Question about Amana NTW4700YQ Top Load Washer NTW4700YQ
Amana washer lid lock wont quit blinking
Washer was not in use and lid was up. lid lock light started blinking and now washer will only fill and drain-will not wash or spin
Your washer lid lock button is locked and lid was not put down before it locked, which is why the light is flashing. Therefore, push the "START" button until you see the lid lock button is off (Approx 3 seconds). Once it is off, then you can put the lid down and push the start button again, which will lock the lid into place. The washer will NOT drain or wash or spin unless the lid itself is in the locked position. If you were able to get the lid down and locked and it still doesn't work, then you need a technician to replace a wiring harness. However, you mentioned that the lid lock button was flashing, therefore, it stands to reason that your lid is NOT locked down.
Posted on Apr 13, 2014
Testimonial: "I really appreciate the response, but I should have mentioned that I already tried holding the start button many times to no avail and I tried messing with the lock mechanism, which is not in the lock position."
SOURCE: Washer wont work.
I FOUND BROKEN BELT . HOW DO I CHANGE IT ?
Posted on Sep 04, 2008
fanny
  • 146 Answers
SOURCE: amana ALW480DAW washer
Remove the front panel by loosening the two screws that hold it in place. Unhook the spring that puts tension on the tension pulley. Remove old/worn belt and replace with new belt. Very important that you use the correct size belt or the motor may be damaged and remember to hook the spring back for the tension pulley. The new belt has to go around the inside of the tension pulley.
Posted on Oct 31, 2007
  • 156 Answers
SOURCE: washer wont drain or spin just hums and then blows fuse
bad motor
Posted on Feb 25, 2008
SOURCE: Amana LWA50AW Washer Leaks!
Same problem here. It's coming from Shaft. Any instructions???
Posted on Apr 26, 2008
SOURCE: won't drain or spin
Sounds like the lid switch which is only about 30.00 to fix if you do it yourself. It's a little difficult but it's much better than replacing or having someone come in and do it
Posted on Mar 11, 2009
I have a Amana top loader washer how do bypass the lid lock so it can wash?..It fill with water then the lid light just blinks because it doesnt lock.
Locate the switch by the lid and simply connect a wire between the two wires going to it to affect a bypass.
Nov 01, 2015 | Amana Washing Machines
Lid locked light on, will not release
The lid lock light won't stop blinking. - Fixya
www.fixya.com/.../t14714916-lid_lock_light_won_39_t_stop_blinking
Oct 21, 2012 - The lid locked keeps blinking and I can not start a cycle. - WhirlpoolLSB6200KQ Top Load Washer question. ... Whirpool cabrio wtw5500xw top loadwasher will not start lid light flashes then goes out and into flashing pause ...
Whirlpool washing machine_ lock light flashing_ nothing ...
? 1:53
www.youtube.com/watch?v=zrV9w6Z5LAU
Mar 3, 2012 - Uploaded by briantaylor62 Whirlpool washer wont start a cycle, lid does lock and the locklight ... a cabrio as well that just has the lid lock flashing and nothing happens , I ...
Flashing Lid Lock Light: How to Troubleshoot Errors on Your ...
? 1:23
www.youtube.com/watch?v=nttHsAX2_OM
Mar 27, 2015 - Uploaded by searspartsdirect
The lid lock light on VMW washers, made by Whirlpool, Kenmore and Maytag, will flash whenever there is a ...
Oct 12, 2015 | Washing Machines
WASHER ... COMES ON GREEN SENSING LIGHT STAYS ON START'S TO FILL CLICK'S OFF RED DOOR LIGHT LOCK LIGHT COMES ON STAY'S BLINKING
Thank you first person that has provided a model number sounds like you already changed the lid lock assembly if you did you know how to get the top up inside the front panel is a tech sheet it will tell you how to place the unit into diagnostic and read the lights for an error code recheck your connection at the control board a flashing lid lock would should give and F5E1 or F5E2 error code also check the alinement of the tab on the lid where it goes into the lock assembly should be a smooth transition
Jan 12, 2015 | Amana NTW4501XQ 3.4 cu. ft. Top Load...
Unlocking your washer so it actually works.
If the green cycle light is flashing on then off, this usually means the cycle is paused. The lid lock should unlock when in pause mode, if not you will need to press and hold the "Pause/Play" button to clear the cycle completely, if there is water in the unit, it will drain first, then unlock the lid and be on standby to start a new cycle. Pleazer Appliance...
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
I have an amana top loading washer and when I press the start it fills a little the locks makes some balancing noise then the lock light starts blinking
There is a tech sheet on the front panel on the inside left upper corner, it is in a plastic bag . You may be able to reach it with the lid open if you push the tub back, be carefull it has sharp edges. It will show you how to put the unit into test mode and get any fault codes. Possible problems may be actuator, capacitor, lid lock or broken red or yellow wire to motor. That is the most common causes. It all depends what fault codes are saved in the history.
Apr 05, 2014 | Washing Machines
Why wont my amana washer start at all?
My washer will notwork it will not let the lid lock are fill with water
Jan 20, 2013 | Amana NTW4501XQ Top Load Washer
LID LOCK FAULT
Fault is displayed if Lid Lock has not moved into locked position or motor cannot be powered.
Lid is not closed completely due to interference.
Check for lock interference with lock striker.
Wash media buildup (detergent, lint, etc.) is preventing the lock mechanism from sliding.
Main control detects open lid switch when attempting to lock.
Main control cannot determine if lid lock is in a locked state.
Perform the following checks if the washer does not lock (or unlock).
1. Perform the Lid Lock test under Manual Test Mode on page 9. The following steps assume that this step was unsuccessful.
2. Check lid lock mechanism for obstruction or binding. Repair as necessary.
Oct 20, 2012 | Whirlpool LSB6200KQ Top Load Washer
Amana NTW4700YQ Top Load Washer NTW4700YQ Logo
900 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
