Question about Intertherm Heating & Cooling
Central air wont work
The heater worker this morning, The little breaker switch was off, turning it on doesn't do anything. There seems to be a noise though, like a very faint motor, but nothing happens.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 24 Answers
Reset the remote control
Posted on Apr 13, 2014
catriver
  • 878 Answers
SOURCE: Compressor turns on but not the fan.
Jeannine, on this model there is one motor that turns both the evaporator and condensor fans. First you want to check to see if there is any obstruction preventing the fans from turning. There is also a dual capacitor that gives this motor a kick start. If this goes bad the motor will not run, just humm. Hopefully it is just your capacitor that has failed but it could be the motor itself. Part number for the capacitor is 16-05-00710-109. Part number for the motor is 50-11-t26p0-050. Usually a bad capacitor will show signs of leaking or bulging, but not always...Catriver..post back
Posted on Aug 02, 2006
bobotfel
  • 236 Answers
SOURCE: 20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Posted on Jan 12, 2008
Bat1956
  • 585 Answers
SOURCE: Central Air Compressor Runs Constantly
Sounds like the contactor is stuck in the outside unit. Turn off the breaker or safety switch, remove the cover, and tap on the body of the contactor with a hammer handle or similar tool. If a click is heard you may have dislodged it and it may work for either a short time or indefinitely. (yeah ,I know that's kinda vague) Test it. If that doesn't clear it up, disconnect the thermostat wires just to make sure and re-test. If the compressor starts without the thermostat connected, you will need to replace the contactor. If you feel real handy, you could perhaps remove the cover, seperate the contacts with a screwdriver, dress the contacts with an emery board until smooth and shiny, and try again.
Posted on May 24, 2009
luker711
  • 91 Answers
SOURCE: My AC unit wont blow the cold air.
No, you probably have a bad evaporative fan motor, capacitor or switching. It usually takes a Pro 1/2 hour to track down such a problem with good training.
Posted on Jul 09, 2009
  • 582 Answers
SOURCE: CENTRAL AIR UNIT IS TRIPPING BREAKER
IF YOU ARE NOT ELECTRICALY EXSPERIANCED I WOULD FIND SOME ONE YOU KNOW TO CHECK THE FULL LOAD AMPS ONE THE UNIT AND USE AN AMPROBE TO CHECK AND SEE WHAT AMPS ARE BEING DRAWN. SOUNDS LIKE YOU MAY HAVE A WEAK CONNTACTOR THAT IS CAUSEING THE PROBLEM
Posted on Aug 10, 2009
I have a Biasi Riva Advance HE Combi Boiler. The pilot light and fan dont seem to be working, I can hear a click when I run the hot water tap and a click after I turn tap off,
Have you bleed the air from system and run hot water and heating at the same time , bleed the pump . you could have air in the pilot after turning it off
May 01, 2017 | Water Heaters
Lg air condition doesn't work when it is cold outside
Sounds like the crankcase heater. This is likely hooked to a temp sensor that is activated when it gets below a certain temp. There is likely a short in the heater and it trips the breaker. The heater keeps the refrigerant warm inside the compressor when compressor not running. Find a different technician.
May 19, 2017 | LG Heating & Cooling
Central ac/ heater (electric)...The heater quit working in the mid of the night, only cool air is exiting the vents. Everything else seems normal except the air is not warm anymore. We need warm air,...
check batteries in thermostat? you'll need a voltage tester,either neon light or vom.check to see if breaker is tripped.throw back and forth if it looks ok.remove cover check to see if power is getting to breaker then out of breaker.The heat is turned on with a low voltage circuit. check to see if you have 24 volts coming out of transformer.if all this checks out it gets real tricky. power to heating elements is switched via switches that are back a ways amongst lots of wires.very dangerous to work on with power on.I don't recommend trying to go further.
Jan 12, 2011 | Heating & Cooling
What supply house sells haier air handlers in Atlanta ga
any 4 tonnes air handler will fit if you respect de gas for the unit if r22 than than r 22 air handler if r410 than r410 air handler you can put r410 air handler if r 22 not avalable but be sure that expension valve is compatible.
Dec 13, 2010 | Haier HC48C1VAR Central Air Conditioner
I turned off the heat on a central heat/ac system this morning to access a sump pump that is located below the furnace system. I fixed the sump pump and now the heat will not come back on. Is there a reset...
you might check the 24 volt transformer or thermostat that is where i would start try your a/c to see if it works if it does then you have a problem inside your unit
Dec 31, 2009 | Broan-NuTone 658 Central Heating System...
Central air condtioner making beeping noise!
it means it has a fault. try resetting unit by switching circuit breaker off and on it might go away
Jun 04, 2009 | Amana ACD106R Wall/Window Air Conditioner
Water heater problem (no leak on floor)
shut off the power to the hot water heater wait 5 to 15 min. If the noise stops it is the water heater eating up electricity. Turn it back on if noise starts again feel about 5 or so feet down the hot water line. If this line is hot you have a leak beyond the hot water heater. If you still hear it when the power is off to the water heater. next turn the water off on the cold water line at the water heater with the power off also Look at the water meter and see if the hand or wheel on the meter is moving and it should no be. Also think if the breaker to the hot water is off the electric meter should practically stop if no refrig oe anything else on. Have someone watch the electric meter and switch 1 breaker at a time leaving the one you just shut off in the off position until you cut them all off. Should the meter still be moving you have a main service cable shorting somewhere call the power company to advise you further if this is the problem.. Should just cutting the circuit breaker for the hot water heater stop the noise and down the hot water line is not hot then you are probably wasting power due to a thermostat or element inside the hot water heater.. Thank you j
Nov 23, 2008 | Ruud Central System Air Conditioner
Central honeywell air conditioner
Sounds like it may have lost power. Check the breaker and the fuse at the furnace. If they are all in the on position and working then it sounds like you may need a technician. If the display is blank on the thermostat you may also want to replace the batteries.
Jun 12, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
21 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
