Pilot light keeps going out! difficulty lighting
Vulcan Heritage Heater pilot light keeps going out! difficulty lighting it! should i clean it? broken radiants. how to open front?
    Sergeant:
  • 340 Answers
Dirty pilot, you may need a contractor.Tom
Posted on Jun 18, 2009
Vulcan Gas Heating Furnace Pilot Light Goes Off
Clean pilot may be too small blow out with tube or air line , thermocouple not working try changing it
May 19, 2012 | Heating & Cooling
Rheem #22DV50-38,pilot light keeps going out.Thermal coupler has been changed.
Most gas water heater problems can be solved by cleaning burner parts and combustion chamber, and bleeding air out of gas line, checking gas pressure, and making sure gas shut-off handle is turned-on and parallel with gas line:
Many things cause pilot light to go out including dirty parts, air in gas line, and hot-unventilated atmosphere.
Open following links for troubleshoot resources and cleaning illustrations.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
Jul 08, 2011 | Rheem Water Heaters
Pilot light on thermostat click main burner doesn;t come on
Don't know if the pilot has been cleaned or the thermopile has been changed. The pilot being lit can be good to keep valve open but not strong if enough to open main burner. If after checking all the above, make sure you have gas flow from the valve, if so replace thermostat.
Apr 01, 2011 | Vulcan EF3 Deep Fryer
We are having difficulty lighting the pilot light on our wards gas wall heater. Is there a diagram that shows where we are suppose to put the lit match and which way to turn the knob? Thanks for your help
you may have to push down on gas knob to start gas flow for pilot move flame so it licks thermo couple detector.
if thermocouple gets too old it will not generated enough power to keep relay open for pilot
Nov 25, 2010 | Montgomery Ward (223600UP) Heater
Describe your Problem i have a quasar vulcan gas heater pilot light is on but wont ignite. can hear it clicking trying to ignite what is the o=problem . this heater maybe about 20 years old
What do you mean by the pilot light is on but won't light. Do you mean that there is gasbut won't light. If so the spark may not be hitting the pilot properly or it may not be getting enough gas. If lighting but continuing to spark the sensor may need cleaning. This can be cleaned with steel wool (not sand paper), probably will need to disassemble the pilot asembly The pilot may also be dirty reducing gas flow. If this is the case dis-assembly will be needed and the pilot cleaned.
Sep 05, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Noisy pilot light Vulcan Quasar 40
Simply clean out the jet tube with a fine wire, the sound you hear is the gas blowing by the irregular edges, and swirling and not mixing and producing sound waves, (Bit like a flute) So, you need to clean the tube right out, and smooth off the end again, & sorta "Countersink", Flame the end too, at the end.use a very fine needle file, and make it look like new, that will sort your problem out. Then adjust so you have a good gas flow. Also check out it isn't blocked too.
Apr 30, 2010 | Cozy Enclosed Front Console Heater 20,000...
probably need to clean the pilot orfice out. You will have to pull the entire burner assembly to get it out. Pull the tube going to the pilot light out and the orfice will be in the end closest to the pilot light. Once you get it out there might be a white fuzzy substance on it, clean it off, the hole in the orfice is very small, DO NOT make it any bigger, find something to push thru it like a single strand off a wire brush. After cleaning re assemble and re light, this should cure your pilot problems.
Mar 14, 2010 | Reliance & 30 Gal Mobile Home Water Heater...
My pilot light kept going out. I cleaned it
You may have to get a new thermocouple.
This is a small copper tube that goes from the pilot light area to tha gas valve.
It feels the heat from the pilot and keeps the gas valve open for gas to flow to the pilot or to the logs when in the lit position.
Without the gas valve will stay closed.
Jan 06, 2010 | Vanguard International Blue Flame - Medium...
We have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
Nov 04, 2009 | Vulcan AUW230A Heater
Vulcan freeloader hot water heater
Could be moisture in the gas supply line - get your gas fitter to purge the line at the meter.
Jul 08, 2008 | Heating & Cooling
Heating & Cooling Logo
370 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
