Question about Panasonic PT-60DL54 60" Rear Projection Television
Bought a Panasonic dlp pt-60dl54 from friends. Usually works fine, but sometimes suddenly switches off for no reason. Couple of minutes later it switches itself back on again. Does this a few times until it just won't switch on again until a few hours later. Tried different plug point, no difference....help?
  • 35 Answers
First thing you want to do is change lamp. also use vacqum cleaner to clean cooling fans. J.D.W.
Posted on Jun 18, 2009
Need service manual for panasonic pt-50dl54j
You should be able to download a technical manual from this site.
Scroll down below the cover image and press on Download File link that shows up in about 10 seconds after opening the link.
PANASONIC CHASSIS GN1D PT 50DL54 PT 60DL54 DLP TECHNICAL GUIDE Service...
Aug 28, 2014 | Televison & Video
Won't turn back on
Have you checked to make sure the bulb is not
Apr 22, 2014 | Panasonic PT-D7700U DLP Projector SXGA...
I have a panasonic pt-60dl54, the sound works but green picture
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens.You will need to replace the DMD board. Have a blessed one!
Apr 13, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Screen is fine when I first turn on TV, then goes black
Sounds like you dlp lamp is going out. That's a pretty old TV and if you are still running on the stock lamp this is exactly the type of thing that will happen. The lamp model for this particular tv is the ty-la1001. You can find that over here:
http://dlplamps.com/products/panasonic-dlp-lamp/panasonic-ty-la1001.html
Mar 21, 2009 | Panasonic PT-52LCX66 Projection Television
I have had a panasonic DLP PT-60DL54 for about 3 1/2 years and up til now its worked fine. The first time I seen a problem the tv shut off after about 5 mins and a fast clicking sound was coming from the...
This is an old posting, but will reply anyways.
I am not sure if this is the same problem that I had , but sounds similar.
I found that there were power surges, or lack of power. I could see my power bar blinking at the time this happened.
So after trying everything under the sun, I plugged it into another outlet with the power bar, and have never had a problem since. It seemed that for some reason I had surges in that line, and have no idea why.
Not sure if this is what is happening to you, but maybe might be of some help to someone else.
Thanks.
Bob.
Nov 21, 2008 | Panasonic PT-60DL54 60" Rear Projection...
Tv shutting off on its own.
Was talking to one of the experts on the "chat live now" tab and he suspects a power supply problem. Who knows??
May 02, 2008 | Panasonic PT-60DL54 60" Rear Projection...
PT-50DL54 panasonic 50" DLP
to get rid of "replace lamp" push the blue action button on the remote and the volumn down on the tv set for a couple of seconds. this has to be done at the same time, good luck.
Bob
Dec 09, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic PT-47WX49E
The only thing I can think of that would make the picture fade to black is a loose solder joint on the filament supply. Each of the 3 picture tubes has a filament and if the 6.3 volt supply to those filaments is suddenly lost, the picture fades to black as the filaments cool down. An experienced tech can find and correct this for you quite easily.
Sep 10, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-60DL54 60" Rear Projection Television Logo
318 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
