition Microsoft Windows Vista Ultimate 64 Edition Microsoft Windows XP Home Edition Microsoft Windows XP Professional Microsoft Windows XP Professional x64 EditionINSTALLATION INSTRUCTIONS: 1. Download the file by clicking the "Download" or "Obtain Software" button and saving the file to a folder on your hard drive (make a note of the folder where the downloaded file is saved). 2. Double-click the downloaded file and follow the on-screen instructions.LINK where file can be downloaded:HP/Compaq Support-Broadcom Driver download
Again, I hope this information is what you neededto install your network device. Should this not answer your question, please come back, provide more details of your problem, and we will be happy to help!Best of luck to you!
Jun 23, 2010 | HP Compaq d530 Ultra Slim PC Desktop
After a few minutes conected to the Internet I get an disconnectd running the network trouble sheeter I get the erro mesage that the network cable is unplugged or broken. I replaced the Ethernet cable and...
You might want to open up your device manager on your xp computer and click on network adapters and double click on your nic and copy down the settings under the advanced tab then do the same on the Windows 7 machine and change the values to the same on the Wnds 7 nic adapter.
Jan 28, 2010 | Dell Studio XPS Desktop Computer
A network cable is unplugged
OK, in order to solve this problem, I will need more information:
1) What is your operating system (i.e. Windows XP? Windows Vista?)
2) Is this a laptop or a desktop computer?
3) If it is a laptop, is there a switch on the case that turns on and off the wireless ability? Check your user manual - it might be as simple as turning on the wireless switch.
4) If it is a desktop, what kind of wireless adapter did you install?
I'll be able to help more when I get this information. In the meantime, here are a few things you can do:
First of all, you need to delete all of the duplicate connections from Network Connections. They won't really hurt, but they're not helping either. To delete them, just right-click on them one at a time and choose "delete."
Next, you need to understand what the message "a network cable is unplugged" refers to: this has nothing to do with wireless. If there is no actual hard-wire cable connected to your computer, the port (that's the opening that you plug a network cable into) will tell Windows that it is empty. This results in the message "a network cable is unplugged." You can ignore it, or - if you plan to use this computer with a wireless connection only - you can right-click on the connection in Network Connections and choose "disable." This stops the message from appearing, and can be reversed (enable) at any time.
I look forward to hearing from you.
Jan 04, 2009 | Televison & Video
Hiro H50015 Network Adapter Logo
83 people viewed this question
Top Hiro Computers & Internet Experts
Prashant M
Prashant M
none
Are you a Hiro Computer and Internet Expert? Answer questions, earn points and help others
